5k Gen 3 Prime — Milky oil
Discussion in 'Gen 5 Prius Main Forum' started by Rafsdhc6, Feb 4, 2024.
  1. Rafsdhc6
    Rafsdhc6 Junior Member
    17
    Ontario
    2023 Prius Prime
    XSE
    Today I had a weird hunch to check oil on my 2023 Prime and to my shock I saw what I have never seen before, milky oil on the dipstick and oil cap also covered in creamy oil.
    This is about the 5th time I checked the oil since new, once when brand new, once around 2k, once just before oil change, once after to see if overfilled, and now 2 months after the oil change.
    I will be going straight to the dealer first thing in the morning (on EV)
  2. Zeromus
    Zeromus Active Member
    553
    308
    Ottawa Canada
    2024 Prius Prime
    SE
    Is it possible you've been running the engine too little in cold temperatures and not allowing condensation to boil off? Lots of short trips in cold weather especially can result in this on an ICE
    Just a guess though, I'm too new to this to know for sure if that's a consideration or not.
    DOHCtor likes this.
  3. Mendel Leisk
    41,784
    Yeah if you've been doing a lot of short trips it could just be due to humidity.
    How's engine coolant level in reservoir?
    douglasjre and CooCooCaChoo like this.
  4. Rafsdhc6
    17
    Ontario
    2023 Prius Prime
    XSE
    Most of my driving is in between 7-15 miles. Start up in EV and drive, engine starts up automatically and shuts down automatically. I haven’t forced a shutdown after start up yet. It does its own cycle of startup and shutdown in EV mode.
  5. Paul Gregory
    Paul Gregory Senior Member
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    It definitely seems like water in the oil. It's not catastrophic for the engine, but the best way to clear it up is to run the engine for an extended time to evaporate out the water. Take a trip to another city.
  6. Leadfoot J. McCoalroller
    8,123
    7,619
    Pennsylvania
    2018 Prius c
    It's atmospheric condensation emulsifying with the oil.
    A longer drive with more engine-on time will boil the water out.
    This happens in lots of cars without anyone ever noticing.
    Congratulations on checking your oil more often than most!
    PrimeDan and Danno5060 like this.
  7. Mendel Leisk
    41,784
    Yeah if the EV portion is the majority, could be insufficient engine warm up. The rated EV range is 44 miles; you're getting that?
    Maybe purposely run it in hybrid mode, say once a week. Try that for a while before incurring diagnostic charges at dealership.
    douglasjre likes this.
  8. Rafsdhc6
    17
    Ontario
    2023 Prius Prime
    XSE
    I’m in Toronto so it was pretty cold here a couple of weeks ago, I’m getting around 30-35 miles on EV. I do switch to HV about once a week and drive 7 miles with about 5 on the highway.
    I’m not too keen to drive with this oil so I will get the dealer to change oil and blame it on them . I mean I don’t see any mention about EV and HV operation and oil/water condensation in the manual.
  9. vvillovv
    vvillovv Senior Member
    4,322
    1,511
    NY
    I'd add to what others have posted above about driving with the engine running more often for longer times than you've posted you are currently running the engine, but only do that after changing the oil.
    If you can drive 100km with the engine on once or twice a month, that should be enough. Also, keep checking the oil after having it changed, too at least for the next 5k miles to make sure the oil doesn't get milky again.
    #9 vvillovv, Feb 4, 2024
    Rafsdhc6 likes this.
  10. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    We hope it's that. A leaky head gasket is the other alternative.
    PrimeDan likes this.
  11. vvillovv
    4,322
    1,511
    NY
    No real need to worry an owner of a fairly new Gen 5 Prime w/ 5k miles on it of the possibility of a HG leak. With an older Gen 3 Prius, than maybe.
    #11 vvillovv, Feb 4, 2024
  12. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    I wouldn't be so sure. Taking it for a long drive will either clear it up or make worse, depending.
  13. vvillovv
    4,322
    1,511
    NY
    That's exactly why the OP should have the oil changed ( as his posts describe he plans to ) and keep checking the oil for a while to make sure. Than if it gets milky again, you can post that you told us so.
  14. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    Yeah, unless he's losing coolant it's hard to call it a BHG. I've checked my oil once every other month and the coolant levels of both reservoir tanks as well. Nothing's changed except the color of the oil.
  15. Rafsdhc6
    17
    Ontario
    2023 Prius Prime
    XSE
    I checked and coolant looks fine, close to minimum line. The oil dipstick is showing about 2 inches over max.
  16. vvillovv
    4,322
    1,511
    NY
    Don't worry about HG yet. If you're taking to dealer for oil change, you can tell them about the coolant loss or not and see if they top it up like they are supposed to. Than keep monitoring the oil.
    I had milky oil at 5k miles with my 2014 PiP and dealer didn't check it at its 5k service, so I changed it myself and never had an issue with the oil after that, but I did watch the oil more closely after that to make sure.
  17. Rafsdhc6
    17
    Ontario
    2023 Prius Prime
    XSE
    I guess it’s weak spot of this type of engine design and lubrication system. But why incorporate a heat pump on top of it? Without a heat pump at low temps the engine would fire up often and prevent this problem.
  18. vvillovv
    4,322
    1,511
    NY
    That is making an assumption of why the oil got milky. I've wondered some about why it happened too.
  19. Mendel Leisk
    41,784
    Say what…
    are you for sure reading it right? Might help to pull it and wipe, then wait about 5 minutes before reinserting for the check (if oil is drawn up the tube this gives it time to drain back down). Also, the face of dipstick near towards front of car may be clearer.
    daisy555, Trollbait and Merkey like this.
  20. vvillovv
    4,322
    1,511
    NY
    It's not easy to read the Prime dip stick ( at least the Gen 4 Prime or maybe it's just mine that is so bad ). I've never seen another cars dip stick show full on one side and 1/4 to 1/2 quart low on the other side. :whistle:
    And I still don't know for sure which side is the correct level. I just add 4 quarts + at change look at the stick and scratch my head, check it again, same thing ,.,.,.,.
    #20 vvillovv, Feb 4, 2024
    daisy555, Merkey and Mendel Leisk like this.
