Valve Stem Cap Down the Oil Return?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 419 Grease Monkey, Feb 6, 2024.
  1. 419 Grease Monkey
    419 Grease Monkey Junior Member
    Houston, TX
    So, after reading dozens of threads here, I decided to do the headgasket on my wife's 2012 prius 3.
    All went well, until I bumped a rocker and the valve stem cap fell down the oil return after torquing the new headgasket on. !@#$ &*^% %!@# $%^&!!!!!!!
    Has anyone here dropped anything down the oil return ports in the head?
    Does it go straight to the pan?
    Will boroscope here after I mentally reset, but thought someone here might have done something similar.
    Will post results after FOSAR with magnets/etc.
    Photo doesnt seem to upload, but its the #3 cylinder exhaust, starboard oil return I think.
    Thanks.
  2. 419 Grease Monkey
    Houston, TX
    Update:
    3/8" (~10mm) boroscope head is just to large to fit down the oil return.
    1/4" (~6.5mm) head will fit down the return and past the shelf to the oil pan.
    There seems to be a shelf at ~8" from the top of the head, and the distance to the pan seems to be ~19-20".
    My stem cap is at ~19-20", so if I can't get it with a small magnet retriever, I'll just have to take the pan off.
  3. Mendel Leisk
    41,824
  4. 419 Grease Monkey
    Houston, TX
    I did get a small boroscope down to see it @ ~19".
    Most magnetic pickups were too wide to fit down the channel, so I used a coat hanger and a very small donut magnet and it came right out.
    Thanks for the response, your posts have been a huge help in learning and working on these cars.
    I can email photos of the special tool if anyone needs, but I cant upload photos here.
    the boroscope was this:
  5. 419 Grease Monkey
    Houston, TX
    Kenny94945 likes this.
  6. Mendel Leisk
    41,824
    Good you got it. And a cautionary tale( now we know they’re tiny enough to drop in there.
  7. Van Baggett
    Van Baggett Junior Member
    My question is my engine ran with it loose and it went into the oil return. Does this drop straight to the pan? Do I need to worry about it? Still trying to find it!
  8. 419 Grease Monkey
    Houston, TX
    Idk about running, I had mine apart and fished it out with a small ring magnet on the end of a 20AWG wire.
    I didnt take my oil pan off, but if I hadnt found it with the wire, that would have been my next step.
    Have you boroscoped it to see if it got caught on that shelf half way down?
