Hissing sound coming from brake pedal; brake pump suddenly cycling much more.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BTubbs, Apr 6, 2024.
  1. BTubbs
    BTubbs Junior Member
    Arkansas
    2013, 178k miles
    A few days ago I noticed that my brake pump (the thing that makes the whirring noise when you open the door and whatnot) was cycling MUCH more than before. After going for a drive and shutting off the car, the pump will cycle every 10 seconds for several minutes on end. I know it's normal for it to cycle a little, but suddenly it was doing it very often.
    Then today while out and about I noticed that my brake pedal was making a repetitive hissing noise when holding the car at a stop. Here's some audio:
    The noise will stop if the brake is depressed fully, but otherwise not. Around the same time this started, I also noticed that when at slow speeds and braking to a stop, the car feels like it's "jumping" or "galloping" if you will. Like I'm driving over a bunch of small speed bumps.
    No codes yet. Brake fluid isn't low or showing any signs of leakage. Any thoughts on what this could be?
  2. ChapmanF
    17,810
    You have a leak—probably an internal one, that is, no brake fluid leaving the car, only leaking past a valve that doesn't seat properly anymore, and returning to the reservoir as it normally would when you release the brake.
    Because of the leak, the target brake pressure isn't being held. The ECU sees when the pressure drops below target, and opens valves to send additional pressurized fluid in to bring the pressure back up. This is the gallop you feel when braking to a stop; the braking pressure isn't constant. With the continuing loss of [edit: brake fluid] back to the reservoir and the need to make up the pressure, the pump must repeatedly run to return fluid from the reservoir into the pressure accumulator.
    #2 ChapmanF, Apr 6, 2024
  3. Tombukt2
    12,704
    2,270
    If you can't deal with any of this yourself you're looking at around $1,400 in parts and another 1,000 or so in labor easily Make sure your car is worth that not that you could sell it for any of that but it's worth it to you because these cars have a bunch of other problems that are going to rear their ugly head in just a few minutes you're at the perfect mileage so there's always that so you have five or $6,000 that you could spend on this car and it wouldn't bother you basically is where you're at in a nutshell to me there's no generation 3 that would be worth that in my world at all not even a 2013 or 14 persona and very nice condition red color no damage to the seats door panels and all of that I still wouldn't do it many do and you can read all their stories most of them right here It's a very big crapshoot If you like to gamble in Vegas you may take the challenge possibly I personally wouldn't do anything I would get out of that system as quickly as I could at this point before things get really silly and they are right around the corner read on throughout these posts you see here in the generation 3 section you have a month of reading easily.
  4. Leadfoot J. McCoalroller
    8,020
    7,496
    Pennsylvania
    2018 Prius c
    Pretty sure you mean brake fluid.
  5. ChapmanF
    17,810
    You're psychic, man. Fixed.
  6. Leadfoot J. McCoalroller
    8,020
    7,496
    Pennsylvania
    2018 Prius c
    Even the best writers can occasionally benefit from an editor.
    <--- coffee maker thataway shop fluids thataway --->
    Teamwork!
  7. BTubbs
    Arkansas
    I see, thank you for the reply. What kind of repair do you think I'm in for, and is the car safe to drive in the meantime?
  8. ChapmanF
    17,810
    Because the loss of pressure varies the braking you can feel, and the system is able to squirt more high-pressure fluid to keep raising it again, the internal leak is almost certainly inside the actuator (a/k/a booster, master cylinder, upper thing here), so you replace that:
    The pump (lower thing there) seems to be working and keeping up with what is asked of it. You can probably keep that. A Toyota warranty repair would change both for good measure, which you might also do if cost is no object.
  9. BTubbs
    Arkansas
    Thanks for the help. I suppose this is the infamous Gen 3 defective brake booster that I've been hearing about. Welp, in the 3 years of owning my car, this makes for the third expensive repair, after two blown head gaskets of course.
    Yep, I totally get what you're saying. I love my Prius to death but man it has given me some expensive problems. After I shell out money for this brake repair I'm probably selling it and from that point it'll be Gen 4+ or bust.
