Hwy vs City Miles on PHEV Longevity
Discussion in 'Prime Main Forum (2017-2022)' started by pasta4breakfast, Feb 25, 2024.
  1. pasta4breakfast
    113
    Anaheim, CA
    2020 Prius Prime
    I know that miles on the open highway are easier on a standard ICE vehicle than city miles. When I google if this or the opposite is true for BEVs or PHEVs driven in EV mode, I do not get an answer. All I get are articles about how city miles are much better for fuel efficiency. I can't find anything on whether slower stop and go trafflc wears the car more or less. Any thoughts on how driving on the street, congested highway or open highway wears the Prius Prime in EV mode?
  2. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Highway miles will use the ICE more often.
  3. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Driving on a highway is rather easy for both the EV or hybrid side since keeping a steady speed is very efficient. The Hybrid mode is more efficient because it is switching between both powertrains. Its acceleration that's the killer for any powertrain. I've used EV mode in my Prius Prime on the highway and switched between that and charge mode. Depending on distance its sometimes more efficient to use the charge mode to get back into EV mode especially for the last leg. This is very dependent on weather and road conditions.
  4. sylvaing
    sylvaing Senior Member
    1,210
    514
    Highway driving requires more constant torque to keep the car going but city driving requires more torque burst to get the car going. Which one is more detrimental, I don't know. Same for tires. Tires have to grip the road more to go against air drag while driving on an highway but city driving requires more grip to overcome inertia (when accelerating) and kinetic energy (when stopping) while requiring less grip while driving since the lower speed means less air drag. Again, which one wears the tires more? I don't know.
  5. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    What kind of hwy driving, what location, which mode(s), what speed and how far? etc.
    What kind of city driving, which city, which modes(s), fastest speed, traffic pattern(s), rush hours and how far? etc.
    You probably still wouldn't be able to give a definitive answer that will satisfy everyone
    and probably not even anyone.
    #5 vvillovv, Feb 25, 2024
  6. Trollbait
    12,662
    With BEVs, it sounds like the high instant torque on starts leads to quicker tire wear. City will lead to more wear if that is true. The regen system means the friction brakes see little use either way.
    As for the drive systems. Well, ICEs are just violent devices. The near explosions and multitude of moving parts mean lots of vibrations. Combined to the high heat can lead to wear and break downs. At steady speeds, the system hits an equilibrium with less jarring changes in load, and there is plenty of air flow for cooling. Stop and go traffic puts more stress on things, plus the idling isn't good for oil, and that can lead to other issues.
    In contrast, an electric motor is gentle in comparison. The shaft and stator only rotates, and is spun by a non physical force. Motors just last longer by their nature compared to engines. Most end up being retired because of something else on the unit breaking, or to switch to something more efficient. For an EV, city or highway miles likely isn't going to make a difference. I don't think long periods of max speed would be good, but that is far above highway.
    pasta4breakfast likes this.
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    And there's your answer. More mpg's=more ev miles/less ICE use.
  8. Mendel Leisk
    41,850
    That's gotta spark debate.
    The one thing I can think of that's tough on engines is short trips, when the car doesn't get warmed up. One strategy we use now, with increasingly limited need for a car, is if we've got to be somewhere across town later in the day, then earlier that day: do the short-run, heavy item shopping trip and/or recycling chore. In short: consolidate trips.
    Also, if going downtown, where parking is convoluted and expensive, take transit. Kind of off-topic though.
    This is hybrid-centric thoughts. I suspect the Prius Plug-Ins are inherently tough on engines, especially when the bulk of your driving is EV, punctuated by engine cold-starts just a mile or two from getting home.
    #8 Mendel Leisk, Feb 26, 2024
  9. pasta4breakfast
    113
    Anaheim, CA
    2020 Prius Prime
    I was thinking mostly about the transmission, motor and other expensive drive train parts. I was curious because I used to charge my car at a public charging station after work. Thus I would not get on the freeway until 7pm or later after most of the traffic cleared. My work installed public charging stations early this year and I am now charging at work. Now I get on the freeway at 6pm with significant traffic. It's not completely stop and go, but there are large stretches of top speed at 35 mph and bottom speed at 5 mph with a few stops here and there. I know where the stops tend to be and I try to coast and slowly accelerate as much as I can without pissing off the driver behind me too much. It always puzzles me how people are in such a hurry to accelaerate when traffic is going no where. This has done wonders for my efficiency. I have been able to get home 35 miles without any gas, even some days in February weather without super LRR tires, but I wondered if this was a lot worse for the car or not. It seems like it is not, but not any better for it either.
  10. sylvaing
    1,210
    514
    Better not leave a space for someone to slip in!
  11. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    I have a 2017 Prime. Purchased in 2018. It is 2024 now. The range on my dash I get in Spring Time show 23 or so miles. During the colder months it can dip to 22.5 miles.
    The PHEV battery will degrade. It will degrade less the slower you drive. So if you drive with the BLUE color, I am sure the battery will last long. I drive with the RED color and that could be why I have my miles degraded.
    But then again the battery is 7 years old. So maybe it does not matter?
