Prius Prime XSE Premium vs Prius Limited AWD - For the same money, which would you buy?
Discussion in 'Gen 5 Prius Main Forum' started by Eug, Jan 10, 2024.
  1. Trollbait
    11,560
    Do you swap to winter tires?
    TGrracie and Eug like this.
  2. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    Yep.
    Continental WinterContact SI
    TGrracie likes this.
  3. Hammersmith
    Hammersmith Senior Member
    1,337
    1,390
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Not to beat a horse completely to death(the poor thing has been turned to mush on a couple other threads already), but winter tire options are very limited in the stock 19" gen5 tire sizes. Options open up if you change wheel sizes. Michelin makes the X-Ice Snow in the stock 195/50R19(I've had them for about two weeks and am liking them so far). They also make it in the stock 17" size of 195/60R17. The Pirelli Ice Zero Asimmetrico is also available to Canadians in the stock 17" size. All other options require a non-stock tire size(as of Jan 2024). I think Bridgestone makes a Blizzak in 195/50R19 for the Japan market, but it's not available in North America and it's only their mild winter LM005 model, not the excellent WS90.
    You probably have already read those other threads, but I thought I'd do a quick sum up just in case since winter performance is important to your decision.
  4. Mendel Leisk
    38,726
    No reason to not go with 17" snow tires, if your stocks are 19", AFAIK.
    Eug likes this.
  5. flim
    flim Active Member
    207
    141
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    https://www.motortrend.com/features/toyota-prius-prime-vs-toyota-prius-specs-value-comparison-review/
    This article provides some insight on which one to get. Btw, do you really need AWD where you live? For the same price after your rebate, I would get the Prius Prime XSE Premium. You get a lot more for your money and it's more powerful and also more economical if combined with the EV miles.
    Is that how much it costs (CA$5000) to get a Level 2 charger in Canada?
    Btw, do you still have your 2012 Prius Plug-in Technology? I have the same model but it’s called Advanced.
    Since I got the Prius Prime XSE Premium 8 months ago, I used it for longer trips and mostly EV miles and I haven’t gone to the gas station since then.
    So I was able to drive the 2012 Plug-in only for very short trips on EV and so far I might be able to reach 1000 miles on the same tank of gas.
    #25 flim, Jan 14, 2024
    Eug likes this.
  6. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    Yes I still have the Plug-In but I’m getting the PCS warning light. I’m going back to the mechanic next week.
    If I lived where you are, I definitely wouldn’t get AWD. In my area it’s not critical but there are days where it would be very helpful.
    The charger isn’t necessarily CA$5000 for a simple install but in my case I’m guessing it probably would be $5000+, because it would have to be mounted outside and at some distance from the panel, with a sub panel upgrade. Neither the main panel nor sub panel could support it as is so the sub panel would have to be upgraded with new wiring to the sub panel and new breakers.
    The other issue is availability. I’ll have to talk to several dealers but my understanding is that Prius is hard to get but the Prime is even harder to get. As @Hammersmith suggests, I might just have to get whichever is easier to get.
  7. Mendel Leisk
    38,726
    If the Prime’s hybrid battery ever fails, it’ll brick practically total the car, it's so costly to replace?
    #27 Mendel Leisk, Jan 14, 2024
  8. Trollbait
    11,560
    With your use, the Level 1 is enough. It is actually enough for most people. The only time a Prius Prime needs Level 2 is for cases where the owner wants to drive more on EV than than the car's range.
    Still a power-split system like the hybrid, so yes.
    #28 Trollbait, Jan 14, 2024
    Sedril, Mendel Leisk and Eug like this.
  9. Mendel Leisk
    38,726
    ^ I've rephrased the question in my previous post.
  10. bisco
    49,490
    big if with ev batteries, you might as well buy lottery tickets
  11. Sarge
    Sarge Senior Member
    1,302
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    205/65R16 is an even better option, even closer to original 19” diameter. ;) The extra 10mm of width is not even noticeable. Works great for me so far. (y)
    Blackat and Eug like this.
  12. Sarge
    Sarge Senior Member
    1,302
    758
    2023 Prius Prime
    XSE Premium
    Sounds like you have a reasonable need to AWD, but I would also consider how many days of the year would this be a factor? I think you said you work from home, so if you really only need AWD when conditions are bad, do you have the flexibility to adjust your schedule on a handful of days per year? Because passing on PHEV means you give up a benefit you would use every time you drive, vs the convenience for a handful of days per year. I am in the GTA as well (granted, not on a mountain…), and it seems we get less and less snowfall each year. :confused:
    Regarding availability, both forms of Prius seem to be more available these days, and going with higher trims seems to be more available, as it seems more people are leaning toward the base models. If you call around you may get lucky… I stumbled onto my yellow Prime XSE Premium through a referral from @Nntw with Welland Toyota (thanks again!) on a vehicle that had no buyer, then I paid this forward referring another friend to my local dealer (Milton Toyota), who took delivery 4 days (!) after learning about it (red Prime XSE Premium). :cool: So I suggest calling around in whatever distance you are willing to travel, you may be surprised. :)
    Eug and Trollbait like this.
  13. Trollbait
    11,560
    But does Toyota have a known history with hybrid and PHEV batteries dying? The Prime battery will cost a lot more to replace than the hybrid, but how likely is either going to be needing that in 10 years and 70k miles?
    flim and Eug like this.
  14. Mendel Leisk
    38,726
    Maybe depends on the rim, but there was one, early report: clearance was so tight that hidden weights were brushing the caliper, had to be shifted.
    Eug likes this.
  15. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    Yeah, last week was the first time AWD really mattered to me this winter. But still...
    Wow good to know. I was hoping to keep the 2012 Prius Plug-In a while longer, esp. since I sunk a couple thousand bux into it for recent repairs, but if something came up soon perhaps I should just jump on it. I was hoping also to compare 2025 Camry pricing too, and also compare to the Lexus ES (mainly because of its reportedly much lower cabin noise).
    Basically the plan was to do some research over the next couple of months, and then put in an order and wait the 6-18 months for the order to come in, while driving my existing 2012 Plug-In. However, the issues with the 2012 are making me rethink my options. So far in recent times I've had to replace my front rotors and brake pads (brake pads in relatively bad shape and rotors in really bad shape) and replace my ABS module (known issue with this model). I also had error messages for the rear wheel speed sensors with the PCS light coming on. The mechanic had a look and said not only were the speed sensors were erratic, the bearings were in in poor shape and noisy (after 128000 km), so we replaced both rear hub/bearings/speed sensor assemblies too. The PCS system error message went away, but now the PCS system error message has come back. Hopefully he can diagnose what's wrong with it.
    #35 Eug, Jan 14, 2024
    Sarge likes this.
  16. Mendel Leisk
    38,726
    Is your location on Earth in the salt belt? I hate that stuff, both for vehicles and our poor dog's paws. :mad:
    Eug likes this.
  17. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    Heh. I live in Toronto. Lots and lots of salt. Also, it's outside 24/7, often just sitting in 15 cm of snow. BTW. I hadn't thought about the dog. We may be getting a dog this spring (already have a deposit with the breeder), so that's good to know. Dog shoes for winter?
    I think the salt, snow, and rain are what did in my rotors (see above). After each rain, my brakes would squeal but then after some usage the pads would scrape off the rust and they'd be fine. However, because of a collision repair, the car sat for months outside (when they sourced the parts), and when I got the car back the rotors were super rusted. Even after two weeks of usage the rotors still had major rust, and I could feel it in the braking. The collision repair shop said he couldn't claim the rotors under insurance because they weren't involved in the collision and would just be considered wear-and-tear by the insurance agent. So, I bit the bullet and just paid for the pad/rotor replacement out-of-pocket. Truth be told though my usual mechanic had told me the pads would have had to been replaced soon anyway. I had already replaced the rear rotors/pads at around 113000 km, so to replace the fronts 15000 km later isn't surprising.
  18. Sarge
    Sarge Senior Member
    1,302
    758
    2023 Prius Prime
    XSE Premium
    Yeah, I was in a similar situation with my 2014 Plug-In. The car was in good shape overall with mileage on the high end of average IMO (220K KM over 9 years), and was generally running well, but had a pesky trouble code which would come up periodically, usually after it rained that I had been putting up with for 18 months, but still ran like “normal”, as it seemed to be related to O2 or emissions (as usual). I knew I was well past battery warranty, and while I know there have been very few (any?) failures with the PiP batteries, being a pioneer with a PiP battery failure would be just my luck (given my Gen 2 had a failed battery (273K KM) AND a failed ICE at close to 400K shortly after rebuilding the battery a second time @ 390K KM, so the failed engine was when I let it go)… so I thought I would not wait so long this time.;)
    I have considered putting off the move due to personal events going on in my life, but decided not to let the opportunity pass as I didn’t know how long I would wait for the next one to come along, given it was the colour and package I wanted. :) Ask the kids say these days… YOLO. :cool:
    Good luck in your search!(y)
    bisco and Eug like this.
  19. Sarge
    Sarge Senior Member
    1,302
    758
    2023 Prius Prime
    XSE Premium
    I could see that being a potential issue if using stick-on weights as is common with alloy rims, however using steel rims for snow tires usually makes more sense for snow anyway, where the standard procedure is to to use hammer-on weights on outside rim anyway, so this is not an issue. :)
    Eug and Mendel Leisk like this.
  20. Eug
    Eug Swollen Member
    956
    211
    Earth (for now)
    Technology
    I went to a Toyota dealership and asked about the availability of various cars. They had nothing in stock of course, but I was told to order the base Prime because it's the cheapest Prime and it doesn't matter it doesn't have plug-in support because I don't drive much. I was like "Huh?" I had to tell him all Primes are plug-ins. Then I asked about the Camry, and he said they don't expect pricing on it until fall 2024, which I don't believe either, since Toyota said they're supposed to be released this spring.
    It turns out the wiring to the right front speed sensor was frayed from the prior collision, but the collision repair shop didn't pick that up, since the error was sporadic. He re-soldered the wire, and now the PCS error is gone.
