After egr cleaning codes remain didnt fix shaking/stall
Discussion in 'Gen 3 Prius Technical Discussion' started by William11348o, Aug 16, 2023.
  1. Melthias
    Melthias Junior Member
    63
    24
    Southern Maine
    When I mounted my catch can I took the intake off for access and in the reinstall process found that the holes in the little EGR pipe were ever so slightly off from where it screws into the intake. I loosened the screws of the intake, attached it to the little pipe and promptly forgot to go back and tighten the intake mounting bolts. When I went to turn the car on I had P3190 and P3191, but fixing the problem fixed the codes. This setup was a little different then yours, but maybe you had MAF issues, fixed them, but then left the intake bolts loose?
  2. William11348o
    William11348o Junior Member
    55
    Hawaii
    Still not running. i am wondering if my maf sensor looks ok but is actually failing. Could someone with a gen 3 and tech stream tell me what their maf reading is wiith the engine not running?
  3. ChapmanF
    15,865
    My money is on zero grams per second when the engine isn't running. What are you seeing?
    burebista and Brian1954 like this.
  4. burebista
    burebista Active Member
    169
    114
    Romania
    I have an old screenshot from Torque if it helps. :)
  5. William11348o
    55
    Hawaii
  6. William11348o
    55
    Hawaii
    0.18 mg/sec with original Denso MAF and 132.92 with cheapy version.
  7. William11348o
    55
    Hawaii
    I have torque also but my TS maf is reading 0.18, very close. However my MAP is always reading 14 psi (1 atmosphere).
    Was your engine running?
  8. burebista
    169
    114
    Romania
    As far as I remember engine was not running.
  9. ChapmanF
    15,865
    Cheapy version makes me wonder where all those 133 grams of air per second were going without the engine turning!
    100 kPa is also about one atmosphere (strictly, 1 atm is about 101.325 kPa or 14.696 psia).
