head gasket?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Seymour1, Mar 29, 2024.
  1. Seymour1
    Seymour1 Member
    266
    32
    I bought a 2010 Prius 4 with many lights on the dash. The previous owner called them "christmas tree lights" and that they were intermittant. I figured it was a loose wire somewhere. He did say it needed a new traction battery as well as the 12 volt battery. I have found that it also needs the brake master cylinder (and maybe the pump) and now I am concluding that it needs a new head gasket.
    I read that to test the head gasket, I should let the engine cool overnight and then open the cap to the engine coolant container. If it hisses, then, the head gasket is good. If not, the head gasket is bad. There was no hiss. And the motor shakes after starting (I know that other problems can do this). And it looks like the coolant level is lower than a week ago.
    The Toyota dealer service guy looked at his computer and told me that it also has a cracked intake manifold (a frequent problem).
    The car has 229,000 miles, which usually for a Toyota or Honda is not very much. I read that the 3rd gen Prius is the worst and the 2010 model is the worst of the 3rd gen. Beware the first year of a new model for any car. I can do most of the labor to fix it but I am wondering if I should junk the car.
  2. JC91006
    JC91006 Senior Member
    16,768
    8,565
    There are 3 expensive things that will eventually fail on the 3rd gen
    Brake booster $1000 part
    HV battery $2000 part
    Head gasket $300 parts needed
    So just the new parts alone without labor will run you over $3000. You can possibly get used parts but you'll have to redo the labor if the used part fails again. If the car's condition is still good, then maybe it's worthwhile to fix it. But if it's in poor shape, lots of rust, bad paint, other broken parts etc, then you may have to possibly junk it.
    All the other failures will be common failures with cars over 10 years old. So if you bought a car without any of the 3 items addressed, it'll be quite an expense to get the car running again.
    Wonder likes this.
  3. Seymour1
    Seymour1 Member
    266
    32
    The car has no rust. It was in Texas for many years. The body is in good shape. I forgot to mention that the previous owner said that it burns a quart of oil every 2 fillups. And there were water leaks in around the tail lights that I have fixed.
    While I have th head off, I will inspect and clean the intake manifold, EGR parts and install an oil catch can. For the brakes, I might take a chance and not replace the booster pump but only the master cylinder.
    Thanks for the reply.
    Wonder likes this.
  4. JC91006
    16,768
    8,565
    Burning 1 quart in less than 1000 miles is pretty severe. You might want to address that while you're taking apart the engine for the head gasket. That oil buring is just going to get worse
  5. ASRDogman
    ASRDogman Senior Member
    7,577
    3,906
    Burning a lot of oil... Maybe a complete remanufactured engine?
    Hybrid pit sells them for around $2300.00.
  6. Brian1954
    Brian1954 Senior Member
    2,197
    865
    South Central PA, USA
    Junk it. It is not worth fixing with 229k miles.
    How much did you buy it for?
  7. Danno5060
    Danno5060 Active Member
    386
    198
    Wyoming
    Instead of the hiss test - they make a combustion gasses test kit that's sold at most auto parts stores. It comes with a blue liquid and a squeeze bulb. You use it on the radiator to suck in from the coolant overflow tank and the fluid turns green if there's combustion gasses in your coolant. YouTube some of the videos.
    Wonder likes this.
  8. ASRDogman
    7,577
    3,906
    That rarely works for the Prius, because the coolant leaks INTO the cylinder and
    is blown out the exhaust.
    A bore scope can look inside the cylinder and see what the piston looks like.
    Along with a coolant system pressure test. With pressure on the system it's very
    likely you'll see the coolant dripping into the cylinder, usually #1 and/or #2.
    Brian1954 and Danno5060 like this.
  9. Mendel Leisk
    41,431
    Boroscope inspection of the cylinders, preferably with the cooling system pressurized, to accelerate coolant leakage past head gasket, is what a lot are using. Or leak-down test.
    Another test: with 229K and presumably EGR never cleaned, it's virtually guaranteed you have a blown head gasket. Cars of that vintage and condition, for sale, often have a stop-leak product in the coolant, a short-term mask of symptoms.
    Between that and the oil-burning, and overall condition, maybe swap in a salvage engine?
    Consider too, just walking away from it, sell for scrap value. How much did you pay for it?
  10. ASRDogman
    7,577
    3,906
    I'm trying seafoam, for 3 oil changes. 4oz before changing and ran for 4-500 miles
    before changing. And now I'm trying the Valvoline Restore and Protect oil. It's only
    $5 more per oil change. And they said it will "restore" the engine in 3 straight oil changes.
    I've got 3000 miles on the first change now, and I just added 1qt.
    And I've been driving faster than I usually drive and using about the same amount, so it's an improvement
    so far.
    But I'm not sold just yet. I'll wait for the next 2 changes and see what happens.
    Since 90% of my driving is highway, and usually 2-3 hours at a time, it will get plenty of time
    to continuously "clean" the engine.
    If it doesn't work, I'm only out about $25.00. It's worth the chance.
    #10 ASRDogman, Mar 29, 2024
  11. Tombukt2
    12,957
    2,325
    Like I said just take your boriscope whether you buy it rent It whatever looking cylinder one and two you can look at the Piston all you want but look down and then up at the head gasket on the exhaust edge which is the edge that faces you when you're sitting in the car and there's where you'll see your water droplets they'll be there more than likely.
  12. Tombukt2
    12,957
    2,325
    Thermal somebody another makes this two-part sealer you pour one part in then you put the other and you take your thermostat out. And do it all like the label says it might work for a couple years you got really nothing to lose you're talking about spending piles of money if this works for you for a few months then so be it. It's worked quite well for a few people.
  13. Seymour1
    Seymour1 Member
    266
    32
    The master cylinder (cylinder A) for my car (47050-47140) according to my local Toyota parts dept is $1143.68 and is also the list price. If I google that part number, other dealers have it for $541, $546 or $562, which is half the price from my local dealer.
  14. rjparker
    10,139
    6,300
    You need a brake booster AND a high end scanner needed to bleed and calibrate the brake booster assembly.
    A new oem hybrid battery is possible for $2k but usually is more like $2.5k installed. It does require some disassembly of the hv battery assembly as you keep your original battery ecus, cables and fans. Of the known issues this one has a variety of used and aftermarket options, all of which are a bad idea for reliability and in one case, safety.
    With excessive oil burning due to flawed pistons and rings, you need a replacement engine. JDM used or professionally rebuilt. Installed $2500–$7500 depending on shop and used vs rebuilt. Rebuilt is your best bet as many “low mile” JDM engines used in Japan prove to be US salvage with the US vin plate removed. Rebuilt allows for revised pistons and rings that Toyota implemented mid 2014.
    There are other issues that are common as well such as clogging of radiators and heater cores if stop leak was used to water pumps and wheel bearings. Egrs clog and oil burning clog $1800 cats.
    I would punt.
    Brian1954 likes this.
  15. Seymour1
    Seymour1 Member
    266
    32
    I paid $2070 for the car and I have $400 more in it. (new 12 v battery, misc.) I will see if the tool rental place has a borescope.
    Maybe I should junk it, but the body is in good shape. I saw a youtube that the rings often stick. Before I changed the oil last week, I poured Reslone engine treatment into the engine and ran the engine for 5 minutes. When I changed plugs yesterday, the 2nd spark plug from the timing chain was wet with oil. I will keep using chemicals to hopefully unstick the rings. But this engine is famous for burning oil. If I replace the engine, it will be with a gen 4 if it will fit.
    Replacing the head gasket is no more daunting for me than replacing the engine and much less money. Of course, I might still have an oil burner if chemicals do not work.
  16. ASRDogman
    7,577
    3,906
    Check ebay. You can find a bore scope for $20 or so that works with your phone or iPad.
  17. rjparker
    10,139
    6,300
    Chemicals won’t fix these low tension rings. Many have tried, some have used everything out there. B12 Piston Soak reduced consumption for one YouTube guy who tried every product and changed the valve oil seals. But he finally resigned himself to a rebuild.
    It would not be so bad putting in a quart every two fillups if it did not ultimately clog the $2,000 cat. Some run out of oil a few times between changes.
    #17 rjparker, Mar 29, 2024
    Danno5060 likes this.
  18. Seymour1
    Seymour1 Member
    266
    32
    During my plug change yesterday, I found only the #2 spark plug wet with oil. It seems that if I would remove the #2 plug and pour "carbon eater" into the hole, the rings might unstick. How about brake parts cleaner? I saw youtubes where it was sprayed into the EGR cooler and it removed the carbon completely. (I am not serious)
    I am desparate. I will try B-12 and Sea Foam and oil treatments. If nothing fixes it, oil is cheap. Our inspection stations do not check for emissions-yet.
    Thanks for the info.
  19. ASRDogman
    7,577
    3,906
    See post #10
  20. Seymour1
    Seymour1 Member
    266
    32
