Cracked Trunk Trim Piece - Not Warranty Covered?
Discussion in 'Gen 5 Prius Main Forum' started by Poseidon, Dec 5, 2023.
  1. Poseidon
    Poseidon New Member
    United States
    2023 Prius
    Hi all,
    A month ago I started noticing a crack on a trim piece on the trunk of my '23 Prius, and later found a few other folks on Reddit that had similar issues. Car was driven normally, but I suspect bumps may have caused that plastic piece to start cracking, which grew over time. I took my car in today for my 10k service, and was surprised to hear that this is not currently covered under warranty, and that (according to my service rep) it would cost 1k USD to fix. The rep did mention they would have their warranty manager reach out to Toyota to see if this is a known issue, but for now, I'm out of luck.
    Does anyone else have the same issue with their '23 Prius, and if so, how has your dealer responded?
    Pics attached below for reference:
  2. BiomedO1
    3,467
    1,800
    SacTown, Ca
    Seems strange that's not covered under the 3 year, 36K mile bumper to bumper warranty. Is the dealership claiming that the damage was intentional or results of contact with another car?
  3. Gokhan
    Gokhan Senior Member
    6,146
    2,431
    Paramount CA
    :eek:
    You not only have a crack but also a hole. It sounds like it is very fragile and easily breaks unless you baby it.
    See the photo below. It looks like very poor engineering design, with that little piece of plastic taking all the tension and shear stress when you open and close the hatch or perhaps even when you go over a bump etc. I would open and close the hatch very gently on a Gen 5 Prius/Prius Prime after seeing this. I doubt Toyota will honor the warranty, but they will probably claim that you slammed the hatch.
    #3 Gokhan, Dec 6, 2023
  4. Poseidon
    Poseidon New Member
    United States
    2023 Prius
    I should have asked, but the rep was friendly and said the warranty manager person was going to check with Toyota, so I did not press any further.
    Yeah, funny thing is I have looked online and I'm not the only one with this issue, which makes me surprised they don't have a service bulletin for this already. Check these guys out:
    :cool::cool:
    Gokhan likes this.
  5. purplePriii
    purplePriii Active Member
    275
    122
    I've seen on a FB group post that someone had it covered under warranty. Unfortunately, the new piece broke while the dealership was installing it.
    There's quite a few people reporting the issue and it is definitely an issue but I feel Toyota will refuse to cover it for as long as they can. That and it looks like the whole part need to be redesigned.
    N79PT, Uhcoustic, Trollbait and 2 others like this.
  6. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    That piece is largely trim, and doesn't seem like it should be subject to any huge force unless the spoiler is pushed. Are all these cars non-powered-hatch ones that might be being pushed from the spoiler? Not that there's any warnings in the manual about doing so, and that manual warns about everything.
    You can see what's under there in picture 5 in this production line gallery:
    写真家・佐藤健寿、プリウス工場を撮る | フォトギャラリー | プリウスジャーナル | トヨタ自動車WEBサイト
    There has been a production change there, visible in the manuals. A strip of rubber (or something) was placed between the bottom lip of the plastic and the metalwork starting from 05/2023, according to the parts catalogue: 87B68 = 87268-47050 PROTECTOR.
    Actually looks like it has a detailed shape, not just a simple strip of rubber. But it's not shown in the assembly/disassembly in the repair manuals - presumably not updated? I can clearly see it on my car, tightly in the gap.
    That could be connected in some way. Was it a water seal that might be increasing stress, or was it an attempt to prevent movement to reduce stress?
    #6 KMO, Dec 6, 2023
    GeoJ and AndersOne like this.
  7. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    It could simply be a manufacturing defect. The only way I can think of it cracking like that is thru some external force of putting pressure on it like sitting on the hatch etc. Hope they cover it for you.
  8. Mendel Leisk
    41,301
    I wouldn't take his word as gospel. Check with Toyota USA yourself?
  9. Gourockian
    Gourockian Junior Member
    63
    22
    New Port Richey
    I don't know if this is releveant but when I upgraded from my 2008 gen 2 to my current 2013 gen 3, I noticed a drop off in the quality of some of the internal rear trim parts and also the trunk roller blind. Anything to reduce weight but also cost to the manufacturer.
    Gokhan likes this.
  10. Gokhan
    6,146
    2,431
    Paramount CA
    I think you are onto something. Gen 2 was iconic.
    Gen 5 doesn't even have a telescopic retracting hatch blind like Gen 4 did. They put an incredibly cheap cover flap that seems to get in the way of everything. That is in addition to the smaller trunk.
    Cruzctrl1 and KMO like this.
  11. otatrant
    otatrant Active Member
    320
    194
    San Francisco
    2023 Prius Prime
    XSE Premium
    For reference here is the part number (based on 10 minutes of searching) you can use to price what it would cost out of pocket to buy the replacement part.
    Here is a link for a listing with pics of the part on aucfree.com
    Lens And Body, Lamp. Tail Lamp. (Rear) $375
    81581-47080
    This second price is from the impex japan site. Have not purchased from them myself but others have and reported positive experiences. Takes some time to ship and shippin not included in price I understand.
    Lens And Body, Lamp. Tail Lamp. (Rear) $147
    Poseidon and Gokhan like this.
  12. Gokhan
    6,146
    2,431
    Paramount CA
    Shipping cost from Japan will be very high.
    You can negotiate the part price with the dealer. The cost to dealer is far below MSRP.
    Perhaps upgrade to a light bar if you have an LE/SE while you are at it.
    otatrant likes this.
  13. otatrant
    320
    194
    San Francisco
    2023 Prius Prime
    XSE Premium
    The cost lohikaarme paid to ship a spoiler looks like just $25 which would be similar width. I would check out his post and the rest of his thread on this topic if saving a potentially a $100 or so is a big deal to you.
  14. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    Call Toyota Corp until they get so tired of you they do something about it. Provide all the documentation you are finding online including photos. I can see maybe the first reporting being considered owner negligence but multiple reports is obviously a manufacture defect. There’s always small claims court too. Good luck!
  15. Gokhan
    6,146
    2,431
    Paramount CA
    That's a good deal. When I used to order US-discontinued parts from Amayama, shipping costs were astronomical.
    My car is new now, and hopefully there won't be need for any parts other than filters.
  16. Poseidon
    Poseidon New Member
    United States
    2023 Prius
    Yeah I am not overly in a hurry to replace this piece, which I understand to be mostly cosmetic anyway. Going back to the dealership in 3 weeks for my second key fob, so I will see if they have an update for me then. I'll also ask for details as to why this is a "customer-paid" repair, since I agree with you all, it seems like a manufacturing defect.
    Trunk has not been slammed either, I prefer putting my groceries in the backseats anyway haha
  17. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    You need to ask the service manager to open a case for you. Show them all the other Prii with the same issue. This is the first step.
    Kenny94945 and otatrant like this.
  18. Preebee
    867
    771
    Midwest
    2023 Prius
    *sigh* :rolleyes:
    The cargo cover on the 2023 Prius is actually an ingenious design, easily folding in half when you don't need it. It's been lauded by testers. And it's not cheap.
  19. Mendel Leisk
    41,301
    That goes without saying?
    Pdog808 and Preebee like this.
  20. Gokhan
    6,146
    2,431
    Paramount CA
    Well, mine automatically folds into a quasi-one-dimensional tube when you don't need it. ;)
    #20 Gokhan, Dec 7, 2023
