2007 Prius DIY Stuck
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DIYohWhy, Apr 4, 2024.
  1. Brian1954
    Brian1954 Senior Member
    2,368
    953
    South Central PA, USA
    Try using Techstream to read the trouble codes. I think the app that you are using is not showing you all the codes.
  2. DIYohWhy
    DIYohWhy Junior Member
    62
    Pennsylvania
    I did before, it was subcode 591. My computer, despite turning off my firewalls and all that, deleted some of the essential files after noticing risks. So I have to find a work around. But likely the same subcode I'd imagine
  3. Brian1954
    2,368
    953
    You have other trouble codes besides the P0A09, which is shown in app. Can you please tell me what app you are using?
  4. DIYohWhy
    62
    Pennsylvania
    I have only seen P0A09 in both techstream and the app when I do the full scan I believe. Although I had these codes before, attached picture. I am using the app Car Scanner for Android.
  5. Brian1954
    2,368
    953
    You need to get Techstream working again to read all your current trouble codes. Read below:
    #25 Brian1954, Apr 7, 2024
  6. ChapmanF
    18,454
    Well, that INF code 591 legitimately goes with P0A09, and it means the code is about the VLO circuit.
    I don't think there's any fuse involved in that circuit.
    I would almost recommend looking at it the other way. If you had lots of experience, you might do ok with a Haynes or other third-party manual, figuring out on the fly the stuff they aren't telling you or they're getting wrong. If you're just getting started figuring out electrical diagnosis to start with, it's no fun having to figure that out too at the same time.
  7. DIYohWhy
    62
    Pennsylvania
    If I use the instructions you list, will it be a working version of Techstream, unpaid for? Otherwise I can just redo the process I did before and if antivirus pops up I'll add my files to the ignore list.
  8. DIYohWhy
    62
    Pennsylvania
    How much would it be to have a mechanic do this? Code P0A09 subcode 591, inverter works, small battery works, pump works, and from what you say it wouldn't be a fuse, so I'm guessing it's a broken wire or connector.
    Seems like this is going to be another project since I'll have to buy electrical equipment and more books and diagrams, assuming Haynes will be insufficient.
  9. ChapmanF
    18,454
    It would depend on the mechanic. Some will say "it's a hybrid, I won't touch it", some will say "it's a hybrid, I'll replace all the electronics and charge you $8,000".
    If you can find the one who says "oh, the code is about the wire shown on this diagram here and I've known how to troubleshoot wiring connections since high school", you might get the job done there for a reasonable price.
  10. Brian1954
    2,368
    953
    Techstream that runs inside the virtual machine is the hacked version. Nothing to pay for.
  11. DIYohWhy
    62
    Pennsylvania
    Hmm I will ask around then, in the meantime I bought an electric / wire repair kit, some electric resistant gloves, and will try to use the Haynes manual to figure things out.
  12. DIYohWhy
    62
    Pennsylvania
    I don't have an ISO of an OS to do a virtual machine but I can use that techstream then thank you
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,076
    1,992
    NJ-USA
    If you search the Gen2 Technical Discussion forum for "Techstream" and "VM", you might find something.
  14. Brian1954
    2,368
    953
    Everything you need is included in the two files that you download from the forum that I linked to. You literally can have Techsteam running in 5 minutes after you have downloaded the two files from the other forum.
  15. DIYohWhy
    62
    Pennsylvania
    Thank you. I had it working before, from a couple ways, my laptop just keeps trying to protect me from viruses and deleting crucial files eventually. Even after I turned off protections.
  16. DIYohWhy
    62
    Pennsylvania
    Will try this tomorrow thank you
  17. DIYohWhy
    62
    Pennsylvania
    After looking at the wiring diagram and these photos, one a screenshot from an inverter replacement video, I believe I'm missing the C5 plug altogether. I only have the two orange power plugs and the larger, lower and in the middle, plug, not a plug for the outlet by the orange plugs that comes out at an angle. I must have had it before replacing my ABS but throughout the job I couldn't find it. I was looking for more plugs just in case. Where would it hang or end up when loose? This must be the black plug somebody mentioned before...
