Gen 5 TPWS solution
Discussion in 'Gen 5 Prius Main Forum' started by Downrange, Feb 28, 2024.
  1. Downrange
    Downrange Active Member
    372
    212
    2024 Prius Prime
    SE
    I'm happy to report the TPWS sensors from Tire Rack are now installed and working correctly on both my Gen 5 Priuses. For those interested, they are the "315 MHZ Tire Pressure Sensor, with Optional Black Valve Sleeve and Cap." They're only 42.00 apiece, much cheaper than the Toyota versions.
    Installing them is easier than it seems when going through the process. The pertinent manual ref is Page 522. When going through the menu, be sure to select "Settings" - "Vehicle Settings" - "TPWS Settings" - then select "Tire Set Switching" and then "Register New Valve/ID". Then select "Tire Set 1" or "Tire Set 2," whichever is pertinent (I assume Toyota has Tire Set 1 as default for the OEM wheels and sensors). It will ask if you've selected the right set, then click "Yes."
    At this point, what actually happens is not exactly what the manual says. It's a bit confusing, but the main thing is (whether or not you actually get a message saying the ID code is being performed) you need to drive above 25 mph for awhile... Don't go in reverse, not at all, so be sure you're already facing forward when you set this up. I can't tell you when it took effect, because that's not really transparent to this operation, and I started over once or twice with each car, because I wasn't sure what was happening, but, eventually the tire pressure warning light stops blinking, and goes solid, then, when they are registered, it goes out. Eureka! Call up the normal tire pressure monitor screen, and there are your readings. Hallelujah!
    Just be patient and be prepared to try several times. It almost seems to be some kind of magic, but it's just the procedure doesn't happen just like the manual says, at least in my experience. Maybe I messed up, but they did "take." Now, let's just hope it's easy to switch back to Tire Set 1 next winter.
  2. PriusCamper
    PriusCamper Senior Member
    12,982
    5,278
    Pacific Northwest, USA
    What was wrong with original TPWS sensor that required replacing them? Just wanted new wheels and tires?
    daisy555 likes this.
  3. Mendel Leisk
    41,821
    Must resist...
    Downrange likes this.
  4. Downrange
    372
    212
    2024 Prius Prime
    SE
    I wasn't being very clear: I have both OEM and winter tires/wheels for both G5s.
  5. JJNY
    JJNY Junior Member
    24
    NY, NY
    I had one set of aftermarket tpms never really work. Had to switch out for "clones." Now they work perfectly.
  6. JH26036
    JH26036 Junior Member
    37
    Boston
    2024 Prius
    Limited AWD-e
    So you just wrote down the IDs and then inserted them into the car? Or is it auto-recognizing?
  7. Downrange
    372
    212
    2024 Prius Prime
    SE
    You just select tire set one or two. The computer searches for and registers the ID numbers and wheel position.
    futurist likes this.
  8. JH26036
    37
    Boston
    2024 Prius
    Limited AWD-e
    Oh okay, it is automatically doing it. That's pretty cool. Thanks.
  9. Zeromus
    Zeromus Active Member
    553
    308
    Ottawa Canada
    2024 Prius Prime
    SE
    Mine didn't work with the aftermarkets at first because the stalks weren't programmed correctly to be read by the car. But once they were reset they work a dream.
  10. bunnygovroom
    bunnygovroom New Member
    nope
    2024 Prius Prime
    XSE Premium
    thanks for this post! you helped get my new TireRack snow tire set registered!
  11. Xse
    Xse Member
    73
    29
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
    what wheel /tire package did you get
  12. bunnygovroom
    nope
    2024 Prius Prime
    XSE Premium
    - 16x7 MOTEGI RACING MR116 BLK RED ST
    - 205/65R-16 Bridgestone Blizzak WS90 SL
    fit perfectly and i was able to plow through several inches of snow like butter
  13. Gokhan
    Gokhan Senior Member
    6,469
    2,588
    Paramount CA
    It is probably the same made-in-China part as the OEM part.
    Incidentally, I was shocked to see it on the window sticker that the Prius parts are now part Chinese, like 10% at the moment. My 2021 Prius Prime Limited was 100% Japanese. But then, China is the new Japan, isn’t it?
  14. longshot
    longshot Junior Member
    83
    How long did you have to drive before it finally picked up? I bought aftermarket. They say 433mhz so based on what you used, these won't work?
  15. Gokhan
    6,469
    2,588
    Paramount CA
    Actually, I was wrong. The Toyota OEM Pacific Industrial Co., Ltd. is warning about Chinese TPMS knockoffs.
    Beware of imitation TPMS transmitters (says Pacific) | PriusChat
