Simple door key blank and locking keys in car?
Discussion in 'Prius v Main Forum' started by whitrzac, Apr 1, 2024.
  1. whitrzac
    whitrzac Junior Member
    46
    madison
    Avid scuba diver. Looking for methods to lock they keys in the car and if there's a basic key blank available that I can use to open the door with
  2. rjparker
    10,433
    6,543
    Use mechanical key inside fob, If desired have second or third one cut.
    Only a cut key will open. A physical key will not start car.
    Every fob has a physical key.
    Air_Boss likes this.
  3. whitrzac
    46
    madison
    I was looking for a normal(ish) shaped blank key.
  4. rjparker
    10,433
    6,543
    Only one kind works
  5. Kashaf Sohail
    Kashaf Sohail New Member
    Hayden ,ID, USA
    2011 Chevy Volt
    Well, there many and a wide range of key blanks available at clksupplies...You can buy according to your need from there.
