Mixing Tires Question
Discussion in 'Gen 4 Prius Main Forum' started by Ravegg, Jan 17, 2024.
  1. Ravegg
    Ravegg Junior Member
    Los Angeles
    2022 Prius
    In November of 22 I put 4 Nokian WR G4 tires on my 22 Prius LE in when I was going to be driving in the snow. Well yesterday, I had an unrepairable flat over 100 miles from home. America's Tire could not match the tire and I had to get a Yokohama YK-GTX put on to get home. Since I had their warranty, I got a new tire for $22 which was less than wearing out the spare and replacing it.
    The question is how problematic is having a mixed set of tires. I have the original Toyo tires that came with the car and could go back to those, but the car seems to ride better with the Nokians.
    Thanks
  2. Tideland Prius
    16,490
    Mixing tires
    https://www.tirerack.com/upgrade-garage/is-it-ok-to-mix-tires
    Can I Mix Tires from Different Brands on My Vehicle?
    Mixing Tires | Different Tires on Car | 1010Tires.com Discount Online Tire Store
    Generally, not a good idea. It's fine to get you home in your case but I would strongly recommend finding another WR G4 and replacing that Yokohama.
    In addition, you're running 3 "all-weather" tyres and 1 "all-season" tire. That alone is a big no-no. They're different tread designs and compound. Honestly, I'm surprised they even put it on and let you go.
    Doug McC likes this.
  3. Doug McC
    Doug McC Senior Member
    1,050
    401
    Midwest
    2022 Prius
    I agree with Tideland, different tires brands have different characteristics, as do different types. Mixing tires is a risky business.
  4. JohnPrius3005
    JohnPrius3005 Active Member
    423
    234
    California and Hawaii
    Opinion from the bleachers:
    Any tires or combination of tires is fine. The only problem you will find is if you regularly drive around curves at 180mph or at the limits of centripetal adhesion. Otherwise, don't worry.
    amos likes this.
  5. Ravegg
    Los Angeles
    2022 Prius
    Thanks for the replies. America's Tire locally is getting me a matching tire and said if they tread depths are not too far off, they will change out the other tire.
    On another note, It looks like a full size tire fits in the wheel well not problem without the foam. Is there a safety reason to have the foam in place, or does it just level the back. I was thinking I could get another rim and just put a full size spare in there without the foam piece.
  6. Doug McC
    1,050
    401
    Midwest
    2022 Prius
    Good tire shop there. Mainly a weight savings and thus mpg increase. Just keep in mind the basic idea in the Prius concept (less fuel usage, better for the environment, so each ounce of fuel saved…..). There MIGHT (and that’s a BIG MIGHT) be some other dynamics affected, (due to the added weight in the rear quadrant of the vehicle) but it would take some one with significant knowledge of the design characteristics to explain it.
  7. Ravegg
    Los Angeles
    2022 Prius
    I actually called Toyota and they said generally it is ok to remove the foam. With respect to a full size spare they said they thought it is ok, but reminded me to make sure it was secured. I will post after visiting the tire store tomorrow to see how it turns out.
  8. Danno5060
    Danno5060 Active Member
    380
    197
    Wyoming
    Actual experience - no. I avoid mixed tires with few exceptions (front versus rear wear differently, so they'll never match from front to rear after driving for a few miles. I also had a bad wheel bearing which made it so half of the studs fell out of one of my winter tires after one season. I got two new studded tires and put these on the front, the year-old/same brand and type of tire went on the rear.)
    This is a holdover from my early rear-wheel drive cars. If you mixed the tires between the left and right, you could overwork the differential, causing it to fail. At least that's what the old timers said. Maybe that also had something to do with the limited-slip differentials of the day too.
    This also makes me want (okay compulsively need) to put tires with the same wear on the rear, because I know they'll eventually wind up on the front someday. Also, I don't want to have the handling go funky when I have to slam on the brakes (anymore than a Prius already does when you hit a bump during braking anyway.)
    If it were just 100 miles, I'd probably still get a pair, then get another pair that matches the originals when I got home. I'd put the other pair in storage and either sell them, or get another pair to put in storage when I can to make a future set. (I've got three Prii now, and they all take the same size tires. two sets for each - studded for winter, and highway for summer.) It's not like I won't use them at some point. That's just me though.
  9. JohnPrius21
    JohnPrius21 Junior Member
    24
    Los Angeles
    Four Touring
    Not my experience, but I’ve read where America’s Tire allowed a customer to “borrow” a tire in a pinch while the single replacement tire they wanted was on order. That way they didn’t have to buy and return a tire they didn’t really want and were going to return anyways.
  10. Mendel Leisk
    40,918
    How was it unrepairable, sidewall damaged, too close to edge of tread, just way too big, or?
    Does "it looks like" mean you've tried it, or you've just read that it can? The simplest method to check is to take one of your wheels off and try it.
    I tried this with a third gen (instead of the temp spare that does fit), and found the wider, stock tire was chafing the sides of the well, rode up about 2" higher., making it impossible to seat the hatch floor.
  11. Ravegg
    Los Angeles
    2022 Prius
    I will post a new thread with the new full size spare.
  12. Ravegg
    Los Angeles
    2022 Prius
    Having trouble uploading pictures or uploading a file, any thoughts how to do this?
  13. Mendel Leisk
    40,918
    Function’s been broken going on two months now, since commencement of thread pinned at top of page. Very frustrating. There are some laborious workarounds. Simplest is to upload elsewhere, link here.
  14. Ravegg
    Los Angeles
    2022 Prius
    Thanks, I posted the photos on Reddit in case anyone wants to have a look, thanks
  15. Trollbait
    12,417
    In other markets, a spare is available from the factory. One of the spare tire threads has the details and part numbers if have cash to spend. There is a foam piece that under the spare size tire. Mainly for the AWD model; there is a power cable that runs along the floor in them.
    There is a bolt hole for the hold down piece. The factory piece is likely sized for a temporary sized rim though.
