Gen 2 key fob remote case replacement - particular details
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 1000uf, Aug 21, 2023.
  1. 1000uf
    1000uf Junior Member
    Italy
    I had bought an used 2007 (second generation) Prius, one of its key fob case was really worn out. I bought a new shell to replace it, but then it wouldn't start the car no matter what. I actually thought it may be the battery and put new ones in and had no success. I was going out of my mind. Finally, I found that I had left the transmitter chip in the old case. Thank goodness I didn't throw it out!
    To help others with a step-by-step guide, I made a video with a complete dissection of the remote key controller for Toyota Prius second generation. Enable/disable smart proximity no-contact start/stop; changing key case; understanding how to start the car even without the remote circuit; locating the transmitter chip for starting the car.
    CPate2020, elliot333 and bisco like this.
    52,386
    well done, thank you!
  3. Pioneerscot
    Pioneerscot Junior Member
    78
    Nevada
    Did you happen to have a link to that case, mine is all peeled back at the buttons ? TU in advance
  4. elliot333
    elliot333 Junior Member
    Virginia, USA
    Super helpful, thank you!
