2010 Prius Overheating
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Newman42, Dec 15, 2023.
  1. Newman42
    Newman42 New Member
    Dothan, AL, USA
    Hi all,
    Tl;dr Prius over heating: After changing temperature sensor and thermostat still overheating. Middle and lower radiator hose barely warm (small from reservoir to radiator and big one at the bottom, respectively) compared to very hot top hose (radiator to reservoir).
    Whole history since I got the Prius in 2019: Replaced water pump last year and ran for a year fine. Two months back cylinder 1 misfire. I replace all spark plugs and ignition coils. A month later, it is due for an oil change so I change the PCV valve while I'm under there. Started overheating, Temperature light is intermittent and eventually throws a p0117 temperature sensor error. I change that out. Heater won't work and still overheating so I change the thermostat. Old thermostat looks like the gasket expanded. I flush the coolant and do all the burping/bleed valve stuff I've found on these forums and backflush the heater core. Still overheats. Middle and lower radiator hose barely warm (small from reservoir to radiator and big one at the bottom, respectively) compared to very hot top hose (radiator to reservoir). Changed the radiator cap as well. Cleaned the EGR valve while I was at it too.
    As I run it in maintenance mode, fans turn on and coolant goes from top hose to reservoir but seems to get stuck there. It starts to fill the funnel the first few times, and the last time pushed coolant through the reservoir cap (tried it closed). Could I have a bad thermostat (from Autozone)? Could the bad thermostat have ruined the water pump?
    I've checked out multiple threads here including: 2010 Toyota Prius overheating issue, Nothing works! | PriusChat , Need help! Gas engine overheating. Cannot resolve. | PriusChat
    Thanks for any help.
  2. Tombukt2
    13,289
    2,397
    It honestly sounds like you've still got air are you filling it up to the third letter on the jug You fill it up to there then you run the car and it should drop to the full mark that drop may take a few minutes you know Prius don't warm up and you know 4 minutes like a normal car and I didn't look at your mileage if it was stated in the original post these cars are known for water leakage into the cylinders and so on and so forth so don't know You've already had some misfire codes and changed plugs and all this and that maybe when you have the plugs out again you should be looking at the plugs for teeny tiny water mist vapor droplets they are very hard to see at my age I use a magnifying glass in my nose and if I smell the glycol on the plug I take my finger stick it on the plug end then touch it to my tongue to confirm that it is in fact pretty pure glycol like the 50% mix in your degas bottle. And then I go ahead and check the other three plugs and verify or maintain that they're clear clean whatever and then I know I have something quenching my fire in the given cylinder or I tasted this and smell this then I know then I start looking for an engine.
    Newman42 likes this.
  3. Mendel Leisk
    41,824
    What was the miles when you bought it?
    Could be a stop-leak product in there?
  4. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    Back flushing doesn't mean it will be cleared.
    Did you clear the radiator also?
    If it ever had pretend stop leak, it's clogged. Along with other small passaged
    for the head and engine...
    White vinegar might help to clear that crap out. But you might need a new radiator,
    possibly heater core. Radiator first.....
  5. Mendel Leisk
    41,824
    One stop-leak manufacturer recommends 50/50 water/vinegar, says it dissolves their goop. Then flush well with straight water. If you can extract a few blobs of the stuff (assuming there is some in there) test them with that mixture.
    Also, once you're done, you've now got a system with a fair amount of residual straight water. Trying to get that back to 50/50 mix with pre-mixed coolant (the recommended Toyota Super Long Life coolant ONLY comes pre-mixed) is nigh impossible. Consider using coolant concentrate, say Toyota Long Life coolant (without "Super"). It's service interval is half though. There's some thoughts on that in my signature (on a phone turn it landscape to see signature).
  6. Newman42
    Newman42 New Member
    Dothan, AL, USA
    Bought it around 150k and now at 247k.
    I know the previous owner and don't think he would have put stop-leak in there.
    ASRDogman and Mendel Leisk like this.
  7. Newman42
    Newman42 New Member
    Dothan, AL, USA
    I used Blue Devil radiator flush.
  8. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    Why did you replace the water pump last year?
    What engine water pump did you purchase? Was it an OEM pump?
    It sounds like a bad water pump to me.
  9. mjoo
    mjoo Senior Member
    1,162
    1,331
    Michigan
    Was the headgasket replaced? If not, is it losing coolant?
    SM-A536V ?
  10. Newman42
    Newman42 New Member
    Dothan, AL, USA
    I had a P261B (iirc) code and replaced it with an Aisin.
  11. Newman42
    Newman42 New Member
    Dothan, AL, USA
    Headgasket has never been replaced. Oil seems clean. No residue on oil cap.
    The loss of coolant seems to come from the reservoir cap. I only witnessed this once. I have seen coolant around that area and oddly enough on the rim of the tire.
  12. Newman42
    Newman42 New Member
    Dothan, AL, USA
    Drove it for 30 minutes with the Blue Devil Cleaner in it. Parked it and put it in maintenance mode. About five minutes later the reservoir fills up and "coolant" starts leaking out of the cap, so I shut it down.
  13. Tombukt2
    13,289
    2,397
    That's water expansion from getting hot getting too hot and it'll expand too much and it blows out the Degas bottle lid or a cap there's an o-ring in there that's why you're undoing it off the click and then you're turning turning turning turning and it lifts up off of there and he flip it over you see that o-ring that goes in and up and down in the bore. Mac creates the seal like your radiator cap and then I guess once you reach a certain point it can blow through the pressure relief in that cap and then it comes out of that little nipple that's facing the right side of the car and squirts out and I imagine some steam comes with it and it looks quite funky when it's doing it quite a bit this is why you feel to the third mark up on the digest bottle what's it the p mark or something and then when it's done and everything is settled it should be at the full mark I'm imagining this be warmed up obviously after you drive in the air and all rises to the top the level of the coolant falls to the full mark then you get in your driveway or park somewhere and you look at it you see it's on full so it's dropped from p to f or whatever that is and you leave it then when you come out in the morning you should lift the hood or whatever I just leave the hood up my property in the morning when I come out I look at it to see dead cold how much everything is shriveled up I'm a little below full usually
  14. Newman42
    Newman42 New Member
    Dothan, AL, USA
    Hi all,
    The water pump is making a gurgling/ticking noise. Is it going bad/already bad? Hoses to the EGR cooler are very hot (where the bleed valve is), but every other hose is warm or cool. Any thoughts? Thanks in advance.
  15. Tombukt2
    13,289
    2,397
    Sounds like your inverter coolant pump is not pumping if the reservoirs full the specified for the inverter coolant pump which is opposite where the coolant goes for the engine complete other side of the car both reservoir should be pink color indicating pink or reddish fluid is installed which is just the Asian branded coolant at Walmart or wherever you go Toyota dealer pretty much all very similar nothing to worry about too much but if that fluid is not moving and it's getting warm enough it will affect inverter and thereby hybrid performance a generation 3 may be more finicky than a two in this regard but in any case you need to get that fluid moving there's a reason it's not moving and it's stagnant and getting hot generally one would be looking towards the electric pump get your hand to where the hoses are for that pump one hose will usually be quite warm in the other one will be quite cooler indicating that the pump is not working being called upon the operate or something
  16. Newman42
    Newman42 New Member
    Dothan, AL, USA
    It was the water pump :\
  17. Brian1954
    2,371
    954
    Thanks for coming back and reporting the fix.
    What water pump did you purchase this time?
  18. Newman42
    Newman42 New Member
    Dothan, AL, USA
    Aisin again. I think the temperature sensor caused the car to overheat, which caused the thermostat gasket to blow, which caused the water pump to get too hot, which burned out the plastic spindle.
  19. Brian1954
    2,371
    954
    It is very unlikely that the engine coolant temperature (ECT) sensor caused the engine to overheat. So you say that the thermostat gasket blew out? If that happened, coolant was leaking out. If the coolant level got low enough, the engine would overheat due to the lack of coolant, and the high coolant temperature or lack of coolant would affect the impeller in the water pump.
    It sounds like you have severely overheated the engine, which will lead to failure of the head gasket. I would start looking around for a replacement car or an engine replacement.
    #19 Brian1954, Dec 27, 2023
  20. ChapmanF
    18,454
    In most cars, the idea of the ECT sensor causing overheating would be out in left field; it would be the wax pellet in the thermostat controlling the temperature, and the sensor doing nothing but reading the temperature for the ECM to use for things like fuel mixture control.
    In a Gen 3 it's maybe not quite as far in left field, as the water pump is variable speed and the ECM tells it how fast to run, and may look in part at the ECT reading to do it. I still wouldn't leap right there as a cause for overheating though.
