Mirror proximity warning light issue
Discussion in 'Gen 5 Prius Main Forum' started by Gunslingerheel, Dec 15, 2023.
  1. Gunslingerheel
    Gunslingerheel Junior Member
    32
    Raleigh, NC
    2023 Prius
    I was just reading the thread about the rear trim cracking on a 23 Prius and the dealer refusing to repair it under warranty so I thought I would ask this. We have a 2023 Prius and with 5,000 miles on it, my wife noticed that the proximity warning light on the driver's outside rearview mirror was shining out from under the mirror instead of from the icon on the mirror. The bulb has clearly fallen out of its holder. It is on the backside of the mirror and can't be seen. We took it to the dealer and he said it had been hit and damaged therefore was our responsibility at a cost of about $350. There is not one mark on this mirror. The service representative actually pointed out two bugs that were stuck on the outside of the mirror and said that was what caused the problem. I removed them with one swipe of my finger. I have looked at it and had others to see if I was missing something but everyone says there is nothing. I asked the wife if she had returned to the car in the parking lot and the mirror was folded in as if someone had hit it walking by and she said no. She also said nothing of significance had hit it while she was riding down the road. Has anyone else experienced this? Does anyone know of somewhere I can find to access the back of the mirror like a yt video? Thanks in advance for any help.
  2. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Has happened to others. Was a thread on this some time back. See: Blind spot warning LED "fell off" back of mirror | PriusChat
  3. Hammersmith
    Hammersmith Senior Member
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Super easy to get at. Get yourself either a nylon trim removal tool or something else with a tiny bit of give(so you don't mar any plastic like you could with something metal). You'll also need a small flat tip screwdriver or something like it.
    You don't need to remove the mirror cover, you need to remove the mirror glass. Stick your removal tool under one of the bottom corners of the mirror glass and pry up(away from the mirror housing) with considerable force. It's going to feel like you're going to break it, but it can take it. Once one bottom corner pops free, move to the other bottom corner and repeat. Then the two top corners. Don't pull the mirror away from the housing yet, since there's one more wire harness attached.
    Once the mirror is free and you've got a little play to work with, it's time to remove the heated mirror connector. It's thin and rectangular, so put the tip of your screwdriver under one end and twist or pry upwards. You'll feel a little pop when that side frees itself. Repeat on the other side and the connector will release easily. Remove the mirror glass for a moment.
    Now find the BSM lamp housing that should be just hanging down. There'll be a rubber plug around the wires to keep moisture out. Work that backward for a bit to reveal the connector. Use your screwdriver to push in the tab and pull the connector free. Now take your lamp housing and reattach it to the mirror. I can't guarantee how long it will last, but you can start by just re-sticking it to the same spot. If it doesn't stick very long before falling off again, you could try cleaning both surfaces carefully with something like isopropyl alcohol or GooGone and using a piece of weather resistant, transparent, double-sided tape to stick the lamp back to the mirror. The lamp self-centers in its opening, so don't worry about that.
    Now put it all back together again. Start with the BSM lamp harness because it's the trickiest. Push the connector in until it locks and slide in the rubber plug. Now plug the heater connector back in. It's a little fiddly since you don't have much space to work with, but not terribly difficult. Finally, center the mirror glass and push each corner in HARD until your hear and feel a strong click. Repeat on each corner. If you can't get the first corner to click, try another one; eventually one will work and the rest will go quick after that.
    If I've done everything correctly, there should be photos below this showing some of the process.
    #3 Hammersmith, Dec 15, 2023
    GcinFl, otatrant, Jabog6 and 2 others like this.
  4. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    This is NOT something a new car owner should be required to do themselves lol. I would blast the service center until they relented - all the way up to the GM.
    If you break something while DIYing......
  5. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, if all they were doing was re-sticking and not putting on new adhesive, it shouldn't take a tech more than 5min to fix. To do it properly would involve ordering a new mirror glass($130 MSRP) and the same 5min of labor.
    I just showed how to do it if they wanted to because I've torn apart and rebuild my mirrors about 10 times over the last couple months, and I had all the needed spare parts within reach from my chair. lol
    otatrant and Preebee like this.
  6. Gokhan
    Gokhan Senior Member
    6,467
    2,581
    Paramount CA
    Don't attempt to repair parts that are still under warranty. Have the dealer do it for free and without time wasted on your end.
  7. Mendel Leisk
    41,808
    If escalating doesn't help, try another dealership, and cut-and-paste your initial post in an email to Toyota USA; those jokers are just giving you the brush-off.
    GcinFl and HacksawMark like this.
  8. Tom_06
    609
    142
    Especially with the example of the other owner that had the problem and that person's dealer just went ahead and fixed it.
  9. Gunslingerheel
    32
    Raleigh, NC
    2023 Prius
    I am open to any suggestion to get the dealer to fix it under warranty as they have already refused.
  10. Gunslingerheel
    32
    Raleigh, NC
    2023 Prius
  11. Gunslingerheel
    32
    Raleigh, NC
    2023 Prius
    OK that is incredibly awesome help. It begs the question how do you know this? Has this happened to you? Thank you by the way.
  12. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    My suggestions are speaking with the general manager of the dealership and/or trying another dealer. Also consider filing a complaint with the NHTSA.
  13. Trollbait
    12,652
    Can also try Toyota corporate.
    HacksawMark likes this.
  14. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm currently in the middle of a project to add turn signals and power retracting motors to my mirrors(using Japanese OEM parts). I've had my mirrors apart half a dozen times as I've learned about what I needed, what worked, and what didn't work. I've got a thread in the accessories and mods sub-forum about my "adventure". (Speaking of which, I need to finish my next post about the advanced wiring.)
    I will say that I did knock off the BSM light the very first time I disassembled the driver's mirror. I just stuck it back on and it hasn't fallen off yet(>4 months). I would agree with the others that it's best to first try pushing a dealer into fixing it, but I gave you the info because you said you had tried that already and you might not have a second dealership option depending on where you live. Also, it's a 10 min fix, so you have to balance how much your time is worth fighting the dealership, getting an appointment, getting the vehicle there, waiting an hour or more for them to fix it, driving home, etc. You could end up wasting many hours of your time to have something fixed that could take 10 min to do yourself in your garage/driveway with no supplies other than a trim tool that you might already have. Both choices are valid, it's just up to you.
    Tom_06 likes this.
  15. GGD
    GGD Junior Member
    31
    46
    2023 Prius
    I'm the one who had the same problem (passenger side mirror) here's what I remember about the dealer interaction.
    When I dropped it off for the 10K mile service I told them about it and that I could still see the glow around the edges of the mirror but it looked like it detached from the back of the mirror.
    They said they would investigate, but also wrote up the initial estimate at $245 which they said was to cover diagnosing in case it wasn't a warranty issue, they did the same thing when the 12V battery needed replacement under warranty. It's a CYA process, and one thing they mentioned both times was "rodent damage" as a cause that would be outside of the warranty. When the car was ready, there was no BS or negotiation, they covered it, and they also explained what they found, that it was held in place by double sided tape, and "fell off". That really surprised me and seems like a design issue, I'm pretty used to EVERYTHING on a car snapping or locking into place. They also said that if it happens again just bring it back, as if they too had some doubts about the reliability of it staying in place.
    I don't know if they use the same mirror parts on other models or if it's a new design for 2023, and wonder if the LED might get knocked loose through normal usage when folding and unfolding the mirror. There's a pretty strong whack to the enclosure when it locks into it's unfolded position.
    I was going to upload a scan of the paperwork but uploads don't seem to be working. So here's what they wrote.
    CUSTOMER REPORTS RIGHT SIDE MIRROR BLIND SPOT DOES NOT ILLUMINATE.
    PLEASE INSPECT AND ADVISE.
    CAUSE:
    120 ENGINE MECHANICAL
    127 WT93 (N/C)
    10172 CHECKED FOR RIGHT SIDE BLIND SPOT MONITOR LIGHT ON SIDE
    MIRROR IS NOT LIGHTING UP. CONFIRMED COMPLAINT. CHECKED FOR CODES NO
    CODES SET AT THIS TIME. INSPECTED MIRROR ASSEMBLY AND FOUND THAT THE
    LED WAS NOT ATTACHED TO THE GLASS BUT IS WORKING. ATTACHED LET TO GLASS
    ASSEMBLY AND RECHECKED. NOW ILLUMINATING AT THIS TIME.
  16. Gunslingerheel
    32
    Raleigh, NC
    2023 Prius
    GcinFl likes this.
  17. Gunslingerheel
    32
    Raleigh, NC
    2023 Prius
    Thank you. Our mirrors are never folded by us. Now the car is in a parking lot four days a week and we have no control over that. If that is all it takes then there is a really questionable practice Toyota has there.
  18. Gunslingerheel
    32
    Raleigh, NC
    2023 Prius
    Are you a mechanic or were you one in another life? I was and I am not sure I could figure all this out without the huge possibility of damage. Thanks again.
  19. Gunslingerheel
    32
    Raleigh, NC
    2023 Prius
    The dealership sent out one of those "How was your visit" letters to which I responded with all of this. I haven't heard back from them which is really disappointing. I just requested to speak to someone up the chain and we will see what happens. If that doesn't work Toyota here I come. The dealership happened to have this car when we went to buy it. You could not find one and I was fortunate to get this one as we needed a car. They did not upcharge the car at all and I have sung their praises to high heaven but the fact that their service writer who was looking at the same thing I was would look me in the face and say it was damaged loses all trust from me.
    GcinFl and Mendel Leisk like this.
  20. Mendel Leisk
    41,808
    I would guess they don't give a damn about repeat business.
