MAP sensor cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AzusaPrius, Jul 4, 2020.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,151
    911
    I have used brake cleaner and it is said not to use it but my MAP sensor didnt bug out, just use the highest alcohol you find. The WD40 will attract dirt and the MAP sensor will fail sooner than before.
    Mod Edit: Spun off from this thread: https://priuschat.com/threads/maf-sensor-cleaning.217669
    #1 AzusaPrius, Jul 4, 2020
    davecook89t likes this.
  2. Mendel Leisk
    40,919
    At least on 3rd gen, MAP sensor is pretty much swimming in oil, from the PCV.
  3. AzusaPrius
    2,151
    911
    Ahh good catch.
  4. redprius2011
    redprius2011 Junior Member
    46
    Georgia
    can i clean it with MAF cleaner?
  5. Mendel Leisk
    40,919
    That’s what I used; mighta been overkill. There appears to be 2 kinds. On our ‘10 it has what looks like a small resistor, in a plastic cage.. Later years, there’s nothing showing.
  6. redprius2011
    46
    Georgia
    can oily MAP cause engine to stay ON and increase RPM while running with ICE and breaking on speed bumps? im going to clean it with CRC MAF cleaner if it doesn't hurts the sensor.
  7. Mendel Leisk
    40,919
    I doubt it, mainly because oil in the intake manifold happens fast, with the PCV dumping in right there. Even an oil catch can doesn’t completely stop it. So oil-soaked MAP sensor is "situation normal".
    #7 Mendel Leisk, Mar 26, 2024
