P0A80 Code- but is it really the hybrid battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Mellyman666, Mar 9, 2024.
  1. ChapmanF
    17,696
    Yes, I sort of thought it might be like that, until he went and brought in P0607, which really is from the (actual!) ECM.
    In general, because a gen 3 Prius has about two dozen ECUs in it, it's ok to just say ECU when it doesn't matter which one you're talking about, but when it does matter, you've gotta say which one you mean.
    And it's best to reserve ECM for only when you are talking about the engine control module. The ECM is one ECU, but every other ECU is not the ECM. Only in ECM does the E stand for engine; in ECU it stands for electronic.
  2. Brian1954
    Brian1954 Senior Member
    1,980
    777
    South Central PA, USA
    First you need to find out exactly what is wrong with the hybrid battery assembly before you replace anything.
    I am a little confused by the three P0A80 codes that you posted pictures of back in post #27. One of them says it is a pending code, one is a stored code, and one is a permanent code. The stored code also has the freeze frame data that you posted. I am confused by the stored code, I do not understand what a stored code is. Toyota's TechStream lists trouble codes as Current, Pending, or History (permanent). So I do not understand what the Innova 3160RS scanner is calling a stored code. If I have time, I will do so research on it.
    Do you presently have any of the warning lights on your dash or is the hybrid battery cooling fan running at full speed? If not, I do not think that you have any current trouble codes. Just drive the car like you normally do, but keep the scanner close by.
  3. Mellyman666
    Mellyman666 Member
    144
    28
    Montréal
    I too didn’t get a stored code, cause in the past it’s had current written instead.
    The warning lights are all on because I didn’t erase anything.
    I just got the Bluetooth OBD2 reader and connected the dr Prius and here is my screen (to be noted this was maybe 5 mins after starting my car and leaving it at idle in 5 degree Celsius outdoor temp.
    I’m currently doing my own research and using the app to try to make sense of my data. I’m also wondering do I need to make the in app purchase to do the life expectancy test as well?
  4. Brian1954
    1,980
    777
    Is the hybrid battery cooling fan running at full speed? You should be able to hear it easily.
    The Delta SOC is showing 36%.This value should be 0.00% for a healthy battery. This is the state of charge difference between the best and worst battery blocks. This suggests that the battery blocks are out of balance with each. A top balance with a grid charger may be all you need to do, but more analysis of your battery needs to be done.
    No, but if you are curious about what result you would see for your battery, you can buy it. I am not sure what the cost is now. I purchased it about 3 years ago for ~$10US.
    The other parameter to watch closely is the voltage difference. This is the voltage difference between the highest and lowest block. That is what triggers the P0A80 trouble code. You should have someone drive your car as you watch the app and take a few screenshots when you see 50 to 80 amps of charging (during regenerative braking) and the same for discharging (during acceleration).
  5. Mellyman666
    Mellyman666 Member
    144
    28
    Montréal
    I'm assuming when/if that happens, I would then be ablle to tell which cell/cells are the problerm ones?
    Thanks again so much for your help! You're great! :)
  6. Mellyman666
    Mellyman666 Member
    144
    28
    Montréal
    Just got back from a 15 mins drive with someone checking the app; I screen recorded it all, but something seems up. As my knowledge is low in this, I don't know if the 'weird' stuff is my battery or the app lol
    1. Is the battery voltage and all the battery readings supposed to change so sporadically? I was going anywhere from 190-250v during the ride. While warming up the car before starting the test (in park), I was getting sporadic readings of like 620v and then down to 400 then down to 208 in a matter of seconds.
    2. My battery apparently never warmed up enough to do the 'full battery test'.
    3. I watched a video from the Dr Prius guy, he was talking about temp differences between the 3 diff areas of the module. When my battery when to like 600+ volts, at one point batt temp 3 was in the negatives...??
    I screenshot and attached different moments of the test. Don't know if it matters but it's current -1 degree celsius here
    Pic 1 + 2: A little after start up- idle. The 229v was at first and then 497 volt out of nowhere and then back to a more 'normal' value
    Pic 3: 3 or 4 mins after start up- still at idle.
    Pic 4: Starting to drive- city streets 30-50km/h
    I have a bunch of other screenshots but not too sure which other ones would be useful. I also used the hybrid battery while out (the doctor prius app erases codes very easily... I clicked erase code by mistake instead of check engine code and so the dashboard cleared but code still present lol). Only difference I noticed with the hybrid battery is before I could go until steady speeds of like 40km/h before it would disactivate. Now it disactivates much easier, and normally makes me go only around 10-20km/h before shutting off.
    Currently watching Dr Prius videos to learn more about interpreting this. If not I have Toyota Mechanic friend who sometimes will do me favors. Wondering if ever it is the battery and needs to be replaced, can I buy a refurbished newer model??
  7. ChapmanF
    17,696
    Weird. If there is a PID for the boosted voltage inside the inverter, those would be believable readings for that, but as battery voltages the 620 and 400 have to be bogus.
  8. Mellyman666
    Mellyman666 Member
    144
    28
    Montréal
    So I can just focus on the more « normal » in range ones? Anyways those ones were much more frequent than the random 400 and 600
  9. ChapmanF
    17,696
    Bogus as in shouldn't have been seen. Puts me in some doubt about what Dr Prius is really doing there.
    The app once had a bug in DTC decoding that got fixed, but that was different; I'm not sure how to explain this.
    The CAN protocol includes checksums, so garbled messages shouldn't be a thing....
  10. Mellyman666
    Mellyman666 Member
    144
    28
    Montréal
    Yeah it was actually really weird and I wanted to know if it was normal because I recorded my phone screen while it was testing and the numbers and bars changes so significantly in a matter of milliseconds, for like almost the whole ride...so I was wondering if the data can actually be that instable or not
  11. Brian1954
    1,980
    777
    Those are some wild screenshots of the Dr Prius app data. No the battery pack voltage should not be changing from 190-250v rapidly. Can you please check you trunk for moisture or water leakage. Corroded connections can create some unbelievable data in the Dr Prius app.
    Do you mean you used the EV mode? I would not do that until we figure out what is going on with your HV battery.
    Try using the app to read the trouble code and please post what was found.
    The first three screenshot show some wild data. The fourth screenshot (pack voltage= 225v) is more normal. Did you happen to close the app and then restart it before the fourth screenshot?
    I personally do not have any experience working on the HV battery. What I know has been obtained by reading this forum. Hopefully someone will see this thread and chime in that has some experience with a problem like this.
    Maybe ChapmanF can answer some of my questions about the battery ECU.
    1. Besides the voltage sensing wires from the battery modules, what else connects into the battery ECU. I believe that there are a total of three connectors.
    2. Does the battery ECU connect with the hybrid control ECU or does it connect with some other ECU?
    So, something is going on with the controls for the battery pack. I would be very surprised if any of the battery modules are bad.
  12. AzusaPrius
    AzusaPrius Senior Member
    2,151
    911
    Delta SOC should always be zero.
    Whatever that number is other than zero is how much the battery is overcharged.
    I would say you need a new battery.
  13. Brian1954
    1,980
    777
    Can you please explain why we are seeing all the other weird data as seen in post #47 Dr Prius screenshots?
  14. AzusaPrius
    2,151
    911
    Doesnt matter that battery is trash.
    What data are you worried about Brian?
    When your car is running the ICE while the HV battery is full, it is trying to drain the HV battery because it is overcharging.
    Delta SOC should be zero.
    You could try draining the HV battery until delta SOC is zero but watch pack voltage and keep it no lower than 220v
    But if it is an old OEM then its time to replace it already.
  15. Brian1954
    1,980
    777
    Agreed. I wrote about this in post #44.
    Wrong. I will quote what I wrote in post #44. "This is the state of charge difference between the best and worst battery blocks. This suggests that the battery blocks are out of balance with each."
    The image below is taken from the Dr. Prius App website:
    I do not understand what you are saying. Can you please explain this a little more so that I can understand.
    Maybe it is time and maybe it is not time. It could be that the battery ECU is faulty and replacing it would fix the problem. Why replace the complete battery for 3,000$CAD when a used 250$CAD battery ecu could fix it?
    More diagnostic work needs to be done on this battery to determine why the weird data is being displayed in the Dr Prius app. Hopefully, someone has experienced something similar to this before and will contribute to this thread. That is the reason for this forum.
    #55 Brian1954, Mar 19, 2024
    Mellyman666 likes this.
  16. Mellyman666
    Mellyman666 Member
    144
    28
    Montréal
    Yeah the dr prius app was going crazy a lot. I don’t know if my battery is just that bad or if the app isn’t 100% accurate. I tried the torque app to read the differences between the highest and lowest voltages per pack but never got it to work but then learnt these numbers are now measured on dr prius app as well (as opposed to older version). But I’ll show you some screenshots to explain what I mean about the app going crazy.
    Also at this point I’ve given up on the whole ´DIY fix it myself’ option because of lack of knowledge and lack of motivation lol but I’m just wondering what best option is to replace battery.
    Kind of pisses me off because I had the car inspected at a garage before buying it two years ago asking them to expressly check the battery…I find it hard to believe it went from being ´good’ in their evaluation to 41% efficiency in 2 years.
    All pics below happened within the same 15 mins test drive. I could not find correlation to speeding up, slowing down or doing something special in order to give those wild numbers
  17. ChapmanF
    17,696
    They changed things up a little in gen 3. In gen 1 and gen 2 there was a full-fledged Battery ECU that had its own network address, distinct from the HV control ECU, and you could talk to both. They both had their own codes.
    In gen 3 they don't call it the Battery ECU anymore, it's just the "battery voltage sensor" or the "battery smart unit". It connects back to the power management control ECU over a dedicated serial link, and whatever codes or live data you read on a scan tool, you're reading from the power management control ECU. The smart unit is just kind of a remote sensor annex for it.
    In the 2010 wiring diagram, there are three connectors shown on the smart unit: c1 where it connects to the car (12 volt power, ground, the serial link to the ECU, the battery current sensor, and the battery blower speed monitor signal), j1 (all the block voltage wires; this connector is orange), and z17 (the four thermistors embedded in the battery stack). The fifth thermistor, the overall "HV battery temperature" one, is wired directly to the power management control ECU.
    Yeah, it's a little weird, one thermistor wired directly to the ECU, while the other four go through the smart unit. Also, the battery blower control signals are wired straight from the ECU, while its speed monitor feedback goes to the smart unit to be communicated back to the ECU over the serial link.
    Awells80 and Brian1954 like this.
  18. Mellyman666
    Mellyman666 Member
    144
    28
    Montréal
    I will try redoing tests but I was never able to even change the delta SOC. If I’m not mistaken it stayed 34% in like all my tests….
    I tried everything; the Delta SOC does not change from 34% no matter what I try
  19. Mellyman666
    Mellyman666 Member
    144
    28
    Montréal
  20. Mellyman666
    Mellyman666 Member
    144
    28
    Montréal
    My other post didn't seem to add my responses to your questions so trying again:
