2017 Gen 4 with 500k miles
Discussion in 'Gen 4 Prius Main Forum' started by PriusV17, Mar 2, 2024.
  1. PriusV17
    PriusV17 Active Member
    337
    169
    CA
    2017 Prius v wagon
    HV batteries still good. No blown head gasket.
    So what makes one driver push the limit and the car still runs good. And another driver blows a head gasket?
  2. Mendel Leisk
    41,828
    With 4th Gen, mostly heat recovery system’s manufacture date.
    bisco and hill like this.
  3. hill
    8,898
    Term for the day -
    "outlier"
    I'd read that cars seldom make it beyond the 200K mile category (< 2%) .... but it's not engine failure that causes this, rather chassis / body rust.
    Seems (afaik) the biggest distance champ GM volt is 'only' up to a mere 400K miles.
    This Chevy Volt Has 400,000 Miles On Odometer With No Noticeable Battery Degradation
    Irony is their gen1 had prius-like egr issues too. 2nd gen has egr cooler - ostensibly to reduce egr issues.
    Whatever you drive, it's like winning the lottery when a car goes for that long with only minor issues.
    #3 hill, Mar 2, 2024
  4. Mr.Vanvandenburg
    1,357
    579
    2020 Prius Prime
    Discounted from 11000 to 10990. Bodes well for G4 owners. I don’t think the total miles I’ve driven is as much as this car.
  5. PriusV17
    337
    169
    CA
    2017 Prius v wagon
    This could be a world record. I wonder if Toyota would buy the car out if they found out about it. :cool:
  6. bisco
    52,292
    YouTube
  7. hill
    8,898
    Not likely. That would require Toyota to actually acknowledge there was a problem. Good luck with that.
  8. PriusV17
    337
    169
    CA
    2017 Prius v wagon
    Seems that an ICE car is no different than a human body. A car will need regular exercise (running at high rpm) to help clean out the carbon build ups. Unless this driver is adding any special additives. The problem is, if your carbon build ups are so bad that driving at high RPM can blow out a head gasket (heart attack).
  9. bisco
    52,292
    But that was gen 3, and Toyota says they are caused by bad coolant pump software.
    I’m not claiming any gen 4 have gone half a million miles without a blown head gasket, but it’s certainly possible
  10. BiomedO1
    4,022
    2,113
    SacTown, Ca
    If anyone here buy's this car; Please report back engine oil consumption if any or if they run into a traction battery pack issues. Do check and clean the traction battery air cooling system ducts, doors, and fan assemblies.
    Thanks in advance.
  11. PriusV17
    337
    169
    CA
    2017 Prius v wagon
    It's makes you wonder if it's humanly possible to reach 550k in 6 years.
    This is a rough calculation of miles and gas per day fill up.
    550,000 miles
    5 day work week = 260 days/yr * 6 years = 1,560 days
    550,000 miles / 1,560 days = 352 miles/day
    352 miles / 50mpg = 7 gallons per day
    So almost every work day this person was filling up on gas.
  12. PriusV17
    337
    169
    CA
    2017 Prius v wagon
  13. Mendel Leisk
    41,828
    I don't stand a chance. Christmas Eve our '10 went past 100,000 kilometers. Last time I shut down, couple of days back, it was at 100,500 something...
  14. hill
    8,898
    500k miles .... It necessarily would have gone through CV joints as well as possibly 10 sets of tires & at least one break job
  15. PriusV17
    337
    169
    CA
    2017 Prius v wagon
    At average of 65mph per day that is 5.4hrs of driving per day. Imagine sitting and driving 5.4 hrs every work day for 6 years. Toyota needs to reward this owner for reaching 540k miles in 6 years and buy the car out and put it in a museum.
  16. sclevine
    sclevine Active Member
    167
    160
    Northeast Florida
    2024 Prius
    I didn't get anywhere near 540k on my 2017, but I did get to 295,000 before gifting it to my daughter recently. I had the heat exchanger issue around 200,000 miles and got a new catalytic converter, but otherwise the car was completely problem free. Dealer serviced every 10k. Quite a bit of wear and tear on the inside (steering wheel, center console, driver side door inside, etc, and more recently fading inside from the hot FL sun where I've been for the last 4 years. The wear on the inside was worse than I expected, as opposed to the car in the video which seemed to be in better shape inside. My car did develop several rattles, which was very annoying.
    In terms of getting to high mileage, besides a long work commute, some people live in places where things are pretty spread out. Here in Jacksonville, I average around 500 miles per week and I work from home. Frequent long haul road trips could be another contributor - in my case, we do a ton of long road trips. FL/NYC and FL/Ohio FL/NYC/Ohio multiple times per year and usually 1 long trip west and another trip to Texas. The last 4 years I put 45,000-55,000 on it each year and I can see people doing more if they really road trip.
  17. Mr.Vanvandenburg
    1,357
    579
    2020 Prius Prime
    The 1957 Chev sedan delivery on their site captivates me much more. So much work done to it. 35k though. This Prius seems to be gone. Great advertising for them.
  18. Dfitz
    Dfitz New Member
    Huntsville, AL
    Four Touring
    What were the initial symptoms of this heat exchanger issue? I wasn't aware this was a thing with the gen 4.
  19. sclevine
    167
    160
    Northeast Florida
    2024 Prius
    The obvious sign was the engine overheating light coming on and lack of heat through the vents (it was wintertime). The subtle sign that I ignored for a couple of months was a bit of an odd gurgling sound that must have been the coolant sloshing when it wasn't full anymore.
