What Tires to Buy for Your Prius?
Discussion in 'Gen 4 Prius Main Forum' started by Bob Welcher, Nov 27, 2023.
  1. Bob Welcher
    Bob Welcher Junior Member
    Columbus Ohio
    Almost 2,400,000 Prius have been sold in the United States since 2005. Many of these vehicles have 195 / 96 R15 tires that will require replacement at some point.
    I owned a 2010 Prius with Michelin 195 / 96 R15 Energy Saver tires, and when I sold the Prius, the tread wear was in line with the 65,000-mile limited warranty. They may be great tires, but they may not provide the best low rolling resistance for optimum mpg. My 2010 Prius only got 40 mpg – I’m unsure if it was the Michelin Energy Savers installed or the software upgrade for the inverter overheating problem the Gen 4 Prius’ encountered.
    Michelin has discontinued the Michelin 195 / 96 R15 Energy Saver tires, but most other Energy Savers sizes are still available. I could find any information on why Michelin discontinued the size of the Energy Saver. One complaint on Michelin’s website reported that the 195 / 96 R15 Energy Saver tires were chunking, which might have been why Michelin discontinued this size (is it possible that only one size would experience a fail?). Another possibility is that the tire did not have sufficient low rolling resistance to allow the Prius to achieve 54 mpg. I contacted Michelin support to find out if they would manufacture that size energy saver in the future. The support agent gave me no information about why Michelin discontinued this size or if Michelin would manufacture this size in the future.
    As a Michelin tire fan, I installed Michelin Defenders ($155) on the 2021 Prius Prime. After installing the Defenders, I took a 187-mile trip at an average speed of 68 miles per hour, and the Prius mileage was 40.9 mpg. On a prior 252-mile with the Dunlops, the Prius averaged 51.6 mpg. Another trip for 442 miles averaged 53.7 average mpg. (See attached energy consumption screen photos.)
    The 40.9 mpg is a drop of almost 20% in fuel efficiency with the Michelin Defenders. So, I returned to Discount Tire, and they agreed to switch the tires to another tire under their customer satisfaction (“We aren’t happy unless you’re happy”) program.
    For the 2021 Prius Prime with 195 / 65 R15 tires, the OEM factory tires are the Bridgestone Ecopia EV 422 plus (Firestone), Dunlop Enasave 01 A/s (a poorly rated / underperforming tire), and Toyo Nanoenergy A 41. I’ve never heard of Toyo, and the Dunlops only lasted 28,000 miles, so without Michelin Energy Savers, I chose the Bridgestone Ecopia OEM tires ($169), thinking that Toyota knew they would hit the mark for low rolling resistance and the 54 mpg.
    My 2021 Prius Prime came with the Dunlop Enasave tires. These tires enabled the Prius to achieve 54 mpg regularly. Unfortunately, these tires required replacement at 27,000 miles. Without much of a choice of energy-saving tires, I chose the Bridgestone Ecopia (Firestone) as a replacement. The tire has a 70,000-mile guarantee, but many owners report far lower miles from these tires. The Bridgestone Ecopia tires have a 90-day return policy if there are any immediate problems. The warranty is reasonable, with a percentage of wear correlated to the percentage warranty allowance (50% wear = 50% replacement discount).
    To have a comfort zone with these tires and protect my investment, I am relying on the Bridgestone warranty/guarantee if the tires have a shortened lifespan. The Bridgestone (Firestone) warranty/guarantee is a little tricky – one of the requirements is to keep the tires aligned. The only way to prove that you have kept the tires aligned is to perform regular, documented alignment checks, ranging from $90 to $100. One owner complained that Bridgestone denied the warranty adjustment because he had no alignment performed every 6 months.
    The Bridgestone/Firestone warranty manual has a Maintenance Record chart to record the mileage, date, and retailer for inspection, rotation, balance, and alignment. I am assuming that Bridgestone requires the documented maintenance records for the warranty. On the Maintenance Record, the Recommended Inflation Pressure includes a line for the months of the year, which may indicate that you are to have the inflation pressure measured monthly.
    Discount Tire assured me that if I rotated tires every 5,000 miles and kept the tires at recommended pressure, I would get good mileage out of the Bridgestone Ecopia.
    If you buy the Ecopia tires and intend to keep the Prius for a long time, the best bet is to buy a lifetime alignment for the vehicle, which costs about $200. Buying the lifetime alignment from a Firestone Dealer/Service Center keeps the information in-house since Firestone owns Bridgestone tires.
  2. BiomedO1
    3,895
    2,042
    SacTown, Ca
    If you have a Sam's Club, Costco, or BJ nearby it may be worth it to take a look. They haven't given me any issues on warranty replacements and do free 5K mile rotations and flat repairs. They've replaced two Goodyears on my SUV without hassles. Goodyears has thin sidewalls, so if you hit a chipped curb just right - you can rip a hole into them or travel on gravel pothole roads.
    I've got 33K+ on my OEM Dunlops and probably got another year left on them. Still a few 10ths from the warning bars.
  3. Bob Welcher
    Columbus Ohio
    I switched from the Michelin Defenders to Bridgestone Ecopia tires (OEM on the 2021 Prius). On a 227 mile trip the Bridgestone tires averaged 51.6 mpg, which will improve as the tires wear in.
    BiomedO1 likes this.
  4. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    And what time of year was it when you switched tires to defenders? Fyi Toyo tire have been around for about 80years now and is a very well known brand..
    So long story short, basically your spending $250-$300 more every year in tires, to try and save a few mpg, and your driving in inferior tires that don't handle or brake as well. Not sure how any of that makes sense but ok.
    #4 Drakxyfly, Dec 4, 2023
    iLikeTurtles likes this.
  5. Bob Welcher
    Columbus Ohio
    I purchased the Michelin Defenders in November - 50s and 60s. I switched to the Bridgestone Ecopia on December 1st. Mileage with the Defenders was 40.9. With the Bridgestone tires the last trip was 227 miles 51.6 mpg. An 18 mile round trip for dinner tonight netted 62 mpg. Big difference.
    Still haven't hear anything about Toyo and the Discount Tire manager said he didn't know anything about them either. Bridgestone Ecopia were the same price as the Defenders and from my research they are definitely not an inferior tire. I like the Bridgestone's ride and handling better than the Defender's. And I wouldn't call a 20% difference (14 mpg) in gas mileage "a few mpg" especially over the life time of the Prius.
    I think I'd rather have my cake and eat it too. Great mileage and long lasting tires, which i think I will have. Time will tell.
    I'll file updates as time goes by.
    #5 Bob Welcher, Dec 4, 2023
    Merkey likes this.
  6. parked
    parked Junior Member
    37
    17
    SF Bay Area
    I have Michelin Defenders on my 2017 Prius Two, and I tend to average around 52 mpg city/hwy, where I go up an 800 ft high hill to get home.
    I dislike the squishy swaying sidewall feeling on low rolling resistance tires, which is especially bad on the Ecopias we have on our Honda, so I add just a tiny bit of pressure to stiffen that up a little. The Defenders have borderline safe traction, IMHO, and the extra pressure exacerbates that some. But they will age out long before wearing out, just like they did on my old Tacoma and Prius C that ran Defenders.
    Drakxyfly likes this.
  7. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    I will start by saying any manager of a discount tire who says they don't know anything about Toyo either is lying to upcharge you or has no business being a manager at a tire store. Not saying they are the greatest tires out there but the Proxes888 are extremely well known track and performance tires.
    There are three other threads in this forum alone, that were made in the past 2 to 3 weeks, talking about winter tires and MPGs right now. Let me break this down for you: there wasn't a loss of 20% from switching to defenders tires, period end of story. You switched your tires over in Winter time just like everyone else and saw a drop in mpg and assumed it was the tires which is not possible. First and foremost winter time. Winter time has been known to drop MPGs by up to 30% in hybrid vehicles. I took a 900 mile road trip in September and then October. In September I got 58 miles a gallon and in October I got 50 miles per gallon on the same trip. The only difference was it was 30° colder in October. Second winter gas comes in at the end of September beginning of October. Winter gas you'll lose about 3 to 4% MPGs. Third, Michelin is known to use a break-in compound that negatively affects MPGs, they themselves will tell you this and that mpg will return to normal after 1/32-2/32 wears down. Fourth, you went from old worn and tires, with less tread and height, to brand new tires with more tread more height, weight and more rolling resistance. This thread pops up four or five times a year every time someone changes their tires. Like I said there are three different threads about this in this forum alone right now.
    Tires simply don't make that big of a difference as your saying. Independent test by tirerack show the biggest difference by switching to rolling resistance tires with 6.7% miles per gallon savings. The proof is in the poster above still getting 52 miles per gallon with the defender tires. Tires which are yes superior to any energy saver tire. Energy saver tires simply give up grip and handling for low rolling resistance. The average savings on a low resistance tire is about 3 or 4%, or a mile to two miles per gallon difference.
    Now let's look at the wear and cost. By your own admission the new Ecopias, only last about 25,000 mi. This means you have to place them every 2 years compared to the Defenders five to six years. Plus now because you want to use the warranty, you have to get it aligned. To even claim the warranty you have to drive the tires down to the 2/32nd, further making a tire which is has less grip and increased stopping distances, more dangerous. So let's say worst case scenario your 10 miles per gallon drop in mpg is accurate, which is isn't, but we will use that as a worst case scenario. If you fill up once a week with the 10 mi per gallon difference, at $4 a gallon would cost you about $115 a year extra. Changing tires every other year at a current cost of $1100 for the Ecopias with certificates, versus every 5 to 6 years, you can subtract out the extra $115 cost for fuel, and other tires, running Ecopias will cost you $250 to $300 more every year, when you break down the cost of replacing tires more frequently and the alignment over the first five to six years. Considering most people only keep their car 7 to 10 years, You will do this four to five times with the Ecopias, meaning You will spend $1,200 to $2,000, (which includes all the extra time and effort of the alignment and logging tire pressures ect) more over the course of owning the vehicle for 10 years to save a couple of miles per gallon, all the while using an inferior tire. That's the best case scenario as like I said, you really didn't loose 10mpg from tires. In reality it's costing more than that. Defender and the step above then the Michelin Cross Climate 2, are some of the best if not the best all season tires available on the market. Sorry but the math just doesn't add up. Your not really having any cake at all, but to each their own I guess. GL!
    #7 Drakxyfly, Dec 5, 2023
  8. Bob Welcher
    Columbus Ohio
    Drakxyfly, question: I see nowhere in your responses about owning or having personal experience with Bridgestone or Toyo tires. May I ask the source of your information and the basis of your statements and opinions?
    According to Car Talk, Bridgestone is #6 in sales, and Autoweek puts Bridgestone # 5 in the US. Toyo is not in the top 15 on either list.
    I have been a customer at Discount Tire for 15 years and have done business with this manager for 6 years. I trust his judgment and doubt he has any hidden agenda. BTW, I don’t think it is appropriate or acceptable to call the manager (or anyone) names on Priuschat.
    I think what the Discount Tire Manager is indicating is that he has had little experience with Toyo, even though Discount Tire sells them, but probably not many. Reviews give Toyo an average of 4 to 5 stars, which is very good. The average mileage warranty for Toyo passenger tires is 40,000 to 50,000 miles, which is probably inflated (no pun intended). Toyo may sell more truck tires than passenger tires.
    “We’re talking winter tires here…” The Bridgestone Ecopia Plus are not winter tires; they are touring tires.
    “Winter time has been known to drop MPGs by up to 30% in hybrid vehicles. “ It is not “winter time” – in November and through December 6th, it has been in the 50s and 60s. The temperature has had nothing to do with the mpg. The same weather and road conditions were present when the Defenders got 40.9 and the Bridgestone got 50.6.
    I have owned two Prius cars and have never experienced a “30%” drop in mileage in the winter – maybe 3 or 4 mpg, but not 30% (15 mpg). That’s ludicrous.
    While there have been reports of Bridgestone Ecopia tires lasting 25,000 miles, which could be due to driving habits or maintenance, driving style and conditions, etc., they will probably last many more miles. Even if they don’t last the full 70,000 miles and only 40,0000 miles, the warranty is 50/50 (wear/reimbursement) on replacement costs.
    As I stated, time will tell. Thanks for your input.
    #8 Bob Welcher, Dec 5, 2023
  9. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    No difference if I have or haven't run Toyo tires in the past(which I have), it's one of the top tire mankers in the world. Funny you mentioned Bridgestone because Bridgestone was founded in Japan in 1931 and Toyo was founded there as well just 14 years later. Toyo , Yokohama, and Bridgestone are the top three Japanese tire manufacturers. If you have ever read a car magazine in the lobby of a Discount tire you would see ads for them. BTW no one called anyone names, and the truth still holds: if you have never heard of Toyo, you shouldn't be managing a tire shop. Now what you said about them meaning they have not having any experiences with that particular Toyo is a different story, and not what you said originally. Toyo is one of the top 10-15 tire manufacturers in the world......
    The Largest Tire Manufacturers in the World (New)
    Yes we are talking tire here and you compared the Ecopias to the Defenders, so it's irrelevant if one is all season and one is winter, which they aren't. Both are all season touring tires, neither are a winter tire.
    Sorry it's not even a question as to if temperature effects mpg, it 100% does. You can read story after story of people with Teslas and other evs cars dying in the cold. It has to do with battery chemistry, especially Li-ion like the new gen 4 Prius uses( except the AWD the used NIMH because it has better cold weather performance). Again I'm not going to keep reiterating over and over again other posts, but it's a proven FACT cold weather drops mpg. I didn't say it absolutely will drop it 30% it can..... Fuel Economy in Cold Weather | Department of Energy.
    So yeah not crazy at all, but less ludicrous then claiming the tires dropped your mpg 20%, when numerous independent testing have shown nowhere near that difference when changing to LRR tires. The average difference was 1-2mpg. Yes it's winter time because your getting winter fuel in the ground starting in Oct by the latest. Unless you logged each trip with the temperature your comparison isn't accurate. If it was 10 deg colder in the trip with the Defenders, that makes a big difference. I have had five different hybrids, and even up sized one car and changed to high performance all season tires and still got the same mpg.
    I've dealt with the same District Manager at Discount tire for 20years, and used to have wholesale accounts with them. I get the maximum discounts and credits possible. The warranty is a pro-rated amount given to you in purchasing a new set of tires and they only give a very minor amount back, nowhere near the difference in having to replace them more than twice as often. Plus as mentioned previously, you have to drive the tires down to 2/32 to claim the warranty. Tires which are already known to have significantly less grip, so I can't imagine them at 2/32. Your tires are literally your direct connection to the road and are what make it go and stop. By your same line of thinking, the Defenders would last even longer. You would get 100k miles or more with them, and would have much better traction. I would personally prefer being able to stop and turn my car properly vs saving a couple mpg, especially in the case where your actually spending more money to do so. If you get four to five years or 40k from the Ecopias your a winner. GL, cheers!
    #9 Drakxyfly, Dec 5, 2023
  10. Dave S Prius
    Dave S Prius New Member
    Northern California
    2018 Prius
    2018 Prius. I got 53000 miles from factory stock Ecopias, probably ran them down a bit more than I should have, but... 55 mpg consistent for 6 years, no matter what mix of city/highway driving. I am careful, but that was a consistent reading. Replacement was required, new set of Ecopia would have been $750 total from WheelWorks. I opted for SureDrive Touring A/S - never heard of them, but decent reviews, with some spot discounts was $371 out the door including tax. IMMEDIATE loss of mpg - feels like I am driving in sand. No change in weather or anything else. Being even more light on the pedal, but now 49 mpg on the first 700 miles on the SureDrive tires. They are otherwise fine for handling/noise. If they last 50,000 miles, it will cost me an extra 100 gallons on the life of the tires, about $400. So, it is a wash monetarily, but it is annoying to lose 12% of mpg. They have a "satisfaction guarantee" I may look into, but if they charge me installation ($100 per set), AND if they will throw away the returned tires, I'll probably suck it up and stick with them. Lesson: Stick with the Ecopias - they seems to get the mpg advertised, and most definitely lasted >50,000 miles. Apart from that, the 2018 Prius has been flawless - I've opened the hood 10 times in 6 years - oil changes and wiper fluid. It is worth more now than when I bought it!
  11. BiomedO1
    3,895
    2,042
    SacTown, Ca
    Welcome;
    Everything's relative, gas prices change. I didn't like my OEM Dunlaps - got more punctures than any other car I've ever owned - considering my car doesn't come with a spare.
    I went with Armstrong BlueTrac 80K mile tires in a heavier load rating. Thicker, heavier tire and same lost of mpg, but $30 less than yours all-in. I should be set for at least 80K, probably 90K miles the way I drive with the higher load rating.
    You may want to add 5psi above your OEM specs to see if the driving in sand feeling goes away. Double check the max. pressure rating on your tire, even the cheapest tires are around 50 psi. If that doesn't work, your probably feeling the extra traction as opposed to the bald tires you were rolling on. That should settle in, in a couple thousand miles and you'll probably get back a mile or two a gallon.
    #11 BiomedO1, Dec 14, 2024
  12. TinyTim
    TinyTim Active Member
    386
    236
    Seattle
    I finally replaced my Toyo A29 original tires. Got just under 50K out of them. I do not recommending pushing those tires quite that far. No complaints about traction on those tires. They are the loudest tires I have ever had. I just put on a set of 55K tires ContinentalProContact TX195 /65 R15 91H SL BSW GM. The Continentals are very quiet tires compared to the Toyo's.
    I got some heavy discounts from Discount Tire plus the $110 Continental rebate.
    iLikeTurtles and ColoradoBoo like this.
  13. AzWxGuy
    AzWxGuy Weather Guy
    1,059
    544
    Tucson, AZ
    2021 Prius
    Just wanted to put in a thumb mostly up for a brand I have never tried. Recommended by my Discount Tire guy, and apparently a large contingent of the Accura NSX Drivers club. Replaced a set of Bridgestones in July, which did not provide the expected mileage, with Falken Pro GS Touring A/S. Break-in time was a little extended, consisting mainly of tracking being a little drifty in crosswinds. They are still a little loose in crosswinds but otherwise track pretty straight in all road conditions. I think the overall impact on MPG was unchanged, but I don't and haven't done a before-and-after tank-by-tank analysis. I just have the MPG running total since vehicle purchase (four years ago) currently stalled out at 55.1 MPG. I run pressures at Toyota recommended 35R/36F. Mosty dry roads too, as it hasn't rained any significant amounts in months.
    vvillovv likes this.
  14. Billy56
    Billy56 Member
    Seattle, WA
    2020 Prius
    L Eco
    First, I have never heard of tire size 195/96/r15 as the thread originator says. My 2020 Prius came with 195/65/15 Bridgestone Ecopia 422+. I always get over 100,000 miles on a set, and average slightly above 80 mpg. Car has over 400k miles now. I always replace with same tires when dealer has buy 3, get 1 free deal.
  15. Mendel Leisk
    41,707
    He likely hasn’t heard of them either, just a typo.
    that’s unreal. Calculated?
    guess it can be done:
    https://www.aftermarketnews.com/prius-world-record/
  16. AzWxGuy
    AzWxGuy Weather Guy
    1,059
    544
    Tucson, AZ
    2021 Prius
    UPDATE: Turns out, the twitchy tracking was some alignment goofiness that has hopefully been corrected with T-SB-0063-20 Steering Wheel Off Center. It fixed the steering wheel centering and tightened up the tracking. These are still only dry road experiences, as it hasn't rained here since November last. No appreciable changes to MPG. I have 16,000 miles on them now.
    Gabe29 likes this.
  17. Optimus
    Optimus Member
    274
    25
    I’ve run a couple Gen3 Prius with the Bridgestone Ecopia EP422 Plus tires. They are an ok general purpose tire, but they absolutely suck in the winter here in MN. We got great mpg in our gen3 with the Evopia, without needing to focus on hypermiling. Our first gen3 got mid 50’s in summer running stock 195/65R15 size and OEM wheels. Our second gen3 got lower 50’s running stock 215/45R17 on OEM 17” package 5 wheels. I attribute the lower mpg of the second car to the heavier tire/wheel combo and extra ground contact. I didn’t care for the 17’s as they also road more harshly, but we ran them anyway since that’s what I had at the time.
    Come winter, I’d easily see a 20% total drop in mpg, both due to it simply being winter, and due to running dedicated snow tires (MUCH softer rubber). What made the Ecopia’s good for fuel economy made them terrible for ice and snow.
    A Gen4 we own right now is running Yokohama Avid Ascend LX. It has done much better in winter conditions, while still getting around 50mpg on our first tank of fuel. I have no plans to switch back to the Ecopias. Having said that, Blizzaks are getting installed shortly for the remainder of this winter season. I expect to see about a 10% drop in fuel economy with the Blizzaks based on my past experience owning two sets of tires (summer/winter) for each car. But, the added traction and safety are well worth the additional hit to fuel economy.
    I’m also adding an OEM spare tire donut package to our Gen4 IV Touring, since Toyota opted to not provide a spare tire on the higher packages. The slight increase in added weight to the car may also have a small negligible effect on mpg too but I value a spare tire more important.
  18. Mendel Leisk
    41,707
    I puzzled over that bone-head move. Best I could come up, the higher levels were heavier, and to keep within some weight category, "something" had to go, and customers be damned.
  19. Optimus
    Optimus Member
    274
    25
    I agree. Luckily, this “upgrade” only cost me maybe $60 at a salvage yard for all the spare tire parts: the tire/wheel itself, the hold-down thumb screw for it, three chunks of foam, two plastic retainers, and I took the scissor jack (so now I have two!).
    I’ve read some older posts here of others doing the same spare tire upgrade but having to buy new parts at the dealer—holy moly the cost!!
    #19 Optimus, Feb 13, 2025
