Featured Why repairing your BEV is so expensive—WSJ
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Dec 4, 2023.
  1. hill
    8,799
    Leave it to gokhan to search for antiquated undocumented articles to his inventory of negativity.
    Notice the read doesn't say how fast a fast charge they used? Nor do they disclose whether or not the charge was tapered?
    They probably skewed their results to prove a point by not tapering their charge rate once charge was above 70% full .... so duuh - many people already know this - but maybe not back when this was published as it WAS ~4 years ago when this article came out - Many readers were ignorant of cell chemistry dynamics which would appear informative to the unlearned.
    #41 hill, Dec 11, 2023
    3PriusMike, austingreen and bisco like this.
  2. Gokhan
    Gokhan Senior Member
    6,184
    2,442
    Paramount CA
    It was a peer-reviewed article published in a top scientific journal:
    https://onlinelibrary.wiley.com/doi/abs/10.1002/est2.141
    In fact, the claim of the article was that Tesla superchargers were not employing optimal charging schemes, which was lowering the cycle life, and they recommended better charging schemes.
    DC fast charging is only a charging method, and it doesn't specify the C-rate. As I said, C-rate greatly affects cycle life, and the difference between 1C and 4C, while both are fast charging, can be day and night.
    I don't think nowadays every Tesla driver knows their battery chemistry, architecture, and manufacturer as well as about charging profiles, strategies, and C-rates.
    #42 Gokhan, Dec 11, 2023
  3. Gokhan
    6,184
    2,442
    Paramount CA
    :rolleyes:
  4. Gokhan
    6,184
    2,442
    Paramount CA
    Again, there is DC fast charging, and there is DC fast charging.
    It looks like most of the time, you are not even at 1C-rate when you are at a Tesla Supercharger. I would not even consider that as fast-charging. Cycle-life degradation starts increasing rapidly after a certain C-rate. 2C could be very hard on the battery. These days many manufacturers, especially Koreans, are pushing or claiming close to 4C (15 minutes) in their new models, which could be very hard on the battery. You can see greatly reduced cycle life if you do regular 4C charging. This is why Toyota limits DC fast charging rates on bZ4X, as it is very conservative.
    #44 Gokhan, Dec 11, 2023
  5. Tideland Prius
    16,553
    Toyota expects the lifespan of their hybrids to be about 15 years.
    And their hybrids and PHEVs now are warranted to 150,000 miles right? (240,000km). The bZ4X is only 100,000 miles (160,000km).
    Plus a battery on a Prius is much cheaper than a Prime or BEV.
    Battery manufacturers do need to start producing spare batteries for repairs. Right now, I’m guessing it’s all for production given the supply chain constraints. If demand is supposedly down, that’ll give a chance for part suppliers to catch up.
    3C.
    Yes it could be. I will say the cooling system is quite good. The limit is 50°C or thereabouts before thermal throttling. Quite high. So I wonder if their chemistry is a bit more heat resistant than others?
    Plus with 800V, it’ll take a little bit longer to heat up given the lower amperage going through the wires.
    Gokhan likes this.
  6. hill
    8,799
    Superchargers are running 250kW now. Oh - that's right. In defense of that wacky linked article - you're now claiming tesla isn't really supercharging ... and yet V4 is even higher than 250V. That antiquated & nonsensical article was written even before many fast charging equipment was even in operation. Ironically - defending these charlatans by claiming they weren't talking about superchargers makes no sense. Supercharging was way less powerful years ago - so you can't now come to their defense claiming they were talking about higher wattage when it didn't exist back then. so sorry .....
    3PriusMike likes this.
  7. sylvaing
    sylvaing Senior Member
    1,210
    514
    This is my 16 minutes supercharging session time last month according to Teslamate. I charged my NCA Lithium battery from 11% to 60% during that 16 minutes. Just before my session was about to end, as you can see in the popup over the graph, I was still at over 1C (battery is 56kWh). About half way through the charging session, I was still at about 2C.
    But I do think the Korean are pushing it a bit far and it will be interesting to see in five years how their battery will be holding up.
    Gokhan likes this.
  8. Isaac Zachary
    Isaac Zachary Senior Member
    2,541
    1,280
    Ok, so hybrid batteries are warrantied to 150,000 miles on new Toyotas.
    Coincidentally I just hit 150,000 miles in my Avalon hybrid with no idea what an OEM battery will cost when this one goes out.
    I haven't tested and recorded how my car is acting, but sometimes I feel like the engine kicks on a lot more often than it used to, and that's making me a bit nervious about the battery's health.
    Tideland Prius likes this.
  9. hill
    8,799
    Nor do most people generally know what it would cost if the ICE goes out.
  10. Isaac Zachary
    2,541
    1,280
    I would say this:
    1. Engines have a long track record of how long they can last and what makes them last. I had a car that I bought with over 300,000 miles on it, the odometer broke, but on paper I was doing over 30,000 miles a year, and I owned that car for 7 years and the engine still ran fine when I sold it. My secret: I changed the oil often. How do I get +500,000 miles out of a BEV battery?
    2. Just a quick search gets me a less than 40,000 mile JDM engine that I can swap into my Prius for under $1,500. Will we ever see that kind of pricing with BEV batteries?
  11. bisco
    51,892
    99% of the driving public doesn't care what you or i can do, nor do any governments or manufacturers
    Isaac Zachary likes this.
  12. Trollbait
    12,518
    If a battery replacement is required in a BEV, it will likely be more than a replacement engine. It's why they cost more to buy. For most people, the difference in fuel cost will result in overall costs being about the same.
  13. bwilson4web
    16,201
    Is the cost trend on replacement ICE engines going down like batteries?
    Which saves more money: LFP batteries instead of NMC or; $7500 subsidy? We really won't know until the Q1 2024 numbers come in.
  14. Isaac Zachary
    2,541
    1,280
    Looking at Edmunds' 5-year TCO with my zip code on 2023 models:
    • Toyota Corolla Hybrid LE: $34,707
    • Cheverolet Bolt LT1: $41,083
    • Tesla Model 3 RWD: $58,491
    Have replacement batteries actually come down in price? One main reason I sold my Leaf was the replacement battery went up from $5K to $8K. There are also no JDM batteries that I know of.
    My question is which will last longer? LFP has more cycles than NMC. But the lower capacity of LFP means they'll be cycled more than NMC over the life of the vehicle.
    In a way I'm kind of glad that the $7,500 is going away. I mean, yes, I'd love to get an EV with the $7,500 federal tax credit along with Colorado's $7,500 tax credit (starting January first) both combined. But trying to find a cheap EV that can actually make such incentives make the car affordable for me seems impossible. That, and I'm still not sure if I'd qualify. I'd rather have the price up front, "This is exactly what it will cost," than this guessing game and illusion that BEV's are obtainable.
  15. Gokhan
    6,184
    2,442
    Paramount CA
    The long-range Model 3 has about 30% more range. LFP in theory perhaps cycles twice more. However, perhaps Tesla is harder on the LFP batteries, like charging them faster to higher SOC etc. So, probably LFP still lasts longer, but the real-life answer may be different.
    I was surprised that the standard-range Model 3 can only go for 272 miles—not enough for a trip from LA to Vegas. So, I don't think BEVs will be ready for prime time for another ten years or so.
    I am impressed with the quality of Panasonic prismatic cells in my 2021 Prius Prime Limited. I left the car undriven for over six weeks at 25% SOC and there was no change in SOC. Tesla says that their battery SOC drops 1% everyday when undriven. Moreover, I doubt I have experienced any capacity loss. Today, I averaged 7.0 mi/kWh in city driving in unusually warm weather for fall, which is about 42 miles of BEV driving on a full charge—70% higher than the EPA estimate. Gen 4 Prius Prime truly rules in terms of fuel efficiency and build quality. Most importantly, you have the gas tank for long trips, which you can easily do at 65 mpg—costing about the same as or possibly cheaper than BEV driving.
    #55 Gokhan, Dec 16, 2023
  16. El Dobro
    El Dobro A Member
    7,088
    3,270
    So, where are all these battery replacements for EVs going on?
    Trollbait and bwilson4web like this.
  17. bwilson4web
    16,201
    I’ve got shovel and would dig them out of a landfill.
  18. hill
    8,799
    perhaps the small battery size prevents you from seeing an amount of parasitic loss - because ALL batteries of that chemistry have some parasitic loss. To claim otherwise is disingenuous. If you had a hundred kwh battery instead, parasitic loss is of course more noticeable.
    is that really so astounding? You DO realize that the battery use is much higher what with its Sentry mode and numerous other online capabilities. So of course the Prius not having those features doesn't have that kind of drain.
    iirc - many of Tesla's electrical usages can be toned down for long-term storage if that's important.
    That's really graceful for you to worry so much about Tesla battery longevity
    Here's an example of longevity from another site;
    - 239,000 miles on the original battery pack .....
    - Original range - 256 miles
    - well worn range - 240 miles
    Highest mileage with original battery | Tesla Motors Club
    #58 hill, Dec 16, 2023
  19. Isaac Zachary
    2,541
    1,280
    I survived a year in a BEV with a 15% degraded battery from an original 84 mile range, so to me 272 miles would be more than enough.
    Yes, there are multiple benefits in having a PHEV like a Prius Prime, which is why I tried to get one when I sold the Nissan Leaf. But ultimately I got the Avalon Hybrid because the Prime was out of my price range (and it only seated 4 at the time too).
  20. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Isaac, The difference in capacity is not a large percentage, but the number of cycles is a factor of 5 to ten so LFP wins here. Besides, LFP has almost a zero risk of a battery fire.
    JeffD
