P3000 and P0A80 pulled from dr Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bryanesk, Dec 12, 2023.
  1. Bryanesk
    Bryanesk Junior Member
    44
    San Bernardino
    Have a 2005 Prius 200k miles with a refurbished battery been looking around here and seeing that the battery should be sitting around 17+ voltage this is what I read this morning only turned it in for about 1 min to read does this mean imma neeed to replace the entire pack soon?
  2. PriusCamper
    PriusCamper Senior Member
    13,273
    5,361
    Pacific Northwest, USA
    Your "volt diff" number is too high and indicates you have a bad module that needs to be replaced, likely in block 9...
  3. Bryanesk
    44
    San Bernardino
    How would I determine which module In block 9 is faulty
  4. PriusCamper
    13,273
    5,361
    If you have halogen headlights, you can attach that 12v 55w bulb to a module and record the voltage loss at the 2 minute mark. A healthy module will drop between 0.4v and 0.2v.
    As for high quality replacement module that match well, this guy is a professor who teach hybrid and EVs at his local college and always sells good stuff: Hybrid Car Battery Distributor | Contact Us | 2nd Life Battery
  5. Bryanesk
    44
    San Bernardino
    What about a normal multimeter?
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    With the voltage difference you have, I would say it's going to be pretty obvious just using a multimeter. Should be easy to find that one, it's the other two or three weak ones that may slip by.
  7. Bryanesk
    44
    San Bernardino
    What do you mean other two or three are you seeing other blocks that are weak aswell?
  8. PriusCamper
    13,273
    5,361
    He means that as a battery pack ages each module starts to fail at a different rate. In general, people get the luckiest on the very first module they replace. @TMR-JWAP for example got over a year the first time he replaced a module.
    But as the years go buy you'll find yourself replacing another module, then another, which isn't too bad if that's what your budget allows.
    However, if you want to do an in depth level of testing and reconditioning your pack, the people who learn to do this job can rebuild a pack that will have no issues for at least three years.
    Or if your budget allows for it you can buy a brand new OEM pack for $2K and forget about the pack for another decade, as well as use that pack in your next Prius.
    Alternatively you can buy a Lithium upgrade pack for about the same price and enjoy all that extra amps to boost MPG, mountain climbing, max AC on hottest days, etc.. The business who sell these packs lives in your area too, so you'll save a hundred bucks on shipping. And if you use my affiliate link I'll give you unlimited tech support: www.projectlithium.com/?ref=9qLPw You also can sell your old pack to a recycler Like Hybrid Pit for $200.
  9. Bryanesk
    44
    San Bernardino
    Yea I had a module replaced and lasted me almost 2 years guess time finally catching up I scanned the code with Techstream and I gave me p3000-123 any info on what this code means is appreciated
  10. dolj
    dolj Senior Member
    8,620
    4,375
    Wellington, New Zealand
    DTC Detection Condition
    Abnormal signal input from battery ECU (HV battery system malfunction)
    Trouble Areas
    • HV battery system
    • Battery ECU
    This is a very general code that really means the hybrid vehicle (HV) battery system is malfunctioning.
    There should be other codes, if not now, coming along very soon.
  11. Brian1954
    Brian1954 Senior Member
    2,524
    1,006
    South Central PA, USA
    Let me add to what you already posted.
    The other code is the P0A80 which the OP has listed.
  12. Bryanesk
    44
    San Bernardino
    so is it just because the battery needs to be replaced or am I gonna have to replace the ECU itself as well pretty soon here
  13. ChapmanF
    18,798
    The English translation of the P3000 detection condition does seem like you could read it more than one way. "Abnormal signal input from battery ECU (HV battery system malfunction)" might sound like there was something abnormal about the signaling from the battery ECU, as if something's wrong with the battery ECU.
    But it doesn't mean that; it just means that the battery ECU sent a signal (just the way it's supposed to) about something being abnormal back there.
    So, in this case, the battery ECU decided that the battery is at EoL and said "yo, battery at EoL back here, P0A80", and that's the 'signal' that the HV control ECU got, so now it's saying "yo, I got a signal about a battery issue so I'm saying P3000."
    Of course, sometimes there can be issues with the battery ECU and it should get a good looking at while dealing with the battery. But the P3000 by itself isn't telling you there's a problem there.
  14. Bryanesk
    44
    San Bernardino
    Aaaah okay I see yea techstream gave me that block 9 is weak gonan replace to module and see how it goes for me
  15. PriusCamper
    13,273
    5,361
    You'll want to open up the ECU and check inside for corrosion of the pins where voltage sensor harness plugs in. The common problem of sudden drops in charge on your display screen is caused when this corrosion gets thick enough and starts micro-arcing between pins.
