Cleaning Bus Bars and Nuts
Discussion in 'Gen 2 Prius Technical Discussion' started by Kris_Parker, Mar 3, 2024.
  1. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Next thing to try is the rock tumbler since tinning seems doesn't work as expected.
    I also got an example of polish copper bus bars from acenbay, looks okay, but the question is would they work the same as OEM (i.e 3-5 years no corrosion)? Just checked their website, 34.87$ for nuts and a polish copper bus bars set for gen2-gen3. I suppose buying 1000 bus bars and 2000 nuts would be a better deal, but it's not available right now.
    Personally, I tried to do what @TMR-JWAP recommended. Muriatic acid in order to get rid of corrosion (takes about 30 seconds), rinse with a water for a few times, and then using a stainless steel wire wheel polish them (this may take some time, I spent around a minute and a half per one bus bar. For example it took me approximately 40 minutes to polish all 26 copper bus bars from gen3 prius).
    Since I just did it a few times, I don't know how would they perform in a long term, and how they would look like after getting into contact with the modules.
  2. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Looks genuinely okay, good for you)
    Is this an OEM nuts? What did you do to them? Looks interesting...
    #42 Kris_Parker, Mar 31, 2024
  3. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    I ordered 5 sets of polished copper bus bars from acenbay for Prius 20, 30 and I hope that no one touched them with bare fingers.
    I need 2 sets for prius c (18 bus bars and 20 nuts) but they don’t have such a set. I'll have to take them from the sets I bought.
    I'll install one set on a 2015 primearth battery (oem replacement from Toyota) on the prius that I'm currently driving and see how they perform.
    Be careful what you try because this might happen. Based on what I saw, it looks like the sensor harness connector has oxidized at the battery computer and someone installed a new harness (sold with bus bars by Toyota) without cleaning anything.
    If I were you, I would remove the bus bars after a month to make sure that bare copper is visible on the battery side of the bus bars.
    Look not bad from this outside.
    However, the inside looks terrible
    and this is the catastrophic result. The similar thing happens when you clean bus bars with the muriatic acid.
  4. Carall
    316
    104
    Harrisonburg, VA
    These are painted a few years ago OEM nuts that I have removed many times already.
  5. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Sure thing, when I would have a chance I will check on them.
    Does fingerprints on a copper bus bars can somehow affect the performance? Is this like a headlight that you can't touch without gloves because it can get damaged?
  6. Carall
    316
    104
    Harrisonburg, VA
    Copper begins to darken and oxidize where it is touched.
    Kris_Parker likes this.
  7. Carall
    316
    104
    Harrisonburg, VA
    I received my 5 sets from Acenbay. Each set contains 27 busbars. Two sets of bus bars are enough for 3 Prius C batteries.
    The busbars appear clean with no signs of fingerprints.
    Acenbay bus bar is thicker than anything used by Toyota.
    No matter how long they last, I believe that new ones are much better than any used ones that have been cleaned.
    Kris_Parker and VZvrtny like this.
  8. Longinus876
    Longinus876 Member
    105
    Long Island
    I have to say; i checked the resistance where the 8mm nuts are tightened against the bus bars and got zero. The metal was clean when I pulled off a nut. I don't think cleaning all that stuff makes any difference. I could be wrong but I think the problems lie elsewhere.
    Brian1954 likes this.
  9. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Looks good.
    I'm agree with your statement, new ones is definitely better than the old ones but cleaned. I'm going to order some of them for myself to see how well it going to work. It also saves tons of times since you don't need to clean anything, and you can be sure that you didn't messed up somewhere while cleaning.
  10. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Thanks for your comment! I don't know if all that cleaning work is changing anything or not but you definitely need to get rid of the corrosion + replacing the nuts, that for sure. Well I didn't had any issues in the first place, I just tried to find a best way for making a refurbished battery that can be used by others without any problems.
  11. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Since I'm here, just wanted to share a pictures of 2019 hv battery that I was lucky enough to pull from a junk yard. I believe the car had 161k miles, 2008 Camry. The voltage was good enough even after sitting for a few months, the modules had the same open curcuit voltage, most of the bus bars and nuts was clean and looking new (except of a few of them) I didn't do anything except charging for 20 hours with a grid charger. Now the car is inside of my 2007 camry hybrid, showing no problem whatsoever.
  12. VZvrtny
    VZvrtny Junior Member
    24
    Just want to present a fun fact regarding these bus bars. I performed a load test on these bus bars and compared them to the OEM bus bars. The test consisted of subjecting each type of bus bar under a 60A load for 5 min as well as 10 min duration. In both cases, the temperature rise on these bus bars was on average 19% less compared to the OEM. They do in fact stay cooler because they transmit the current more efficiently than the OEM. This is directly proportional to the reduced internal resistance. According to the hand calculations, the internal resistance is approximately 20% less, which validates the correlation to the physical test under load. Nickel-plated bus bar test results were very similar as well.
  13. AzusaPrius
    AzusaPrius Senior Member
    2,221
    929
    Lets hope you used my promo code "azusa" at AcenBay.com to save some cash!!!
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    So...the 5 minute test was 4 minutes and 53 seconds longer than the typical high current period experienced by the battery under full acceleration with the pedal on the floor. What were the actual temperatures? what was the actual difference?
    Based on your results, Az is probably getting 10 more mpg and he can feel the added acceleration it provides, but what would the rest of us actually see?
  15. ttou68
    ttou68 Active Member
    351
    211
    How much of a discount?
  16. AzusaPrius
    2,221
    929
    10% discount
    ttou68 likes this.
  17. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Is it 10%? Both times when I ordered something (for 60$ and 140$) the discount was only for 1.20$.
    Tombukt2 likes this.
  18. Tombukt2
    13,290
    2,398
    Generally that's something the consumer has to stay on top of these group buys and all this and that kind of stuff your friend got us set up with this well yeah well when you ring me up I'm going to be the first one asking about $1.20 so there's always that lots of people don't know how to operate the cash register or the calculator they only know how to tell you it's $1,000.
  19. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Hey, just wanted to ask would be there an option for 1000 polished copper bus bars and 2000 nuts, same as for nickel plated? Another question is are you planning on making wire harnesses for Gen3, Prius C, Camry40 and Camry50?
  20. VZvrtny
    24
    I decided to test at 5-minute and 10-minute durations to reduce the noise in the reading of the data. In reality, the current is flowing back and forth at different rates and eventually, the heat builds up depending on the driving style, terrain, and road conditions. My focus was not so much on the peak temperature I could achieve, but mainly on how much it rises compared to the OEM under the same load conditions. I also found it very interesting that delta T was lagging similarly at the 5-minute mark and 10-minute mark, even though the actual temperature was higher the longer it was under load. The ambient temperature at the beginning of the test was 75F and the final temperature was 105F for the polished copper and 112F for the OEM bus bar. At the 10 min mark, the temperature on the polished bus bar was 115F and on the OEM it was 126F (I was getting values between 15% and 23% difference in delta T on different tests).
    The temperature itself is not the point, but what the test clearly demonstrated in my opinion is that the OEM is consistently getting hotter by approx 20% after prolonged use. You are correct that in reality, the bus bar will not experience such continuous load, but hundreds of various intensity charge/discharge cycles will still cause the heat to build up eventually. Regarding the MPG, I don't think this will have a direct impact on the MPG, I think the greater benefit, in the long run, would be the health of the modules and not the immediate MPG improvement.
