Whiteline & Mevotech Sway Bar Kits for 2nd Gen (?)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Danimal_562, Feb 2, 2024.
  1. Danimal_562
    Danimal_562 Junior Member
    Hello All,
    Looking for some guidance for a front sway bar kit for my 2nd Gen (2009).
    Can anyone confirm that any of these kits will work for me?
    WPS-BTF72Z WHITELINE FRONT 24MM BAR KIT for COROLLA 2003-2018/MATRIX 2003-2018, CELICA 2000-2005
    MS868128 MEVOTECH FRONT SWAY BAR KIT (26mm?) for " " (CELICA IS NOT LISTED)
    If those options will not work for whatever reason, what endlink and bushing options do you recommend for use with a stock Corolla Front Sway Bar (24mm?)?
    Thanks in advance for your guidance and suggestions
  2. douglasjre
    douglasjre Senior Member
    2,181
    719
    Null, NL
    Rockauto.com
  3. Danimal_562
    Thank you, I will definitely be using the site for future reference. Do you have any insight as to whether or not the sway bar kits(bar, links,bushings etc.) mentioned (for corolla/matrix/celica 2000-2018) will be "plug-and-play" for a 2nd gen? Thanks again.
  4. douglasjre
    2,181
    719
    Null, NL
    Nope. But I have used mevotech brand before. Don't know how long they last yet
  5. Danimal_562
    Good to know, may I ask what you're using from them and how it's doing for you thus far? Thanks
  6. douglasjre
    2,181
    719
    Null, NL
    Installed in my Corvette and 3rd gen Prius... tie rods. not enough miles to say longevity yet
    Danimal_562 likes this.
  7. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    I used the below
    OEM corolla 24mm front solid swaybar - 48811AB011
    Energy Suspension front swaybar bushings - 8.5128G
    The OEM Corolla sway bar is solid while others are hollow. I forget the "conversion" of hollow to solid (e.g. a 27mm hollow is equal to 24mm solid). This is the setup I'm using on my car and the bushing. You can use the OEM bushings from the corolla but I wanted soemthing stiffer and went with polyurethane.
  8. Danimal_562
    Thanks for sharing. What endlinks are you using? What rear bar is that? How's everything been after the install? That's the route I was considering, but think I'm going to pull the trigger on the Mevotech swaybar; about the same cost as a used corolla swaybar, slightly larger, solid, and comes with links, bushings and hardware.
  9. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    I'm on RSR coilovers so I'm on aftermarket, adjustable endlinks.
    Cusco adjustable front stabilizer links - 00B318A26
    Progress Tech 24mm rear solid swaybar - 62.2150
    Everything has been fine and great with the bars. I've done pretty much changed every bushing to polyurethane and the car has been great and solid. Here's a list of all suspension that Ive done. Not sure how far you want it go.
    RSR Coilovers - BIT081M
    Energy Suspension rear subframe bushing - 8.3121G
    Carbing rear brace - 6920500
    Carbing rear seat brace - 6980500
    Carbing steel front strut bar - 6110500
    Ultra Racing 19mm Anti-Sway Bar - UR-AR19-076(A)
    Ultra Racing rear subframe brace - UR-RL2-446
    SPC EZ shim kit (rear camber and toe adjustment) - 75600
    Spoon Rigid Collars front and rear 50261-ZRE-000 and 50300-ZGE-000
    Ultra Racing front fender brace - UR-FD3-025P
    Energy Suspension front control arm inner front bushing (set is for the front and rear bushing but I was only able to use the front) - 8.3120G
    Superpro front control arm inner rear bushing - caster adding- SPF3178K
    Eibach Pro-Alignment Camber Bolt KIT (front camber adjustment) - 5.81270K
    Superpro steering rack bushings - SPF3405K
    555 ball joints - SB-T442
  10. Danimal_562
    Wow, tastefully done! I will definitely be referencing your post for my future mods. What wheels/specs and tire size? Thanks again.
  11. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    My wheels are 15x6 +45. Tires are 195/65/15. They're the Rays Super Eco so the wheels themselves are 9lbs each. Super light and forged.
  12. Wischman
    Wischman Junior Member
    Chicago
    Where did you find the carbine rear seat brace? I can't seem to find it for sale anywhere.
    TIA!
  13. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    I ordered from Japan. I think off Rakuten Japan.
