Cold weather and snow and mountains (oh my!) What has been your EV experience?
Discussion in 'EV (Electric Vehicle) Discussion' started by Isaac Zachary, Feb 5, 2024.
  1. sylvaing
    sylvaing Senior Member
    1,210
    514
    I did the Ottawa Toronto round trip multiple times in winter and never had an issue in my Model 3 SR+. I punch in my daughter's address and the car tell me where to charge, albeit, I stop an extra time compared to summer but the car tell me as I set the destination. I never experienced what she did.
    Isaac Zachary likes this.
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,541
    1,280
    Cool!
    How many times did you have to stop? Looking at the map, that route is littered with dozens of Tesla Supercharger stations.
    On my normal route to the inlaws, it's 200 km to the first Tesla Supercharger, then another 238 km from there to the next Tesla Supercharger. (And that last leg isn't that different if I use non-Tesla quick charging stations). It's also not near as flat, with some thousand meters going up and down in altitude. But driving due East and adding 3 (summer) driving hours does keep the Tesla Supercharger stations more like 100 km appart.
  3. Isaac Zachary
    2,541
    1,280
    Ya, the EV range debate is complicated. I need to go 1 mile to work and 1 mile back. I need about 5 miles to get to anywhere in town, and 5 back. It's about 10 to my mother's house. It's 30 miles and 30 back from the nearest actual town (albeit, a dead end on the highway most of the year).
    I think owning two cars would make sense, a "clunker" EV for around town and nice ICEV for the highway. Or some sort of plug-in hybrid that does it all.
    The mistake I made with the Leaf is I had a nice new EV for around town and had to use the 1985 DIESEL VW non-turbo Golf with all its rust, black clouds of billowing smoke, and its whopping 40 hp (or at least 40hp some 700,000 miles ago) that would get me pulled over going up mountain passes with the pedal to the metal for going too slow. (The officer just wanted to make sure I was ok).
  4. bwilson4web
    16,201
    The additional battery pack need only be installed when range is needed. Otherwise, it does not have to ride around to the local grocery store or school. Weight is the enemy of EV range.
    There are more than a few efforts between 'luggable' battery packs and portable generators to extend the range of EVs:
    If that housed a PowerWall, it would make sense. But an ordinary, air cooled, unoptimized engine-generator, no.
  5. hill
    8,799
    One advantage of a much larger traction packs (ramcharger's ~100kWh PHEV class) is that it can accept DC fast charging as well as higher speeds DC - whereas traction packs in a 5 to 20 kWh PHEV pack is typically way too small for QC.
  6. bwilson4web
    16,201
    Cybertruck range extender.
  7. Isaac Zachary
    2,541
    1,280
    I was actually gathering the parts together to make a range extending trailer for the Leaf. The problem is that batteries were too expensive and with ICE's I wanted one that would comply with at least the emissions for a normal ICE hatchback of the same year. Neither option seemed possible given my budget. So we traded it for the Avalon. So far so good, except the problems with the infotainment center and the stupid fabric wheel wells.
  8. bwilson4web
    16,201
    My approach is a $15,000, 27 kWh, 2017 BMW i3-REx.
    There are salvage BMW i3 battery packs of different sizes from $1,500 to $7,000 . . . some assembly required.
    Wiki lists my 27 kWh battery at 256 kg (564 lbs.) This would easily fit on a 276 lb, 1,720 lb working load, Harbor Freight trailer.
    #28 bwilson4web, Feb 9, 2024
  9. sylvaing
    1,210
    514
    In summer, once. In winter, twice. Assuming a 100% charge before leaving.
