Broke Hybrid Battery Service Plug off inside battery.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Spradilak, Jan 1, 2024.
  1. Spradilak
    Spradilak New Member
    South Carolina
    So as the post says..I finally got done doing my reconditioning, everything was going amazingly well. I went to go out the service plug in. While I was lifting the totating the lever up I felt some resistance but continued to push anyways....and it broke.
    Now the remainder of the service plug is in the battery socket and the locking tab is laying in my backseat. How the hell do I get the rest of the plug out of the socket? No amount of moving side to side or up and down will break it loose..is there a tab somewhere that I'm missing that needs to be pressed in? I could really use some help here.
    Hopefully toyota stocks these and I can pick one up tomorrow..
  2. Spradilak
    South Carolina
    OK I guess I jumped the gun. I stuck a flathead in between the orange of the service plug and the black socket and slowly twisted it around the perimeter until it came out. I post this incase the same thing happens to someone in the future.
    If you feel any resistance when swinging the locking arm up DO NOT GO GORILLA ON IT. It will break..now I just need to find a replacement. Thanks.
  3. PriusCamper
    PriusCamper Senior Member
    12,685
    5,120
    Pacific Northwest, USA
    Glad you didn't get yourself electrocuted! This is probably one of the most high risk problems you could have with an HV battery pack.
    Of course I'm sure you had insulated tools and high voltage safety gloves with fabric gloves over them, right? Lol... Not!
    Spradilak likes this.
  4. Spradilak
    South Carolina
    I did in fact have insulated tools(only for the 8mm bus bar nuts)and 00 gloves for the assembly/dissambly process, however I didn't use the gloves to put the safety switch back in. But I did put them back on when I carefully pryed it out with the screwdriver. Not gonna like I was pretty nervous.
    My job is an offline reworker at the BMW manufacturing plant in SC, so I brought my insulated 00 gloves and 8mm home with me for Christmas break. :D
    I just hope that one of the dealerships near me has it in stock since my other vehicle is a 1990 Chevy silverado and that thing chugs some gas.
    PriusCamper likes this.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,584
    765
    Southern California
    Can the OP please post a picture of the broken plug? I'm curious how it broke.
    Some devices like that "break" when the plastic temporarily deforms enough to jump off its retaining post, and in those cases, they can often be reassembled and will work fine afterwards. If the plastic actually snapped or bent, well, that shouldn't be repaired.
  6. Mendel Leisk
    41,316
    With current "issues", OP will need to post the pic somewhere else, say Google Drive, iCloud, and provide a link here.
  7. PriusCamper
    12,685
    5,120
    cut and paste photos still works for me...
  8. ChapmanF
    18,071
  9. Spradilak
    South Carolina
  10. pasadena_commut
    2,584
    765
    Southern California
  11. Spradilak
    South Carolina
    I found one about an hour away for $40. If I didn't absolutely need the car the next day I would have just ordered one from ebay for $15-$20 but I guess you have to pay for convenience. But thanks for the link!
