2014 Prius smart key not functioning.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JeffAnd, Feb 10, 2024.
Tags:
  1. JeffAnd
    JeffAnd Junior Member
    24
    Wisconsin
    Symptoms: Doors does not unlock when you grab the door handle. The fob lock and unlock buttons do not work. On the fob you can see the LED light up when you press the buttons. The Start button does not start the car. If you use the key fob to press the start button the car starts. Standing next to the car the LED light on the key fob does not blink. Both key fobs did not work. On the dash I do see immobilizer symbol blinking. The scanner did pull a code B126A.
  2. JC91006
    JC91006 Senior Member
    16,474
    8,393
    have you tried changing the battery?
  3. JeffAnd
    24
    Wisconsin
    My sister took the key fob to the dealer ship, and they said the battery was good. She did this after the problem started.
  4. bisco
    49,372
    is the sks button under the dash set correctly?
    do you have an aftermarket remote starter?
    you can get a free 12v load test at autozone
    Brian1954 likes this.
  5. JeffAnd
    24
    Wisconsin
    I believe the SKS button is found on gen 2, not gen 3. Only the factory remote start for the Prius. When the key fob is held upto the start button the car will start. I don't think its the 12 volt battery.
    This is a 2014 gen 3 Prius. The vehicle is not transmitting the SKS signal to the key fob. The vehicle is not receiving any signal from the key fob.
    Does the gen 3 key fob red LED blink when it's next to the car? Does it blink even when next to a different gen 3 Prius? NOTE: Both key fobs must have the same FCC number. It will have a ACX or AAB in the FCC number. The vehicles must have the same number.
    #5 JeffAnd, Feb 14, 2024
  6. JeffAnd
    24
    Wisconsin
    Update: My sister took her 2014 Prius to a locksmith to add a key, and he could not pickup the oscillator signal. It's at this point he refused to work on the car. The vehicle has an aftermarket Viper remote start that was installed in 2016. I would like to remove the Viper remote start. Because this is suspected possible cause.
  7. bisco
    49,372
    all the best!
  8. JeffAnd
    24
    Wisconsin
    Some interesting information about the smart key module behind the glove box. They seem to come in two different colors. Red for for the ACX key fobs, blue the AAB key fobs. I suspect this what is going on for gen 3 Prius. The replacement module will need to be programmed back into the car via toyota tec software. Key fobs need to be reset in order to be reused. Autel KM100 key program tool.
  9. JeffAnd
    24
    Wisconsin
    I have purchased a used SKS module off of Ebay, in case the aftermarket remote start removal does not work. I believe the SKS smart key module needs to be paired with the other modules in the car. Like body control and steering column lock. If any one with knowledge in this area please chime in.
  10. JeffAnd
    24
    Wisconsin
    Removing the Viper remote starting did not fix the problem with the remote and smart key functions. Next step to replace the SKS smart key module. It appears the Autel KM100 has more capabilities with respect the immobilizer than my Xtool D8. This maybe key to getting the replacement module working.
