First Oil Change
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Blackat, Nov 4, 2023.
  1. Blackat
    Blackat Member
    264
    174
    Colorado
    2023 Prius
    Limited AWD-e
    Did the 1st oil change today myself at 4600 miles. Dealer said free one is at 10K, too long an interval for me
    Pretty easy. 30 min
  2. planetarian
    planetarian Member
    75
    73
    Kentucky
    2023 Prius
    XLE AWD-e
    That's weird; i had mine done today and the dealer explicitly referred to it as the 5k service (despite my car being closer to 7k), and I didn't have to pay for it.
  3. vvillovv
    vvillovv Senior Member
    3,614
    1,272
    NY
    My 2014 PiP had milkshake crankcase syndrome at 5K service and it wasn't changed. I got the cartridge housing removal tool and did the oil change myself with valvoline 0-20 synth that was so clear (back in those days) it was impossible to see the oil level on the dip stick without a magnifying glass and bright light.
    After the first oil change I never had another issue with the oil.
  4. Trollbait
    11,510
    The 2 year service package Toyota provides follows the standard service schedule in the warranty manual. That's tire rotation and inspections every 5000 miles and the oil change every 10k, or whatever time interval they list. It works out as covering two oil changes.
    Assuming you asked for an oil change, the dealer used your 10k mile oil change credit to cover it.
  5. Blackat
    Blackat Member
    264
    174
    Colorado
    2023 Prius
    Limited AWD-e
    Also, my time is valuable and I can do the oil/filter change in 30 min. with checking all fluids etc.
    Tire rotation is free at my local shop 3/4 mile away.
  6. Mendel Leisk
    38,651
    Are you using AI?
    douglasjre, vvillovv and Sedril like this.
  7. KMO
    KMO Senior Member
    1,513
    394
    Finland
    2023 Prius Prime
    Seems to be a bot of some sort. About half the posts are just effectively rewriting the post being replied to, as a sort of "me too", not even attempting to be a response.
    vvillovv likes this.
  8. GuardianGrayHalcón
    GuardianGrayHalcón New Member
    Las Vegas
    2024 Prius
    Limited AWD-e
    I was wondering if you could share which oil, oil filter and drain washer you used. I'm trying to cross reference part #'s and some of the online databases are not up to date. Thanks, Michael
  9. Blackat
    Blackat Member
    264
    174
    Colorado
    2023 Prius
    Limited AWD-e
    I used Mobil 1 0w-16, reused the original drain washer(they last thru many oil changes)YMMV, got the filter from the dealer #90915-YZZF1
    Pretty easy DIY with a floor jack
  10. TinyTim
    TinyTim Active Member
    366
    224
    Seattle
    Why would anybody do their oil changes on a new Prius? The deal takes care of everything for the first 2 years. The first oil change is 5k and after that 10k. Unless things have changed since the 4th generation.
  11. Blackat
    Blackat Member
    264
    174
    Colorado
    2023 Prius
    Limited AWD-e
    The first free one is 10k, I tried to set up the first OC at 4100 miles and they said nope.
    I'm a mechanic and my time is more valuable and I can do a better job than the dealership anyway
    It's an all morning adventure to take it to the dealer for an oil change. I can do it in 30 min with all the inspection pts as well.
    YMMV
    douglasjre and vvillovv like this.
  12. Doug McC
    Doug McC Active Member
    997
    374
    Midwest
    2022 Prius
    On my ‘22 Gen 4 the first dealership oil is is 1 year or 10,000 miles, the second is 12 months later or 10,000 miles.
    Blackat likes this.
  13. Mendel Leisk
    38,651
    If you walk up to dealership parts department they’ll sort all that out.
    GuardianGrayHalcón likes this.
  14. GuardianGrayHalcón
    Las Vegas
    2024 Prius
    Limited AWD-e
    I usually buy online as the dealerships here in Las Vegas mark parts prices well over Factory MSRP.
  15. Ronnie5
    Ronnie5 Member
    47
    48
    2023 Prius
    I believe the correct oil filter for the 2023 Prius is 90915-YZZN1
  16. Blackat
    Blackat Member
    264
    174
    Colorado
    2023 Prius
    Limited AWD-e
    Yeah. That’s right. Was going by memory, my bad
  17. Blackat
    Blackat Member
    264
    174
    Colorado
    2023 Prius
    Limited AWD-e
    I got the wrong number for the oil filter. The correct one is on another post
  18. Mendel Leisk
    38,651
    That's same as gen 2 and 4, and 3 if you do the conversion.
  19. rep308
    rep308 Junior Member
    71
    suburbs of Boston
    I always do the first change at 700 miles, next at 2000 and 5K from then on. That's maybe an extra $250 to extend the life of a $35,000 car. I do my own. If you are not as crazy as I am, just do them every 5K and please do not wait until 10K for your first change.
    ColoradoBoo likes this.
  20. ColoradoBoo
    ColoradoBoo Senior Member
    952
    626
    Monument, Colorado USA
    I'm with you...many believe the new engines are pre-broken in at the factory, not true. Many years ago, they would put special "break in" oil that would help with the process but not anymore...so doing a couple early oil changes is smart. (First should be anywhere from 500-750 miles) then every 5,000 (or 6-months if you don't drive much.)
    Seeing how others neglect their vehicles has made me ONLY want to buy cars new....why put a ton of money in a used vehicle that is on the verge of major drivetrain issues?
    rep308 likes this.
