Minor bug in energy info display
Discussion in 'Gen 2 Prius Main Forum' started by davidbw, Aug 30, 2004.
  1. davidbw
    davidbw Member
    110
    29
    In front of my computer
    On the energy info display, normally when you are going forward, the wheels spin a forward direction, and when you go backward, the wheels spin in a reverse direction. I just discovered a small bug. If you are driving up a steep uphill slope, come to a stop, and remain in "drive", and then release the brake and allow the car to coast backwards, the display will show the wheels spinning in a forward direction.
  2. Sufferin' Prius Envy
    3,998
    I sure hope you aren't navigating by that! :wink:
  3. Bite
    Bite New Member
    Well, when Toyota programmed that, I'm sure they weren't expecting many people WANTING to coast backwards down a hill ;)
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    What kind of mpg did you get coasting back down the hill? I notice that I only get 4 mpg while backing up with the electric motor. Does that make sense? If I go forward I get 99.9mpg back 4 mpg. What gives.
  5. toyoprius
    toyoprius New Member
    109
    Boston
    Sheesh. I'm already having enough trouble figuring whether I'm coming or going. Toyota isn't making it easier.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I believe it's determined by the shifter selection, not the actual direction of the wheels... LOL
  7. swepri
    swepri New Member
    71
    Motala, Sweden
    hdrygas,
    Perhaps when going BACK you will get 4 mpg worth of gas BACK into the tank :D
    How is THAT for a mileage? Too bad the cruise control don't work backwards though.
    /Paj
  8. karmavore
    karmavore New Member
    65
    Madison, WI
    No, no, no... it's no bug. Your virtual wheels just happen to be spinning backwards at a rate such that they *appear* to be moving forwards. It's a common illusion.
    No need to thank me. (really)
    Brad
    p.s. speaking of spinning your wheels...
  9. Brian
    Brian Member
    480
    Bakersfield
    Yeah, does any one have those spinners on the wheels of a Prius? 8)
