Being nice to your motor
Discussion in 'Prius v Main Forum' started by Nicad, Dec 1, 2023.
  1. Nicad
    Nicad New Member
    ontario, canada
    2023 Prius
    Limited AWD-e
    Just wondering if it is advisable to run the car hard some times just to get the motor fully up to temp, revved out, working hard. Seems to me a totally sedate life will lead to car Sclerosis?
    52,362
    Some highway driving every now and then would probably be a good thing,
    But more importantly, regular servicing of the egr circuit is the best preventative maintenance, and 5,000 mile oil changes
    djasonw and Tim Jones like this.
  3. rjparker
    10,474
    6,567
    I doubt you can get it warmed up more than it does normally if you drive 15 minutes or more. It is highly unlikely you will blow out carbon with high revs even if they were not limited by the hybrid system. In my experience high speed driving just burns more gas and accelerates oil consumption.
    The best preventative actions for head gaskets and brake boosters are frequent oil, coolant and brake fluid changes. Before high oil consumption starts and before increased brake booster cycling. Without high oil consumption, egr buildup will be nominal.
    Doug McC and Tim Jones like this.
  4. Doug McC
    Doug McC Senior Member
    1,080
    420
    Midwest
    2022 Prius
    What you are referring to is often called “an Italian tune-up” and many here swear by it. Even The Car Care Nut seems to. I don’t. I agree with rjparker, preventive maintenance (more often than most people here do it) will work a whole lot better, even though it may not be as much fun as playing hot rod racer.
    CR94 likes this.
  5. Mendel Leisk
    41,873
    I’d just try to avoid frequent short runs, consolidate chores where possible.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The motors do not need more maintenance than 100,000 mile changes with ATF WS.
    Perhaps you were thinking of the engine.
  7. Mendel Leisk
    41,873
    Symantecs? The engine lubricant is referred to as motor oil.
  8. CR94
    CR94 Senior Member
    2,741
    1,198
    Northwestern S.C.
    More likely the opposite for third-generation cars, considering the susceptibility of their head gaskets to thermal gradients. That's especially likely when the engine is cold.
    Your 2023 might be more tolerant of your method of "getting the motor up to temp."
