Brake fluid change at two year service?
Discussion in 'Prime Technical Discussion' started by GT4Prius, Apr 24, 2019.
  1. ZipZap
    ZipZap New Member
    Oregon
    I tried the invalid mode procedure on my 2017 Prius Prime, but it does not appear to work. Any suggestions?
  2. Mendel Leisk
    41,053
    Did you have parking brake set? It has to be, not sure why, but if it isn’t car won’t go into invalid mode.
  3. ZipZap
    ZipZap New Member
    Oregon
    Yes. Thanks for your help.
  4. ZipZap
    ZipZap New Member
    Oregon
    Actually, now I think I have bigger problems. Yesterday, after trying unsuccessfully to achieve invalid mode, I heard somewhere that invalid mode was only needed for the rear brakes. So I decided to replace the brake fluid in the reservoir by applying suction to the nipple on the right front wheel. I was able (with great difficulty) to lower the fluid level in the master cylinder below the lower limit mark. At that point I gave up for the day. This morning I tried the invalid mode procedure again, but noticed the brake pedal does not feel normal and I hear a clunk from the master cylinder every time I press the pedal. If that wasn't enough, now when I open the driver's side door, I do not hear the electric pump turn on. Have I really messed things up?
    Thanks.
  5. sylvaing
    sylvaing Senior Member
    1,210
    514
    Personally, I would try this first to see if the brake fluid needs changing.
    https://a.co/d/bgtXavP
    If not, leave it alone, but do service the brake pads.
  6. Mendel Leisk
    41,053
    I’ll dig up what the repair manual says in a bit.
    ^ I would just baste fluid out, directly at the reservoir, and refill. Be careful not to let fluid level get too low, introduce air into system (on Gen 3 at least that’s nigh impossible).
    FWIW Gen 3 info is in my signature. On a phone turn it landscape to see signatures.
    #26 Mendel Leisk, Apr 1, 2024
  7. Mendel Leisk
    41,053
    Here we go:
  8. ZipZap
    ZipZap New Member
    Oregon
    Thanks! I'll take a look at what you sent.
  9. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    Previous car was a Nissan Leaf. They require brake fluid replacement every 2 years. I had a lease and was required to pay for it in the lease terms. This was in the USA. They had some asinine argument that the brakes aren't used as much so get contaminated "some way" which just shows that not everyone who writes service manuals is an engineer. But I wouldn't change brake fluid until I got new brakes and then I'd flush the system. There's literally no point otherwise. Unless you ride the brakes all the time. Then you probably are damaging the fluid.
    BiomedO1 likes this.
  10. BiomedO1
    3,226
    1,709
    SacTown, Ca
    You can litmus and hydro test the brake fluid to see if it's still good.
    I've had 15 year old car that the brake fluid was never changed - indicated by the sludge at the bottom of the reservoir. Clean out and flush the entire system, the car would stop in half the distance it used to. Pads and shoe changes if needed - inspection done while flushing out the system.
