Rough ride
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Feb 18, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,223
    591
    Alberta
    2024 Prius Prime
    XSE
    I have noticed that my car feels every bump in the pavement, and sometimes it's painful to my recent back injury. Are the shocks stiff because it's winter here? Will the ride improve in warmer weather? Can the stock shocks be adjusted? Thanks for any replies.
  2. PriusCamper
    PriusCamper Senior Member
    13,006
    5,287
    Pacific Northwest, USA
    Prius have always had complaints about uncomfortable seats... There's probably some adjustments you can make with seat accessories? Hard to say one product is better than another though because there are so many body types.
    You can also try lowering tire pressure.
    And for me personally, I do yoga and lots of physical exercise on parts of my body as training and while I'm driving so I can drive a Prius 8-12 hours non-stop without much discomfort.
  3. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I find the drivers seat to be very comfortable for long road trips. The 19 inch wheels and low profile tires will cause a more harsh ride. Switching to 17 inch wheels and better tires will soften the ride quite a bit. Or maybe using an ergonomic seat cushion.
  4. Mendel Leisk
    41,850
    XSE has the 19” wheels? Are you running higher air pressure?
  5. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    Now I’m searching for exercises and yoga that can be done in a car. : }
  6. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    Seats are much improved over the previous generation, as is the handling which means the chassis will be stiffer. Did you test drive the vehicle before buying it?
    If you want a softer ride, trade your G5 in for a G4.
  7. Preebee
    867
    771
    Midwest
    2023 Prius
    Is PriusCamper a close relative to Gokhan? Or maybe Gokhan?
    Blackat likes this.
  8. rjparker
    10,438
    6,545
    Low profile tires are the problem. it does not matter what car you put them on, the ride will suffer.
    Being cool has its downsides.
  9. reallyreal
    reallyreal Member
    71
    61
    Italy
    2024 Prius Prime
    Check tire pressure
  10. Tooly
    Tooly Member
    51
    44
    Okanagan, BC
    2023 Prius Prime
    XSE
    It's the 19" tires on your XSE. Switch to a 17" or even 16" wheel & tire combo and it'll make a difference.
  11. Uhcoustic
    Uhcoustic Member
    55
    30
    2023 Prius Prime
    XSE
    My dealer overfilled the tires by about 12 psi when I took delivery. That could help a little.
  12. daisy555
    1,727
    715
    CT
    Would you please remind me of the pros and cons of doing this? Thanks
  13. rjparker
    10,438
    6,545
    High tire pressure gives slightly better mpg with a rougher ride. I always use the lower door jam recommended pressure.
    However no matter what you do, larger diameter wheels end up with lower profile tires (less rubber between the road and the wheel) which creates a harsher ride. The flex in the tire rubber is a major ride comfort factor.
    Uhcoustic and daisy555 like this.
  14. Mendel Leisk
    41,850
    More likely he neglected that portion (and more?) of the Pre-Delivery Inspection, that they charged you dearly for: cars from the factory often have tire pressures at max sidewall, to avoid flat-spotting. Dealerships need to drop tire pressures, but they’re very good at cutting corners, doing as little as possible.
    Uhcoustic likes this.
  15. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This is more on Toyota corp. Checking the tire pressure is no longer on the pre-delivery inspection checklist. If you're lucky, the tech doing the inspection will be experienced enough to know that models built in Japan* will need to have their tire pressure adjusted. But it's more likely the inspection will be done by a newer hire that is just following the checklist they were given.
    *models built in the US and sold in North America often do not have over-inflated tires as their static transit times are shorter
  16. 243r
    243r New Member
    Seacoast, NH
    2024 Prius
    Limited AWD-e
    Same complaint as the OP. Could there be shipping blocks in the springs which should have been removed by the dealer before delivery?
  17. daisy555
    1,727
    715
    CT
    Yikes! That’s even possible?
  18. rjparker
    10,438
    6,545
    No. Older Prii rode better. The new one corners better. Great if you like rice rockets.
