Limit charging power
Discussion in 'Gen 5 Prius Technical Discussion' started by peternumber2, Jan 10, 2024.
  1. peternumber2
    peternumber2 Member
    128
    29
    Rome
    2023 Prius Prime
    Hi all,
    I got my new prius phev yesterday, after waiting for almost three months...
    Question:
    Since I'm charging it in my garage, and I don't trust the quality of the garage's electrical wiring, I would like to use the built in option to limit amperage, but that option is greyed out in the settings menu. Why?
    Thanks
  2. KMO
    KMO Senior Member
    1,942
    672
    Finland
    2023 Prius Prime
    I recall that wasn't available in some modes, but can't remember which - try both READY mode and in POWER ON mode while plugged in.
    Might be that the cable control device is already limiting to 8A - the one Toyota supplies in Finland+France does. Although I believe you should have the 10A version in Italy - check the label and part number.
  3. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    It's not possible to switch that setting while the car is charging and there might be other times when the car is plugged in that the 8 Amp might be grayed out. 8 Amp setting should be available for sure when the car is not plugged in / unplugged.
    How long does it take to charge? If you are timing the charge please note at what 'SOC you started.
  4. Mr.Vanvandenburg
    1,352
    570
    2020 Prius Prime
    What voltage is the supply, 220-240? You could check for voltage drop on the wiring circuit when evse is plugged in, or call an electrician to check everything. In America the car on board charger is 3.3 kw. max. or 13.75 amps at 240 v.
    The amperes here is selectable only on the 120 volt charging as far as I know.
  5. peternumber2
    peternumber2 Member
    128
    29
    Rome
    2023 Prius Prime
    Thanks all for your prompt replies. Today I checked again and the 8A option was available. I enabled it. It should charge the battery in 9 hrs, starting from 0 SOC. I'LL check and report.​
    OT why didn't I get the wireless phone charging slot??? Seems that no EU trim includes it....
  6. vvillovv
    4,321
    1,509
    NY
    When the charge setting has max enabled on my Gen 4 Prime at 120 volts it takes 6 hours to charge from 0% SOC and at 220 volts it takes 2 hours If I switch on the 8 Amp setting and plug into the home 120 volt outlet I've seen the charge time estimate as high as 12 hours.
  7. peternumber2
    peternumber2 Member
    128
    29
    Rome
    2023 Prius Prime
    Here in Italy (230V), plugging it at home :
    it takes a bit less than 5 hours and limiting the current to 8A results in a bit less than 9 hrs.
    reallyreal and vvillovv like this.
