XLE/Limited: 19” to 17” tire swap?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by villageidiot2, Mar 1, 2024.
  1. villageidiot2
    villageidiot2 Junior Member
    29
    2024 Prius
    Hi all!
    I’m looking to replace the stock Limited 19” tires to 17” for slightly better fuel efficiency. I’ve been doing a bit of research and it’s one of those cases where as the more I dig in, the more confused I get (including this thread).
    Is it as straight forward as going from the stock 195/50R19 to 195/60R17 (one found in LE trim)? Or is there a more precise 17” equivalent to swap in?
    I’ve read about trying to keep the diameter similar for accurate odometer, speedometer, and MPG readouts from the car. I’m pretty much a newbie, so appreciate any advice and if someone has cracked this one yet. Thanks!
    daisy555 likes this.
  2. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    If you're not sure, there are a few resources that have helped me learn that might also help you.
    Here's a link to a Gen5 thread that is more about pics and going max size installable, but also has some sizes that can be helpful to narrow down some of the specs needed when going custom wheels / tires.
    Where’s the aftermarket wheel/tire thread? | PriusChat
    than there is this site that covers almost everything needed, once all the fitment terms are understood.
    TireSize.com - Compare Tire Sizes, Specs, Prices & more
    And this site will do all the leg work even if you don't know what the terms mean.
    Wheel-Size.com :: Global Wheel Fitment Database For Vehicles
    And @Rob43 s thread with 14 pages of posts about the Gen4 tire and wheel fitment guide - it's a lot of reading, but it you really want to learn more about what the fitment terms mean, it's a great resource along with the other linked above.
    Aftermarket Wheel Fitment Guidelines | PriusChat
  3. douglasjre
    douglasjre Senior Member
    2,097
    701
    Null, NL
    That'll be fine. No need to get overly technical. Tires wear out soon enough and you can try different sizes anyway. I don't know why people make tires into such a big deal
    Blackat likes this.
  4. Paul N
    Paul N New Member
    Pembroke, Ontario, Canada
    2024 Prius Prime
    XSE
    Big deal? Maybe not but size does matter. Going with an over all size that is different will affect your speedometer and odometer readings as they are calibrated to work with a specific over all circumference of a tire. This will also affect HV/EV mpg/e-mpg.
    Mendel Leisk and daisy555 like this.
  5. daisy555
    daisy555 Senior Member
    1,673
    693
    CT
    I have similar concerns. I don’t have the car yet but I’m being told that the XLE AWD is a heavier car and partly why it has the larger tires?? Plus if I were to switch from 19 to 17 inch tires it could interfere with the AWD system. Something about messing with the differentials and that this can’t be adjusted to accommodate for the smaller tire.
    Yes. I want the best gas mileage possible but I’m mostly concerned about these low profile tires and pot holes etc.
  6. wrtboy168
    wrtboy168 Junior Member
    70
    27
    Northern California, USA
    2024 Prius
    tire width remains the same with the swap. there is a 21.1% gain in sidewall albeit tire diameter is -1.9% smaller which is really fine. when your speedometer reads 60mph, the actual is closer to 58.9mph. it's fine.
  7. daisy555
    1,673
    693
    CT
    There would be zero issues with AWD differential?
  8. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Correct, there would be zero issues with the AWD differential. I belong to other auto forums and this issue comes up all the time. The consensus is if you're within 3% difference of the original diameter, you'll be fine. Keep in mind that a wider tire, say for example going from 195 width to 215 width would have some impact of your MPG but it would be barely noticeable. See the following site for tire and size differences and how it would affect the car's performance. Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
    #8 HacksawMark, Mar 3, 2024
  9. Blackat
    Blackat Active Member
    408
    272
    Colorado
    2023 Prius
    Limited AWD-e
  10. PandaBOT
    PandaBOT New Member
    Colorado
    2023 Prius
    XLE AWD-e
    Have you tried the 195/60R17 on the AWD XLE? I just blew a tire today and the wait time for a new one is about 30 days! I asked the dealership about doing this switch, but they don't have any experience with the new Prius and don't know if it'll clear the brake calipers.
  11. MIkeDr
    MIkeDr Active Member
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    You should be fine. See the attached. Your speedometer will read 2% slower … and that’s assuming everything is perfectly calibrated to begin with. IMG_1981.jpeg
    zare34 likes this.
  12. villageidiot2
    29
    2024 Prius
    I have a LTD FWD, which has the same size tires as the AWD XLE. I actually ended up going with a 205/65/16 and it fits (actually closer to spec and more tire selection). So, I would imagine the 17” would fit too.
  13. ingénieur
    ingénieur Junior Member
    26
    Drummondville
    2001 Prius
    I have a Prius 2023 LTD AWD, i installed aerodynamic mag 17 x 6.5J Fast EV01+ Titanium (Fast Part Number: FE01N(+)-1765-65TN+38C661) with 195/60R17 tire. It works really well and has 38 mm offset (Near Prius spec: 40 mm). I installed 66.1 mm to 60.1 mm hub ring and conical nuts with these wheels.
  14. villageidiot2
    29
    2024 Prius
    Just want to note for anyone curious - Looks like the next generation 2025 Camry LE retains the 205/65R16 tire size, which should help keep supply/options steady.
    Source: Zoomed in on YouTube videos of a few initial impressions that have popped up over the past few days lol.
  15. Hammersmith
    Hammersmith Senior Member
    2,010
    2,002
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    2025 Camry Tires
    LE: 205/65R16
    SE/XLE: 235/45R18
    XSE: 235/40R19
    Spare: 155/70D17
    Source: Owners Manual and Toyota.com
    villageidiot2 likes this.
  16. darkstar3274
    darkstar3274 Junior Member
    46
    2022 Prius Prime
    Any improvement in (1) gas mileage (2) road noise? (3) changes in speedometer/odometer as expected? Understand people have different motivations for changing wheels and tires. Thanks!
    #16 darkstar3274, Sep 16, 2024
  17. darkstar3274
    46
    2022 Prius Prime
    which lug nuts did you use? Thanks
