Extension Cord
Discussion in 'Prime Plug-in Charging' started by JLA704, Dec 8, 2018.
  1. fuzzy1
    10,602
    Yes. He inadvertently swapped numbers at that point.
  2. CraftyCoder
    CraftyCoder Member
    48
    65
    Washougal, WA
    2018 Prius Prime
    Good catch. I reversed them in the summary.
  3. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    A lot of the car/car information has obviously been redesigned to deal proactively with the aggressive/absurd American legal environment. The "No extension cords" bit appears to be part of their defensive strategy, not a technical issue.
    A 12 gauge, 25 foot cord is more than enough for 15 Amps. The cord you cite sounds awesome.
    jerrymildred likes this.
  4. jimm27
    jimm27 Junior Member
    Sacramento, CA
    House wiring is solid, extension cords stranded...
    I cannot recall if I'm right or left handed.
    (Sorry. It's a tic.)
  5. BiomedO1
    4,116
    2,158
    SacTown, Ca
    Just a reminder to check your extension cord ends periodically, for heat and corrosion build up. Found the socket end heating up a bit while charging, they were the cheap OEM cord ends. Cut off both ends and replaced with hospital-grade plug and socket, no issues since.
    Hope this helps someone...
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    It's a good practice to even check those once in a while. The screw terminals can loosen over time.
    douglasjre likes this.
  7. kenmce
    1,551
    523
    NY
    Where do you get these?
  8. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    12ga for 20A unless over 50ft run, Then 12ga for 15A. Per code
  9. rjparker
    10,490
    6,577
    Some house wiring is stranded particularly the higher power wiring like AC, electric ovens and main or sub panel wiring. Stranded carries more current for the same physical size.
    The primary problem with extension cords are most are very light weight 16 or 18 gauge and their receptacles are plastics rather than nylon or ceramics.
    Often an extension cord on a simple room heater drawing 12 amps will degrade at the receptacle end and sometimes melt.
    Expecting the general public to know the difference is a stretch so Toyota and room heater manufacturers alike say no extension cords.
    #29 rjparker, Jan 28, 2024
    jerrymildred and douglasjre like this.
  10. BiomedO1
    4,116
    2,158
    SacTown, Ca
    Home Depot and Lowes has them or you can order online. Just make sure they specifically state hospital grade and have the green dot on them. Hospital grade plugs and sockets must meet a min set standard; unlike those other cheap knock-offs.
    Yes, this is on a fat yellow construction grade 12AWG extension cord 100% copper stands.
  11. ChapmanF
    18,532
    I don't know if that's right or wrong; the thing I've noticed is when comparing a solid and a stranded wire that are assigned the same American Wire Gauge, the solid core is skinnier than the stranded one.
    In the big gauges, stranded is a lot easier to bend, though.
  12. sylvaing
    sylvaing Senior Member
    1,210
    514
    Current is concentrated on the surface of the wire. One solid core has less surface area that multiple strands.
  13. fuzzy1
    10,602
    At 60 Hz, copper skin depth is 8.5 mm, or 17mm diameter. That would correspond to what gauge -- about 7/0? The charts I'm seeing stop at 4/0.
    For the wire gauges used for household extension cords, this "current is concentrated on the surface" effect is de minimus.
    PS. Here is wikipedia's skin effect chart. The red dot is an approximate marker of where 12 gauge 6 gauge [edit: I initially confused radius vs diameter] copper wire lands for 60 Hz:
    #33 fuzzy1, Jan 28, 2024
    sylvaing likes this.
