Just replaced the traction battery with K2 Energy LFP26650P LiFePo4.
Discussion in 'Gen 2 Prius Main Forum' started by Shawn Wandell, Sep 17, 2022.
  1. Shawn Wandell
    Shawn Wandell Junior Member
    Knoxville, TN
    I need to figure out how to capture the data. I have just replaced the traction battery with one I've fashioned together with K2 Energy LFP26650P LiFePo4 cells. The batteries were free. A local junk/scrap dealer came across these and didn't know what to do with them and listed them on facebook marketplace for free. I wasn't the first to respond but I was the first to show up at their warehouse. I ended up with 17 military modules plus one master control unit. Each module has two banks of 80 batteries in 20s4p configuration, 64V each 10.2 amp hours. At first I took one of the battery banks apart... lots of sparks! After the difficulty of trying to separate the spot welded batteries I had to think how I could use the batteries in their existing configuration. I used 3 and a half banks, connecting the Prius voltage monitoring harness in correct sequential order every fifth row. 16V nominal with 10.4 amp hours. Total of 280 cells. Car runs! Now to see how it's going to progress... The logic for replacing the battery seems fairly straightforward, however, I have zero knowledge of how the vehicles computers will adapt to this battery. Technically, it's the same technology in a different format than project lithium battery. Crude implementation on my part, but functioning. I'm tempted to build another and go a bit further; place the harness leads every 6th row instead... for a module nominal voltage of 19.2V... Batteries are powerful, what will the ECU's do with it? I do not have the cables that go with the original modules but am thinking of attempting to utilize the master control module with 7 of the the modules as a power wall. Lot's to keep me occupied... much needed after losing my son to suicide 3 years ago. 2008 Prius touring edition. I have a 2010 with solar roof that will remain stock unless I find the lithium battery satisfactory.
    SFO likes this.
  2. Mendel Leisk
    41,791
    No clue what you’re doing, but that’s admirable self-reliance.
  3. Tombukt2
    13,244
    2,392
    Cool you have plenty of time and this is what you want to do with it there you go I can't imagine what will happen they say that nickel metal hydride battery that's been used in the Prius is pretty stout other companies have even commented on it so I don't know you're still running on the 211 volt platform so no matter what you do with a battery I guess you get more headroom etc the bigger the battery the more AH headroom all of that you have the smaller the less cool.
  4. Shawn Wandell
    Knoxville, TN
    So I had become quite pleased with the LFP battery crudely implemented and needed to make it a more permanent installation that could fit under the oem metal housing. Quite dicey as hv connections are very close to the metal case. I’m using adhesive backed thick barley paper directly on underside of housing over connection areas. It is a very tight fit. Air flow is a concern due to the tight welded configuration of the 26650 cells. I now have P0AA6 which can be cleared while driving, but after powering vehicle down it is necessary to ‘clear’ battery codes to get to READY even though no codes are showing. Something about isolation between high and low voltage systems. Due to physical limitations I moved where the safety plug connects to battery. Instead of between 4-5 it’s now between 10-11. Performance is noticeably reduced after this attempt at permanent install. Instead of ~41 mpg with stock Nimh I was getting 46-47. Also, I was seeing much higher amp draw on heavy acceleration compared to stock. Much reduced after fitting battery to metal compartment. I do think there is a ‘learning’ period required for the ECU to most effectively manage battery. I have thousands of these cells and would love to be able to successfully add more capacity in the storage area above spare tire. Looking at using a pelican style case in that space bolted to metal.
    SFO and Bill Norton like this.
  5. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Shawn, This is amazing!
    Please keep us informed.(y)
    Is this the only thread you are on with this LFP Battery Pack?
    edit: I just saw this is your #2 post.
    This definitely deserves a thread of its own!
    I wonder what the basic cells and a holder assembly would cost a DIY guy like me?
    I can't go down that rabbit hole now...
    #5 Bill Norton, Nov 15, 2022
  6. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    So you're saying the performance has reduced or improved with your DIY Battery? This whole section isn't worded clearly.
    Anyway you could could clarify?
  7. Tombukt2
    13,244
    2,392
    So then why not go a little bit taller and just don't put the tray back on top of the battery pack you can close it up but you don't have to put a tray on it or you can just set it up there I guess One more row up might give you the room you need but be negligible in the rest of the cars area
  8. Buckinghambob
    Buckinghambob Junior Member
    Virginia
    before I get too elaborate with a comment, is anybody still monitoring this. I'm still a bare bones novice at this new tech, and could use any updated results/suggestions.
