New Engine Installed - No A/C
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SFR-DSR-44, Dec 19, 2023.
  1. SFR-DSR-44
    SFR-DSR-44 Junior Member
    59
    Milpitas, CA
    Hello, I need some guidance.
    A friend and I put a "new" engine into my 2013 Persona with 126K miles due to a cylinder #2 start-up misfire that was found to be a head gasket leak. The engine had never been overheated, but oh well - seems like a common failure mode.
    After the engine swap, the engine/hybrid system is all working great. I have no ECU codes, it runs strong with no misfires/rattles/etc, and because we cleaned all the components pre-installation (e.g. EGR & intake, and put in new spark plugs & EGR, etc...). I may be seeing a slight bump in mpg (~1-2 @ 75mph) but that's not important to my problem.
    Unfortunately, I have no A/C - the fan blows ambient air and I think the compressor isn't kicking on. We carefully hung the A/C components during the motor swap and didn't think we damaged anything to cause a leak (but of course this is possible). The only connector removed was the small communication connector on the top of the compressor, not the high-voltage line to the inverter.
    Work done so far:
    1) Checked the fuse panel under the hood as well as in the driver's footwell and the fuses related to A/C are fine.
    2) Inspection of the sight glass on the left side of the engine compartment on what I think is the high-pressure line. I don't know what to conclude, because I never looked at it before. I think I see liquid moving but no obvious bubbles.
    3) I did the "hold down AUTO and recirc" trick and I got a flashing 72, which means "A/C INVERTER HIGH VOLTAGE OUTPUT SYSTEM MALFUNCTION." I think this could mean that either the high-voltage fuse in the inverter (the $50 one) could have blown, the compressor decided to die as a result of all the handling, or perhaps contamination/moisture got into the plug on top of the compressor causing a short. I have not yet opened the inverter top to inspect the fuse, as it was raining the past two nights.
    I wanted to ask if anyone has other ideas before I start playing with the inverter, or a similar experience?
    Thank you very much,
    ~Eric
  2. JC91006
    JC91006 Senior Member
    16,768
    8,565
    You did add refrigerant right?
    SFR-DSR-44 likes this.
  3. Tombukt2
    12,959
    2,326
    In my 13 persona when we swapped in the JDM engine I had the same problem along with some other funny business going on electrically so I electrically unplugged the compressor that is the orange business I put the communication connector back on and made sure before I put it together that there was no water or anything in the connector that's going to press into the compressor so clean it blow it out whatever make sure it's good and install that plug right around for a day or so with the compressor orange HV plug undone. After you driven a few cycles with it unplugged completely just at random whenever you decide turn the air conditioning on everything like you're going to run it for cold put it on low not a temperature or circulate all that pull the hood release get out of the car and plug the orange plug to the compressor up It should immediately start up and run If your air conditioner was working before the engine swap it should not be out of gas or refrigerant to be technical check it out and see if you can make that happen
  4. SFR-DSR-44
    59
    Milpitas, CA
    Thank you both for replying.
    No, not yet because: a) I have not concluded there was actually a loss of R134. The a/c system worked well before the engine swap and the code on the HVAC is pointing towards something electrical going on.
    Interesting. So you ran the car with the 6-pin connector plugged into the compressor (I will remove and double check to make sure it is all clean/dry inside) but with the orange high voltage cable removed. While it makes me somewhat nervous that you ran with the open high voltage exposed on the back of the inverter, it seems like it worked for you. I wonder what that was doing in terms of the car's logic to then fire up.
  5. JC91006
    16,768
    8,565
    Ok, you need to add refrigerant. The proper amount that's indicated, not more, not less. This is the first step in getting the compressor to turn on
  6. ChapmanF
    18,180
    Now we're advising people to go around making high-voltage connections under the hood while live?
    What's a person even expected to learn from that stunt that couldn't be learned in some less hold-my-beer way?
    Mr. F, Tombukt2 and SFR-DSR-44 like this.
  7. rjparker
    10,142
    6,304
    You don’t add refrigerant if the hoses have not been removed and refrigerant was not obviously lost.
    Mr. F and SFR-DSR-44 like this.
  8. Tombukt2
    12,959
    2,326
    Yep that's what I did I just unplugged it because it kept throwing a code for the air conditioning which I knew was working fine when everything was last used so I just unplugged it Left the cord where it's mounted and unplugged I didn't think anything could happen doing that at all actually like unplugging something from the wall or plugging in the generator and back feeding and I drove like that for a few days without any consequences not a thing happened and then when I plugged it back in I didn't touch the orange plug in the trunk I just plugged the thing in in the front click while the system was on on the display and the compressor started whirrinh been running ever since I didn't realize there was a safety concern at all My thought that's what those plugs were there for if it was not meant to be unplugged it would be a different kind of connection or something can the fire just jump right out of the receptacle or the plug? That would be pretty cool.
  9. Tombukt2
    12,959
    2,326
    Open from the back of the inverter Will that receptacle or plug however you want to look at it comes out of the inverter and it's bolted to that bracket and then you squeeze and unplug whatever. There's only power at that plug You know when the cars running but there's nothing plugged into it I guess you could put a piece of tape over it if it worried you or something.
  10. ChapmanF
    18,180
    There are connectors so things are easy to take apart when you need to ... with the car off, the service plug pulled if you read manuals, and time for the capacitors in the inverter to drain.
    They weren't put there for stunts with live high voltage, though clearly that doesn't stop 'em being used that way.
    'Fire' can do a bit of jumping when a circuit has reactance. In a Gen 2, you'd be playing directly with the motor windings and their inductive reactance. Gen 3 is a little different because the motor inverter's inside the compressor and you're playing with its power supply instead of with the motor directly ... but it's still a 3 kilowatt motor and supply, not a wind-up toy.
  11. Tombukt2
    12,959
    2,326
    Yeah I just treated it like the dryer cord unplugged it Left it hanging over the metal hose near it or whatever and clipped it there and apparently whatever was going on at worked because after a few days of not being in the system whatever when I plugged it back up with the system turned on on the screen it brought the compressor on and it's been running ever since. I knew I didn't need gas because when I shut the car down to put in the engine the air conditioning was blowing ice cold and the gauge readings were pretty much beautiful you know the things with the dials on them that measures the refrigerant PSI on the high and low side those things I knew it didn't all leak out just sitting there. So just it being disconnected for a few days and the reason for the disconnection was I noticed that when the unit was plugged up it was draining the h a l e out of my hybrid battery for no reason the air conditioner wasn't on but my hybrid battery was just going down like crazy and other things were happening and I had dash lights I unplugged the compressor in the car was drivable without the battery monitor going all the way down then when I started looking I found that the hybrid battery was all corroded and disgusting like most of them got that resolved by the hybrid doctor up in Virginia not battery still going strong and then when that was rectified in the electricals and the hybrid system were all working properly with no lights and codes and then plug the air conditioner back up and it's been working fine ever since I had no idea I was possibly going to kill myself with electricity I unplug my dryer all the time if I have to work on it or whatever I didn't realize the outlet or the plug was susceptible to that kind of bad thing.
  12. rjparker
    10,142
    6,304
    Obviously you and others have proved you can get away with plugging in the compressor hot. Still, it is more dangerous than 12vdc. It seems there is some unknown mechanism in the AC compressor that can cause power leakage after being moved out of the way. Seems to happen periodically after head gasket or engine repairs, but not everytime.
  13. SFR-DSR-44
    59
    Milpitas, CA
    Update: A/C is NOW WORKING!!!!
    Thanks for the replies and suggestions.
    I didn’t try the hot plug idea, but after getting back into town from "Christmas with the family" this morning I decided I’d start from ground zero and go step-by-step.
    My initial thought was the high voltage fuse in the inverter:
    1. I disconnected both batteries and let the system bleed down. While it was bleeding down I removed the 6-pin connector on the compressor and used some electrical contact spray and dried it using my shop vac to create air current.
    2. I removed the top of the inverter (L-bracket) to expose the high voltage connections and the fuse. The fuse looked fine, but I removed it anyways and using my ohm-meter confirmed it was okay.
    3. Then, reattached both batteries and verified basically nothing had changed. Still got code 72 in the HVAC test and the compressor wasn't kicking in.
    Okay, so now what? I still wasn't going to try the hot plug idea, but thought that maybe there needed to be some handshaking between the inverter, compressor, and HVAC controls? Or maybe the HV connector at the compressor wasn't clean or got damaged when the engine bay was reassembled? Or maybe just needed a hard reset of the HVAC? I didn't know for sure so I did the following step-by-step. You'll see later that it may have been just the last few steps, but since I'm not 100% sure I'm posting everything I did at the risk of looking stupid(er)....
    1. Using small probes and a Fluke 87 multimeter, with car on and running but A/C button off, checked high voltage on both sides of the connector near the compressor.
    2. Turned A/C button on and confirmed high voltage on both sides of the compressor. In both cases, the voltage was fluctuating some (which seemed odd to me), but at least I knew I had voltage to the compressor; I did not know if it was enough or whether it had enough current to go along with the voltage when asked for.
    3. Turned off car and disconnected both batteries again and let bleed down for 10 mins.
    4. Disconnected both the 6-pin and high voltage lines to A/C compressor.
    5. Reconnected both 12v and hybrid batteries, and started the car. Still had HVAC code 72 and somewhat expected a communications error but nothing new.
    6. Turned off car, and reconnected the 6-pin. No change.
    7. Disconnect hybrid battery again and wait to drain (10mins), and reconnected the high voltage compressor connector.
    8. Reconnected hybrid battery.
    9. After everything was put back still had code 72. Ugh.
    ---Now, I think if I had started with the next step I may have saved myself 2 hours. However, I do feel like I've at least made sure everything else (except for refrigerant) looked in good shape.---
    9. With the 12v battery still connected, I pulled the 10A A/C fuse (fuse 31) in the under hood fuse box and waited for about 2 minutes.
    10. Put fuse back in, and HVAC code 72 had cleared and got 00. Did not hit A/C button yet.
    11. Turned off car.
    12. Turned car back on and hit the A/C button. A "strange" sound not heard since the engine swap was heard, and the air got cold quickly. The compressor had come back to life. Woot!
    It looks like when the HV line to the compressor was disconnected during the engine swap, it put the code 72 into the HVAC memory that wasn't coming out with simply disconnecting the 12V battery - rather the fuse had to be pulled and reinstalled with the 12V battery connected to do more of a hard reset of the HVAC.
    SO, I think it was the hard reset via the 10A fuse #31 that ultimately was the secret sauce. But, going methodically and verifying the HV fuse in the inverter and the various voltages helped me to be more confident that a connector or cable hadn't been damaged during the engine swap.
    Now I just need to replace the front sway bar links and the right side tie-rod end due to torn boots and she'll be as good a new. Although she will probably need an alignment.
    ASRDogman likes this.
  14. ASRDogman
    ASRDogman Senior Member
    7,585
    3,908
    What "system bleed down" are you waiting for????
  15. SFR-DSR-44
    59
    Milpitas, CA
    From the various threads and YouTube videos I watched they seemed to suggest waiting 10-15 minutes for the high voltage to discharge (for lack of a better word). I realize that opening up the L-bracket on top of the inverter opens up a switch and technically leaves it safe but since I did not have isolating gloves I didn’t want to take any chances - and in later cases I was not working with the L-bracket off and thus needed to give the system time to discharge.
  16. ASRDogman
    7,585
    3,908
    Okay, that make sense. I seem to remember reading about that and/or
    hearing about that in videos....
    Main thing is, the A/C is working!
  17. ChapmanF
    18,180
    Yup, that was probably it. The repair manual section for that code does say "the compressor operation remains stopped until both the history and the current DTCs are cleared."
    Out of curiosity, had you ever tried either using a scan tool to clear the HVAC codes, or using this DTC clear gesture while the panel diagnosis is showing?
    That might also have done the trick.
    As far as I remember, the only ECU in the car with codes that can only be cleared by pulling a fuse is the one that moves the parking pawl ... there's a list of eight codes for that one that can only be cleared by pulling the P CON MAIN fuse.
  18. SFR-DSR-44
    59
    Milpitas, CA
    Re: a scan tool, all I had was a simple OBD2 scanner and I don’t recall it being able to see the HVAC module. Thus, the only way I was seeing the HVAC code 72 was via the holding down of Recirc & Auto during start-up I need to consider something better going forward. Do you have a recommendation?
    Re: trying pressing Front Defrost and Mode simultaneously, I did read through that Repair Manual and saw that for the Prius it was Front Defrost and Mode - but it didn’t work for me and so I didn’t mention that. I probably should have (I’ll try and edit) as that is probably what triggered me to try pulling the fuse while the 12V battery was still attached.
    Thanks again for all the support on this forum! Now I just need to decide if I want to try swapping out the head gasket on the old engine when I have time.
