Just had inverter coolant pump changed, ran 1 day, now not starting, getting P3191
Discussion in 'Generation 1 Prius Discussion' started by Jtaylor1111, Jan 3, 2024.
  1. Jtaylor1111
    Jtaylor1111 New Member
    Vermont
    2003 Prius
    2003 Prius. Our inverter pump failed and we had a local mechanic change it, and it ran perfectly after he changed it, and then when we went to pick it up and drove it home (about five miles). The next day, we turned it on and are getting red triangle and the car with the exclamation mark, and the car engine turns off after about three minutes, or less. We ran our OB2 scanner tool and got the code p3191 that apparently just means that the engine won't start. Is there a common mistake that my mechanic (not a Prius mechanic) might have made changing the inverter pump? It is working and he said that he bled it too.
  2. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    It is pretty hard to mess up an inverter coolant pump remove and replace and should not result in a P3191 if something was done incorrectly.
    The diagnostic and repair process for a P3191 is pretty much the same as for any gasoline engine.
    Jtaylor1111 likes this.
  3. Tombukt2
    13,336
    2,401
    Generally speaking I would say not but I don't know that 2003 model that well that's the little coupe thing. Generally you go over all the ignition related stuff and are you sure you're not out of fuel that will certainly make the engine not start I've had it happen to me on purpose about three times I do this when I get a new car and do a gas mileage test I run the car out to empty to see where my fuel gauge actually looks like when it's empty and how far I can go after empty.
  4. bisco
    52,335
    i wonder if he might have bumped some other wires?
    here's a thread:
    code-p3191.77997
  5. Jtaylor1111
    Vermont
    2003 Prius
    Looking at videos today about the inverter pump, I don't that the brand new OEM pump that was put in is pumping very powerfully. The surface of the coolant is almost still, though you can see movement under the surface, so I thought it was working, but it definitely is not churning the way that you see in other cars with good pumps. Could this be the reason I am not able to keep the car on? Also, could this be caused by air in the system or some other reason that has to do with not installing it properly? I have seen online that it can take hours to get all the air out, and I don't think that it was anything like that for our mechanic, though I haven't asked him specifically about it yet.
  6. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    Before jumping into engine diagnosis, which this could be, check a couple of other things first.
    Turn the ignition to "acc" but don't start the car, then test the 12v battery voltage. It has to be above 12.1v in acc in order to be sufficient to booting up the system to start the car properly.
    If good, disconnect the 12v battery for a few minutes then reconnect it.
    This will reboot the ECU system and allow it to better recalibrate to the recent new changes in the system, and allow the engine ECU to start the engine properly.
    SERIOUSLY, try this first, It may save you some effort and trouble.
  7. Jtaylor1111
    Vermont
    2003 Prius
    We did disconnect the 12 volt battery and then re attached a couple of times, but when we try to start it, it does appear to start for about one minute and then the car engine dies and the car with the exclamation point warning light is red. We also checked to voltage and it was well above 12 volts (we replaced that battery about eight months ago).
    I am wondering if perhaps the viscosity of the coolant in the colder weather is such that it makes it less turbulent with the new pump (was about 25 degrees), rather than an issue with the strength of the new pump so now I am not sure if that is a helpful observation.
  8. Trombone
    Trombone Active Member
    338
    114
    Allentown, Pennsylvania
    2002 Prius
    Well, believe it or not, couple of mornings ago when it was single digits outside, I read 9.6 volts on the ScanGaugeII and the hybrid system booted just fine with engine "Ready" in about 1-2 seconds. YMMV!
  9. ronlewis
    ronlewis Active Member
    1,021
    200
    texas
    2001 Prius
    OP, I'd forget about the coolant pump. That's not your issue. Maybe it's an issue, maybe it was never an issue. It wouldn't cause a cold engine to not start. The car would have started and run just fine after your tech's work regardless. A failed pump will only affect engine performance once the inverter coolant temp gets too high, which it doesn't do real fast from a cold start.
    You got another problem, or maybe one that was only ever your problem, IDK. The first clue, IMHO, is that you're not getting other codes. That generally means problems in components that are not sensor-monitored, more "mechanical" than electronic. Fuel delivery can be an example, or the throttle body.
    Of course, check the basics - does the ICE rotate? Got oil, fuel? It's possible and fairly easy to slightly lift the fuel rail off the injectors to see/confirm base fuel pressure. Should see if when you first lift, and then turn the key on a second to reconfirm before sealing it back up. Does risk the injector o-ring(s) failing when you set it back down, so be careful. Definitely check for loose connectors on any sensors that might be telling the ECU to not energize or push fuel.
