Strange PSI issue
Discussion in 'Gen 4 Prius Main Forum' started by unigeezer, Feb 23, 2024.
  1. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    I'm a little bit baffled. I noticed my driver side front tire has been losing almost exactly 10 psi when I check it every morning. I've removed the wheel, dunked it in water, used soapy spray on the tread, the bead seal on both sides, and the valve stem and could find no evidence of a leak. Not a single solitary bubble. I usually run 42 PSI in the front and 40 in the back but every morning when I check it it has dropped roughly 10 psi down to 32 psi. It just seems to stop at that point and does not lose any further pressure. Any thoughts on why this is happening?
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Are you pumping the tire back up to 42 psi before testing for a leak? Check that the valve in the valve stem is tightly screwed in.
    JeffD
  3. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Sorry, I forgot to clarify. Yes, I inflate back to 42 psi before checking for leaks. I also checked the valve stem and it felt tight. But I went ahead and backed it of a bit and re-tightened. Now, with the electric pump still attached to the valve after inflating, it's not losing pressure.
    #3 unigeezer, Feb 23, 2024
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    Anybody gaslighting you? There are earlier threads about people messing with fuel tank levels for the entertainment value in that. Are you confident there is no tire damage? Maybe time for a professional inspection?
  5. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    I had used an external plug about 6 months ago after finding a nail in the tread. The repair was successful and there wasn't an issue until just recently so my assumption is that the plug was starting to fail even though I couldn't confirm using soap and water. But after thoroughly inspecting the tire, the bead seal on both sides and the valve and not finding any evidence of leaks there, I assumed the plug was the culprit. I have since ordered a replacement tire.
  6. trailblazer55
    trailblazer55 New Member
    Miami, FL
    2020 Prius
    I believe plugging your tire is only a temporary fix until you get a replacement tire. 6 months is a good amount of time that it held up! Hate dealing with nails...
  7. sylvaing
    sylvaing Senior Member
    1,210
    514
    Sorry to hijack but... what???
  8. vvillovv
    vvillovv Senior Member
    4,324
    1,511
    NY
    Pull an all nighter when you have a day off and check pressure every hour or two. If you don't have a second gauge and only use your electric pump gauge, get and test a second tire pressure gauge. Some gauges work better than others.
    Can you still locate / see the plug you installed 6 months ago?
  9. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Yes, the plug is visible, and seemed to still be holding as I could not see bubbles forming using soap/water with full weight of car and at 40 psi. I ended up replacing the tire.
    Doug McC and vvillovv like this.
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    It was in one of the earlier generation sub-forums, thinking Gen II. Some guys at work messing with their friend who was all about his amazing fuel economy. Somehow those guys were adding fuel to the tank (locked fuel door?) for a couple of weeks and then subtracting fuel in the same manner. Then chuckling to themselves when the story is told.
    sylvaing likes this.
  11. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    On a related note, what would be the recommended PSI that would create the best balance between optimum MPG and longest tread life?
  12. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    You will get a lot of different recommendations for tire air pressure from members on this forum. Personally, I inflated my tires to 2 PSI higher than what Toyota recommends on the label at the drivers door.
    vvillovv likes this.
