Triangle of death P0A80
Discussion in 'Gen 2 Prius Technical Discussion' started by Erc32, Jan 17, 2024.
  1. Erc32
    Erc32 New Member
    New jersey
    Hi everyone so just a little info my car is a 2005 Prius 150k miles. The other day got this code no other sub codes.I have reset the codes a few times still pops up.So my options are replace with a new Toyota battery found a dealer selling for $1950 or change the bad module which I believe is only 1 bad module I will be attaching a screen shot of the torque voltages.Anyways was wondering what you guys would do change the whole battery or just the module this thing is stressing me out thanks
    Ok it's not letting me upload so here it is manually
    #1
    HV 17.7
    LV. 16.3
    #2
    HV 17.6
    LV. 16.2
    #3
    HV. 17.6
    LV. 16.2
    #4
    HV. 17.6
    LV. 16.2
    #5
    HV. 17.6
    LV. 16.2
    #6
    HV. 17.6
    LV. 16.1
    #7
    HV. 17.6
    LV. 16.2
    #8
    HV. 17.6
    LV. 16.1
    #9
    HV 17.6
    LV. 16.2
    #10
    HV 17.6
    LV. 16.1
    #11
    HV 17.6
    LV. 16.2
    #12
    HV 17.9
    LV. 14.5
    #13
    HV 17.6
    LV. 16.2
    #14
    HV 17.6
    LV. 16.2
    Battery temps 61.6 61.6 60.2
    #1 Erc32, Jan 17, 2024
    52,398
    if you plan on keeping the car, a new battery will solve the problem for a long time.
    replacing cells is likely going to be an ongoing exercise, but if you have time, much cheaper.
    PriusCamper likes this.
  3. Erc32
    Erc32 New Member
    New jersey
    Thanks for replying I'm just scared of spending 2k and then something major on the car messes up in a short time which I don't think it will the car drives great but you never know I do plan on keeping Ii use it for door dash uber which I do full time
  4. bisco
    52,398
    there's lots of good rebuilding threads here if you're interested in learning the best methods and pitfalls
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,089
    1,997
    NJ-USA
    Your data shows a bad module in block #12.
    Based on forum posts, you might have a 10% chance that "just" replacing a module will actually work and might get you 6-12 months.
    Do a bunch of research on the forum, buy some gear and used modules and you can "refurbish" your pack. Do everything right and you can get 2-3 years. Do it wrong and it won't work at all.
    Buying a "rebuilt" pack is a crapshoot. Might last 2-3 years, might last 2-3 months (or weeks). Understand the warranty because you will likely need it.
    New battery from Toyota is the most reliable path.
