2005 Prius almost 200k miles metal shavings in oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bryanesk, Dec 14, 2023.
  1. Bryanesk
    Bryanesk Junior Member
    44
    San Bernardino
    Hey so I found some metal shavings in my transmission oil while changing it am I pretty screwed or am I gonan be alright I heard that the Prius transmission isn’t the same as a normal car so it can’t slip but currently fixing my hybrid battery but if my transmission is gonna go out soon is it even worth it. Any advice is great thanks
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    If this is the first time the transaxle fluid has been changed, a little bit of sparkly goop on the magnet is normal.
    Anyway, put in fresh WS and roll onward! Go or blow, it'll end up costing the same!
  3. Bryanesk
    44
    San Bernardino
    Gonna say the 2nd time the fluid still looked pretty red but put in ATF WS and hoping for the best think it was last changed at 150,000
  4. Mendel Leisk
    41,385
    With any past cars we've had, all conventional automatic transmissions, they've had a magnetic drain bolt, and it invariably had a "paste" clinging to it, kinda black, kinda silvery. No chips or shavings, just this super-fine stuff. That's normal I think.
  5. Bryanesk
    44
    San Bernardino
    There was maybe a little bit of chunks but nothing big when I took out the oil it was barely barely shiny if I were to shine it in the sun at the right angle maybe from the first time it was replaced?
  6. BiomedO1
    3,550
    1,840
    SacTown, Ca
    Worse case, it should be really easy to find a used, since they're pretty much trouble free.
  7. Tombukt2
    12,924
    2,322
    It's a generation 2 you're fine everything is a okay It is normal to see silver specs in the transmission fluid there's also aluminum involved that's not magnetic no biggie most people never get around to changing the mess until 200,000 so after they buy the car new dealer prepping install or PDI and then run through warranty most people did that It might have been changed at 60,000 by the dealer and then most people ran that right on out to 200 K I say most people maybe not folks PC. But many did without any problems matter of fact it's pretty rare you really read about a transmission having problems even the motor generators in the transmission It's extremely rare look how many times it's happened here on Prius chat not very many so just keep getting it a transmission for one of these things somebody will charge you $250 to swap it out and you'll buy one for near nothing they're plenty of available they're all over the place like $200 I'm talking.
