2008 Prius with 3/4 warning lights and no codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PapaMurphysLaw, Feb 2, 2024.
  1. PapaMurphysLaw
    PapaMurphysLaw Junior Member
    35
    Woodridge, IL
    This morning I drove for about 3 minutes before 3 (4) warning lights came on.
    • The red triangle
    • The check engine light
    • A red icon with a car and exclamation point on the “info” display
    An hour later when starting the car to take it to read codes, another light popped up (in addition to the others) for <1 minute before disappearing
    • An exclamation point within a yellow circle that has parentheses around it.
    I went to an Autozone and the code reader pulled no codes. All systems tested passed as well.
    Due to a busy few months, I realized I’ve been forgetting to check oil. So I did that next, found the oil level was off/almost off the dipstick. I likely added just over 2 quarts to get it back to a healthy level.
    • Note: I never noticed the oil can symbol pop up
    • Note: I’m due for my oil change within the next few weeks
    The red triangle, check engine light, and red car icon have all stayed on with no change.
    The car runs mostly like normal. However, I’ve had one abnormal situation when accelerating from stop. The engine RPMs went up for ~3 sec before the car started picking up speed. This seems like a concerning issue, maybe for the hybrid battery.
    Does anybody have any input on what I can do to help fix this? I’d prefer not to go to the dealership due to the cost but I can’t think of an alternative.
    Thanks for any help you can provide
    Edit: None of the auto shops near me were able to get any codes with their readers. So I’ll be dropping off the car today at a nearby Toyota dealership to try to figure out what’s going on.
    #1 PapaMurphysLaw, Feb 2, 2024
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Your car has codes, but the reader used was not able to read them. This happens quite often, as not all readers are able to recognize hybrid codes.
    PapaMurphysLaw and Brian1954 like this.
  3. ChapmanF
    18,398
    This thread compares a number of scan tools and apps, and indicates which ones are the good bets for reading all your codes:
    Gen2 OBD2 app review | PriusChat
  4. Mendel Leisk
    41,744
    How old's the 12 volt battery? Checked it's voltage? (car off, first thing in the morning)
  5. priuslyfe
    priuslyfe Member
    248
    61
    pretty sure there is no "low oil" light. makes no sense other than to force owners to consistently check the oil level.
    when it does get low, you might notice the red-triangle flash when turning sharply. I think it means the oils goes to a side with momentum and triggers that flash. if so, stop and add oil.
  6. Mendel Leisk
    41,744
    There is an "oil can" symbol, though many would more succinctly describe it as "Aladdin's Lamp" symbol. It's for low oil pressure though, not low oil level. Problem with that, it usually comes around the time you're already screwed.
    The dipstick dimples are about 1.6 quarts (1.5 liters) apart, and there's about a pint (0.5 quart) from the bottom dimple to the tip of the dipstick. With OP saying oil was just registering on the tip of the dipstick, and his estimate of around 2 quarts added to get it back to top dimple (assuming that's what he meant by "healthy level"...), he probably had at least 1.5 quarts in there still. By no means ideal, but better than nothing.
    If "healthy level" means somewhere between the two dimples, that'll cut into that estimate of how low he got.
    #6 Mendel Leisk, Feb 2, 2024
  7. Tombukt2
    13,198
    2,386
    In my generation twos I've never noticed Aladdin's lamp or the oil can either I'm now have to go out and look I know that when the '09 which uses oil gets low on oil it will set the red triangle especially in corners and then of course when it's low enough when the car is not turning which is not good but this engine has been doing this since I got it so maybe at some point I'll put the other one nz that I have in it . But it may not make it if everybody keeps running into deer with it.
  8. PapaMurphysLaw
    35
    Woodridge, IL
    The 12V is likely nearing the end of its life. I don’t know when it was last replaced but it’s been at least 4 years, possibly 5-6.
    I couldn’t check it from a cold start but, when checked after driving, it had a 11.9V max and dropped to low 11s / high 10s with headlights on. Not excessively low but I don’t know how far below 12.4V it becomes in issue
  9. Brian1954
    Brian1954 Senior Member
    2,340
    933
    South Central PA, USA
    Take the car to a few different auto part store and have them check for the trouble codes. Maybe you will get lucky, and the scanner that they are using will report trouble codes.
    My guess is the hybrid battery. Once you get the trouble codes, you will know.
  10. PapaMurphysLaw
    35
    Woodridge, IL
    During the 6 years I’ve owned the car, I had one other time at the beginning where the oil got very low and I got the red oil can / Aladdin’s lamp symbol. Took care of it quickly and never saw it again. Didn’t see it this morning though so it’s likely that oil pressure isn’t behind this. I wish there was a low oil warning, just to have an extra precaution
    #10 PapaMurphysLaw, Feb 2, 2024
  11. PapaMurphysLaw
    35
    Woodridge, IL
    By “healthy level” I meant ~3/4 of the way to the top dimple from the bottom one, if not a little more than that. Though I didn’t get it exactly to the top dimple
  12. PapaMurphysLaw
    35
    Woodridge, IL
    That’s what I’m expecting but hoping isn’t the case. I’ve scheduled an appointment with the dealership to bring the car in and test it today/tomorrow. None of the auto shops near me were able to get any codes
  13. Tombukt2
    13,198
    2,386
    I would be hoping actually that is the case because then that solve the business Man oh wait car now is what 14 years old I know when my hybrid battery was falling on its face in my '09 I could step on the gas and make the car rev 3500 RPMs and go nowhere like the transmission was slipping in a regular ice vehicle exactly like it actually soon as I change the battery all that nonsense stopped gas mileage went right back up to 47.1 which was factory rated in 09. Put the bad battery falling on its face I was getting like 39.
  14. Mendel Leisk
    41,744
    Replacement time. After driving it should actually have a bit of "surface charge, be higher than a "healthy" level, say 12.8 or higher. 11.9 fresh after driving, and quickly dropping, doesn't bode good.
  15. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    My wise-guy split personality is about to show up....
    Weird that it's called a 12v battery, not an 11 volt battery. Although, if those voltages were read from the MFD (not a voltmeter on the batter terminals) they may be relatively normal.
    There is, but it requires an open hood, a paper towel and a stable periodicity for best results :).
  16. rjparker
    10,348
    6,474
    You have some hybrid code, most often the hybrid battery but there are others.
    You need to get the diagnosis and THEN step forward and ask questions here. If you can resist the charms and scare tactics of the service advisor. Often there are lower cost value added repairs depending on your location and sometimes your knowledge of local shops.
    As a side note, there are low cost Bluetooth obd2 hardware interfaces that work with phone apps to access most codes. Such as Car Scanner or Dr Prius. Maybe $50-$100 (hardware and upgraded app)but not totally comprehensive with less detail. Usually enough for most owners.
    $500+ scanners include XTool D7 or D8 and the Launch X431 CRP919X especially if you need a brake booster and diy installation.
    Toyota Techstream is the standard (which is going away) and still excellent for older Toyotas. None are magic bullets but used by experienced eyes help isolate the issue.
