Opening the overhead console for wiring?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Paul Gregory, Mar 31, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,217
    586
    Alberta
    2024 Prius Prime
    XSE
    I have a new dashcam, and I'd like to power it from the overhead console instead of running a wire up the pillar.
    Any tips on how to get in there?
  2. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    The panels just pop off.
    Note: Only trims with the auto-dimming mirror have the necessary power leads, others should run down the a pillar to the fuse box.
    otatrant and HacksawMark like this.
  3. Zeromus
    Zeromus Active Member
    553
    308
    Ottawa Canada
    2024 Prius Prime
    SE
    The fitcamx comes with the appropriate wiring harness, and I believe Dongar sells one for one USB power output for other brands. The prime will work no matter the model, my SE is fine with the fitcamx, no issues.
    Note that the only way to have parking mode enabled on a dash cam is to run it down the a-pillar for wiring since the piggyback adatper for TSS power will only work when the car is on or in acc mode.
    deev likes this.
  4. purplePriii
    purplePriii Active Member
    275
    122
    All Primes have the connector by the mirror, not just the auto dimming ones?
  5. Paul Gregory
    2,217
    586
    Alberta
    2024 Prius Prime
    XSE
    I believe I will be running a wire up from the fuse box to the upper console. I have some small connectors I can use for connecting the dash cam and the radar detector.
  6. onthesalt
    onthesalt New Member
    17
    seattle, wa
    2024 Prius Prime
    XSE Premium
    I was just investigating this earlier this week. I posted in this forum about the wiring on the 10pin connector but no responses. I found a constant 12V there (upper left viewed from rear) but couldn't find one on only for ACCY. Perhaps I just needed to put the car into READY. But beware of all the 12v battery drain issues. I think I'm going to to buy a LiFePO4 jump starter and wire it up as the parking mode power supply.
  7. Zeromus
    553
    308
    Ottawa Canada
    2024 Prius Prime
    SE
    The Canadian one does. I have an SE and that's how I installed my fitcamX without issue.
    Only things I need to go back and fix are the a pillar clips that don't hold as tight as if they were new, next time at the parts desk I'll grab those, and the rear camera wire can be seen through the black shroud of the hatch glass since it touches it when routed through the metal cavity.
    purplePriii likes this.
  8. purplePriii
    275
    122
    Good to know! I wired mine the old fashion way to the 12V outlet but I'd be down to change it eventually. At the time there wasn't much info but thanks for confirming it!
  9. Paul Gregory
    2,217
    586
    Alberta
    2024 Prius Prime
    XSE
    I bought the Viofo A229 Duo dashcam, but I hired the installation done. Unfortunately it mounts on the windshield at such a steep angle that it's impossible to read what's on the screen. I had to some special rigging (pics to follow).
    Tip: don't use this dashcam on a Prius with the steeply sloping windshield.
  10. soft_r
    soft_r Active Member
    183
    151
    Beverly Hills
    2024 Prius
    Is the overhead map lighting fixture a simple pull down? Or is there a trick to removing it from the roof/headliner?
    I'm wondering if for those who do not have the powered mirror hookups, if there's a tappable switched source in the overhead map lighting area.
  11. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    I install a Wolfbox G850 as dash and digital rearview mirror.
    Is a cheaper option and cover the issue to the small rearview mirror and also double down as a dash cam.
    I was able to install it myself and add a usb type A power adapter so I don't have too use the type C or 12V ports.
    I was able to hide all wires and adapter behind the rearview mirror casing.
  12. Rob Thornton
    Rob Thornton New Member
    San Diego
    2024 Prius
    That's pretty close to what i want to do! What type-A power adaptor did you use? I have a wolfbox camera too, just not the rear view type
  13. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    I used the Dongar Dashcam Power Adapter (10-pin Type B)
  14. Tekz
    Tekz New Member
    British Columbia
    2026 Prius Plug-in
    I also have an SE and was looking for a 12v lead that’s constant and also ignition-based. Since you’ve already explored it, can you share more on how you did it? Which wire/s did you tap into on the overhead console? Too many wires when I tried poking around…TIA
