P3191 After EGR cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mysticalbambi, Dec 24, 2023.
  1. mysticalbambi
    mysticalbambi New Member
    Charlotte
    Hello,
    I have a 2012 Prius with 165k miles. No problems prior to cleaning EGR. I cleaned out my EGR system today & after putting everything back together & starting my car it had a very rough idle & died a 20 seconds later or so. It threw the code P3191 (Engine does not start) & 03190 (Low engine power). I went & looked to see if everything was plugged in & it all seems to be plugged in. I put it together without waiting for any of the chemicals to fully dry. When I disconnected the mass airflow sensor & ran it, it would run rough but it did not die. Any help with this would be much appreciated!
  2. Mendel Leisk
    42,297
    Check the PCV hose is plugged into intake manifold. Otherwise it’s a massive vacuum leak. That one has tripped me up.
    Brian1954 and PriusCamper like this.
  3. PriusCamper
    PriusCamper Senior Member
    13,422
    5,419
    Pacific Northwest, USA
    How massive is massive? :)
  4. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
  5. mysticalbambi
    Charlotte
    I made sure this one is fully connected
  6. mysticalbambi
    Charlotte
    Where did you read it was specifically for the camshaft position center? Will look more into it.
  7. Mendel Leisk
    42,297
    Gas tank vapour hose connected to intake manifold? That’s just below throttle body.
    Brian1954 likes this.
  8. Tombukt2
    13,826
    2,510
    If it starts and runs and then dies pretty immediately or whatever you probably have your vacuum covered a PCV or a gas tank vent largely like that would probably not allow the two ZZ Atkinson to start The electric motors will back you up or whatever reverse but as soon as the engine tries to start backing up far enough or whatever it'll spin over you'll hear it try to turn the motor on activate the coils whatever and it just won't do it and it throws the 3190 91 whatever poor engine power so on and so forth yeah because there's none remember the reciprocating mass is turning all the time no matter what you're doing with the car in forward or reverse so the Pistons are going up and down the computers just haven't turned the coils in the fuel on.
  9. Brian1954
    Brian1954 Senior Member
    2,667
    1,066
    South Central PA, USA
    The description for P3191 is "Engine does not start." There are many reasons why the engine may not be starting. The camshaft position sensor is only one of many possible reasons. Here is a list of other reasons why the car is not starting:
    1. Intake system (possible vacuum leak)
    2. Throttle body assembly
    3. Fuel pressure
    3. Engine
    4. Mass air flow meter sub-assembly
    5. Out of fuel
    6. Engine coolant temperature sensor
    7. Crankshaft position sensor
    8. EGR valve assembly
    9. ECM
    I would check the other possible reasons before I would check the camshaft position sensor.
  10. mysticalbambi
    Charlotte
    On maintenance mode it will run & it will die after 15 seconds or so. When I turn it on regularly it will run & sometimes idle perfectly smooth until it auto-turns off. Do you know where all the vacuum lines would be? I’m looking & I can’t see any that are blocked off or disconnected
    Which side of the manifold would it be on? I’m currently taking it apart in case there was something I missed
    #10 mysticalbambi, Dec 25, 2023
  11. mysticalbambi
    Charlotte
    So I may have found the issue, behind the intake manifold there was a disconnected hose, I will put it back together & try after plugging it in to see if that fixes it
  12. mysticalbambi
    Charlotte
    That ended up fixing the issue. Thank you everyone who was able to respond
    Mendel Leisk, Brian1954 and ASRDogman like this.
  13. ASRDogman
    8,052
    4,083
    Okay, my mistake. I have no idea why I wrote that about the cam shaft position sensor.
    But, I DID include the article, so if anyone just read the article..........
  14. Mendel Leisk
    42,297
    AFAIK there’s 2 “air” hoses, the PCV and gas tank vapour. If either end of either is disconnected your engine will only “run” for a few seconds.
  15. icurays1
    icurays1 New Member
    Tucson AZ
    2015 Prius c
    For those looking for other possible solutions, I had this same issue and could find no hoses or wires disconnected. Checked and re-checked everything, including putting old spark plugs back in, old engine air filter back in. I have a 2015 Prius C but I don't think it makes a huge difference.
    When I cleaned my EGR, I tool the electric actuator part off so I could depress the EGR valve manually and get some cleaner in it. I think when I re-assembled it, it must not have threaded the magnet all the way back on. The magnet is the grey cylinder with a spring under it - it threads onto the shaft of the EGR valve. Didn't get a pic of it but it is inside this black housing with the plug on it:
    Anyway, I took the electric part back off (leaving the EGR installed in the vehicle), inspected it, threaded the magnet back on a bit tighter this time, re-assembled and the car started smoothly after that. I suspect that the EGR valve was stuck (open or closed, not sure which), which was causing the issue.
    Hope this helps someone.
    ASRDogman likes this.
