Oil consumption concern
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Feb 18, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    The last time I bought a new vehicle in the dead of winter, it consumed a lot of oil because I believed that it wasn't broken in properly -about 1 quart every 300 miles.
    I got my new Prius just after the new year, amidst a cold snap. I was concerned about the same issue, and drove it quite gently. I checked the oil after about 6 weeks of driving, and it's right on the full mark, so that's a relief.
    Gokhan likes this.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Wait, you're essentially throwing yourself under the bus for not breaking-in your previous car. Who does that?
    I'd love to know what car this was. Consuming 1 Quart in 300 miles is far more than excessive. That should have triggered a lemon buy back.
    Back to Prius: We've had our Gen 4 since new in 2016 and now have 77K miles. I've never lost a drop of oil in that time. Same experience in all our previous Prius cars.
  3. Mendel Leisk
    41,406
    Curious what was it?
  4. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
  5. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I was 20 years old when I got my first GMC pickup. I drove it home in -20 weather, and discovered the bad oil consumption soon after. I brought it to the attention of the dealer, and I'll never forget what he said, "a quart every 300 miles is about where we draw the line." I thought that was BS, but there was nothing I could do about it.
  6. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    what is your problem? I did what I could.
    I guess I'm a fool either way; for not knowing how to break in a new engine, and for not being able to get the dealer to fix it.
    #6 Paul Gregory, Feb 18, 2024
  7. Mendel Leisk
    41,406
    I think he's on your side.
  8. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    I could see dealer abuse in Alberta during the winter, before you got the truck. Driving home at -20 shouldn’t be what caused it. The Prius has 0w-16 oil and probably harder for them to abuse on the lot moving it from spot to spot, even if they try. Start cold, turn off, repeat over and over. It also has more of a fixed starting cycle. The Prius also probably wasn’t there very long.
    Very easy light throttle driving on a new engine is probably not good for it, after the warm up period. You want some moderate acceleration to seat the rings.
  9. Gokhan
    Gokhan Senior Member
    6,191
    2,449
    Paramount CA
    I didn't have any oil-consumption issue with my new Corolla and Priuses. I have always used the recommended SAE oil viscosity.
    Yes, always break in by driving very gently for the first few thousands miles (keep the speed below 55 mph as much as you can). In fact, always drive gently even after break-in, which will not only make the internal-combustion engine last longer and consume less oil, but it will also make the HEV/PHEV battery lose less capacity and last longer.
