Key Fob Duplication
Discussion in 'Prime Main Forum (2017-2022)' started by Kan, Mar 12, 2024.
  1. Kan
    Kan Junior Member
    35
    Las Vegas
    2022 Prius Prime
    Hi. I got me a '22 PLUGIN XLE last week. There's so much to learn and digest. It came with 1 key fob and local dealer wants to charge me $420 for a new one. I found a few on ebay but FCC ID is a bit different showing as HYQ14FLA, but mine is HYQ14FBC, so I hesitated to buy. Would ...FLA work if I took it to dealer to program? Is dealer the only option to get a key or to program it?
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    $420 doesn't sound totally out of line for a dealer. A good locksmith should be able to do the job as well.
  3. Kan
    Kan Junior Member
    35
    Las Vegas
    2022 Prius Prime
    I ended up going the dealer route and the fob they sold me has FCC ID: HYQ14FLA, and that's different than one that came with car. I certainly could have bought the HYQ14FLA off fleabay for cheap, but I didn't know if it would work. Now, I can confirm it works on FCC ID: HYQ14FBC, this is for anyone who's facing the same situation.
