Gen 5 LE - 195/60/17 Tire Replacement Question
Discussion in 'Gen 5 Prius Main Forum' started by Wheelman, Dec 18, 2023.
  1. Wheelman
    Wheelman New Member
    NC
    2024 Prius
    The Prius Gen 5 LE has standard 195/60/17 tires, with no spare tire, just a repair kit.
    I am considering replacing them with 215/55/17 run flats.
    195/60/17 is (7.7"wide x 26.2"high) vs. 215/55/17 is (8.5"wide x 26.3"high).
    It is .8" wider than the standard tire.
    Would there be a clearance issue with calipers or scrubbing during turns?
  2. HacksawMark
    HacksawMark Active Member
    437
    284
    Oregon
    2023 Prius Prime
    XSE
    No you won't have any any clearance issues. I'm running 215/60R17 for my winter set. So same width but taller. No issues at all.
  3. Bryden
    Bryden New Member
    Utah
    2023 Prius
    LE AWD-e
    I am using Bridgestone Blizzak 215/60R16's on 16x6.5 (5-114.3) and have had the car in a few Utah snowstorms so far. VERY impressed with the grip and control ('23 LE eAWD)...
