Prius 2010 118k miles (Master brake Cylinder and brake booster assembly)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gof, Jan 12, 2024.
  1. Gof
    Gof New Member
    Va
    Brake lights went on, etc. so took it to dealer for code check. Per them:
    "Car needs new master brake cylinder and brake booster assembly. 1-2 days labor, total would be $3820 before tax. Plus he said the front rotors are rusted out and they recommend changing the pads and rotors, additional $500. They said it is probably safe enough to drive it to get it home but otherwise not drivable as is"
    Car otherwise has had no other issues other than new tires. I love the prius brand but I am not ready to pay for a new prius (only drive once a week and a few times a year 200-600 miles round trip vacation trips.)
    Has anyone had experience or feedback on this particular repair? Was going to take it to a local shop for labor cost, but I'm not well versed in this particular repair.
    51,567
    yes, it is very common, and toyota actually extended the warranty to 10 years i think. check on that in case it's 15.
    if not, see if you can find a mech who might do it, i think the parts are around $1,200., you can call around to other dealers too, for competitive pricing.
    hard to see about the pads and rotors, they might just be scamming you, idk.
  3. rjparker
    9,901
    6,105
    10 year 150k miles. Need to buy new parts selected by vin to ensure it works at all. Requires Toyota Techstream or one of a few high end scanners to calibrate and bleed. Lots of labor so don’t do it twice.
  4. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    Yes, mine went out around that mileage. Dealer wanted $3,000. I ended up buying the part used from eBay and installed it myself for around $200. There was a good in-depth video of the install on YouTube that made the process a lot easier for a first timer.
  5. Gof
    Gof New Member
    Va
    Thanks for the replies. I will upload the report and their quote. Feel like I’m being charged way too much. I’m planning on taking it to another shop to take a look at it. But appreciate the comments and if you have anything else to add, I really appreciate it.
  6. Mr. F
    Mr. F Active Member
    387
    255
    Washington
    What were these costs? Brake fluid?
  7. Mendel Leisk
    41,013
    Good video:
    (Cautionary note at 22.40 about the need for "very good scan tool", without which you shouldn't attempt this.)
  8. Gof
    Gof New Member
    Va
    Uploaded link - image upload not working
  9. Mendel Leisk
    41,013
    Raw text from OCR of above:
    imgur
    Sign In
    Sorico Name
    Price
    E 6 of 6 TOZDIAG: ENGINE DIGNOSTIC
    $0.00
    [Primary): 08TOZDROP2: DROP APPT
    $0.00
    [Primary): 08TOZ9319: 9319 TOYOTA APPT
    $0.00
    [Primary): 00TOZMPI: MULTIPOINT VEH INSP
    $0.00
    [Primary): 00TOZFMI : FLOORMAT INSPECT
    50.00
    (Other): 1.0 DIAG ABS AND BRAKE LIGHT
    $170.98
    Assembly
    [Other): C1391 TSB:0079-18; P&A Brake Booster Assembly With Master Cylinder Brake Booster Pump
    $3811.68
    Brake Job - Front (Replace Pads and Rotors): DO NOT REC. RESURFACE DUE TO RUST BUILD UP
    $502.60
    Oil Change: DUE FOR OIL CHANGE
    $35.00
    Printed on January 12, 2024
    Quote expires on February 11, 2024
    Subtotal $4520.26
    $90.00
    Shop Charges 5126.20
    Total $4736.51
    VOTE
  10. rjparker
    9,901
    6,105
  11. Gof
    Gof New Member
    Va
    Took to another mechanic. He said that the light and code disappeared after filling it with brake fluid. Does not suspect this repair is needed and has been using the car for 4 days without issue. Is this common?
  12. Danno5060
    Danno5060 Active Member
    381
    199
    Wyoming
    It's been my experience that nobody is going to care for my car as much as I do - especially since it's a Prius. After the dealer screwed up a bearing change, I learned to do it on my own. I wouldn't hesitate to do the brakes on any of my own vehicles.
    What they're asking seems really high to me. I've never changed out a master cylinder, on any of the cars I've owned (going back to the mid-1970s). I'm sure there are times when these fail, but it's not been my experience. I've done the brakes on most of my other cars though. That's where I'd be looking.
    I'd at least pull the wheels off, and take a quick look at the pads and rotors, and calipers. Brake wear depends a lot on what part of the country you live in, what kind of driving you do, and how you drive. Even if you end up taking it into a mechanic, look at at least one of the front, and depending on what you see, one of the rear.
    All this changes if you have squeals, shimmy, grabs, grinding noises, or a mushy pedal.
  13. Gof
    Gof New Member
    Va
    Thanks.
    Their report: ABS, brake, and VSC lights on. One code found C1391. abnormal leak of accumulator pressure. There is a service bulletin for this code. Repair is to replace brake master cylinder with booster and accumulator. Found brake fluid low. Topped fluid level. Cleared code. Road tested over 5 days. Code did not reset.
    Front brake pads were low and rotors were rusted. These were replaced.
    Does this sound right? The dealership called saying that eventually the ABS will fail and lead back to the same issue. However the mechanic said that given the code and improvement with the brake fluid - the issue is resolved.
    Any thoughts would be appreciated!!!!!
  14. Danno5060
    381
    199
    Wyoming
    Check the system for leaks. If the fluid is low, it's gotta be going somewhere. Look for wet/oily areas on and around the brake lines, around the master cylinder, slave cylinders, brake lines, and brake line connections. Of course, recent brake system work could also make for some wet/oily looking areas.
  15. Mendel Leisk
    41,013
    It's normal for brake fluid level in the reservoir to drop as pads wear. Put new pads in, and it goes up. Mechanic dismissed codes, did a brake service, topped up fluid. If you've got something going bad in those two brake-related lumps on the firewall (won't even try to name them) a brake fluid top up won't "heal" them.
  16. Gof
    Gof New Member
    Va
    So a good sign?
  17. ChapmanF
    17,810
    A mirage, I suspect.
  18. Gof
    Gof New Member
    Va
    Thanks - made it a year without anything but fluid. Does this seem accurate? Same code came up.
  19. rjparker
    9,901
    6,105
    This quote is for a new 1391?
    You said you added fluid this year. After the brake job in January?
    #19 rjparker, Nov 25, 2024
  20. Gof
    Gof New Member
    Va
    No - no work was done in Jan. Just fluid. Just looking for any recs, seems like everyone is right!
