2017 12 volt battery replacement
Discussion in 'Gen 4 Prius Main Forum' started by parked, Dec 1, 2023.
  1. parked
    parked Junior Member
    37
    17
    SF Bay Area
    My 2017 12 V battery just died on the side of the road after listening to music for like 15-20 minutes, so I guess it’s time to replace it.
    When I called Costco, the guy said he knew for certain their 51R battery doesn’t fit because Toyota apparently uses slightly smaller terminals. I was pretty surprised, because I’ve never heard of such a thing.
    Has anyone else had this problem, and do you know what particular battery model I need to look for?
  2. Mendel Leisk
    40,534
    I’d check with dealership parts department first. They tend to be pricey, but it will be just what you need. Then try automotive retailers, preferably online: most will allow you to enter vehicle stats, then will show what they have that’s compatible.
    Using the radio with the car not full on is tough on the battery btw; best to have the car fully on, what Toyota calls “ready”.
    parked likes this.
  3. parked
    37
    17
    SF Bay Area
    Thanks for your reply, Mendel.
    I’ve been searching a little online, and I think the Costco guy might be mistaken.
    The Interstate Battery website says my car takes a DIN (German designation) H4 battery, which another site says is equivalent to a BCI group 140R battery. The battery posts should be regular SAE type A, so I’m not sure what the Costco guy was saying.
  4. bisco
    51,079
    easy enough to measure a post in an auto parts store
  5. FuelMiser
    FuelMiser Senior Member
    1,342
    919
    Monument, CO
    parked likes this.
  6. BiomedO1
    2,771
    1,472
    SacTown, Ca
    The Costco guy is mistaken, you've got round battery post - all the same. You've just got to make sure the positive post is in the correct position. The positive post is slightly larger than the negative post. So if you try to install a group 140 battery instead of a group 140R, you'll reverse the polarity, while attempting to install it into the car. The positive post on a group 140 battery is on the opposite side; that's if a group 140 battery exists. I know this holds true for the group 24 battery vs 24R. Not the first time I've seen an idiot do this!!!
    On a pre-ECU car, no harm - no foul. On our cars, that's several thousands is damage.
    Hope this helps....
  7. parked
    37
    17
    SF Bay Area
    Thanks for all your help, everyone.
    I did some researching over the weekend and made a spreadsheet with some basic information. (Maybe a little overkill) Hopefully it's beneficial to anyone else who needs to replace their battery too.
    I'm having problems uploading a pdf or an image, so I've linked an image of the pdf here: temp Imageq MOas T — Postimages
    If I can figure out how to upload a pdf, I'll come back and add it here.
    Bottom line: it looks like I can get an AC Delco absorbed glass mat (AGM) battery in the right size for less than I can get a traditional flooded battery. Great deal from some online sellers. I'll likely go with Summit Racing at $152+tax, free shipping, no core. Most other retailers charge $250+ for a comparable battery. The AGM will be an upgrade which should last longer and give me more radio time.
    AC Delco is a GM company, and they don't list any applications for other car manufacturers, even though some of their applications use the same exact size. I've since learned that BCI Group 140R, DIN H4, and EN LN1 are all the same batteries. Same dimensions, same terminal locations and polarity.
    Battery Group Sizes and Cross Reference Chart with pictures | BCI, EN, DIN Codes
  8. parked
    37
    17
    SF Bay Area
    Here's a pdf of my comparison shopping, with clickable links: Dropbox - Prius Batteries.pdf - Simplify your life
    A lot of the specifications from the websites are dubious. For example, Summit Racing and Rock Auto list the exact same battery, but their weights differ significantly. One site even lists two different weights within the same listing.
    #8 parked, Dec 4, 2023
  9. parked
    37
    17
    SF Bay Area
    Just following up to add a fixed link to what I found was the best deal. (The link in my pdf included a session id, which breaks it for other users.)
    LN1 AGM
    ACDelco 88866037 ACDelco Gold Automotive AGM Batteries | Summit Racing
    This is both the best battery (because it's an AGM) and the cheapest I found.
    Landed on my doorstep for $166 including CA tax, free shipping, perfectly packaged and handled. No core charge. Took about 10 minutes to install and is working perfectly.
  10. sylvaing
    sylvaing Senior Member
    1,200
    506
    parked likes this.
  11. parked
    37
    17
    SF Bay Area
    That's an intriguing upgrade. That write-up is for a 60 Ah battery, which is a 20% improvement in charge over the 50 Ah AGM battery I bought, but given enough space, one might fit an even higher capacity battery. The penalty is of course, added weight you're dragging around and dragging down your MPG with no daily benefit. The benefit for me would be those occasions where I ran the battery down listening to the radio on the side of the road or while camping.
    My old OEM battery is actually in pretty good shape still, and I might wire that up to the battery backup for my home security cameras, modem, and router.
  12. Doug McC
    Doug McC Senior Member
    1,044
    396
    Midwest
    2022 Prius
    John Kelly of Weber University warns against putting an AGM in a car designed with a lead acid battery (and vice-versa) due to charging algorithms (via the ECU) being different.
    Toyota’s replacement battery warranty beats every body else. FWIW
  13. sylvaing
    1,200
    506
    Isn't the Toyota battery an AGM type to start with?
  14. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Not in the 16-22 gen4's and 17-22 Primes. Regular old battery in the engine bay it's just a funky size
    sylvaing and Doug McC like this.
  15. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    741
    Monument, Colorado USA
    Excellent information! I've been keeping an eye on my wife's original 12-volt in her 2017 Prius 2 and, before winter, it was still testing at 100%. I'll have to go check it again since it's been wicked cold this past month. It does sit in the garage most of the time so is pampered.
    I'll call dealer for a quote on what they want but if it's over $200 probably will go with the Walmart Everstart for $159.
  16. Doug McC
    1,044
    396
    Midwest
    2022 Prius
    While you’re talking to the dealership ask about the warranty. That info might effect your decision.
  17. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    I bought a duralast gold battery from autozone for my 17 tundra and it came with a 3 year free replacement warranty. They didn't give me any trouble swapping it out for a new one after 2 years when my truck killed it by mistake - the switch for the brake lights got dislodged by the pedal and we didn't notice the brake lights stayed on after we parked and paid no attention to the truck for a month. I brought it in, they tested it, it was dead and they handed me a new battery.
    ColoradoBoo and Doug McC like this.
  18. TinyTim
    TinyTim Active Member
    374
    228
    Seattle
    Does anybody have the Toyota Part number for the 12V battery for a 2017 Prius. I am looking at the True Start batteries but they say they may not fit my Prius.
  19. ocean view
    ocean view Junior Member
    31
    Western MA
    2022 Prius
    My 2022 Prius 12v battery part number is 288800-37131.
  20. parked
    37
    17
    SF Bay Area
    I don't have the Toyota part number for a 2017, but if you scroll up to posts #7, there's a link to a BCI, EN, and DIN cross reference chart.
    Basically, you're looking for a BCI Group 140R, which is equivalent to a DIN H4 or an EIN LN1. Double check on your own battery to be sure.
    On post #8, I made a link to a chart with the somewhat extensive comparison shopping I did before finally settling on the AC Delco Absorbent Glass Mat battery I purchased from Summit Racing. It's been working perfectly since I installed it in my 2017 almost a year ago. After installing an AGM battery in my mother in law's Nissan that was draining and killing batteries like crazy, I've become a fan of that type of battery. No more problems many years out now.
    TinyTim likes this.
