Car Issues - 2012 Toyota Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by John Raville, Mar 31, 2024.
  1. John Raville
    John Raville New Member
    Atlanta, GA
    my e-brake, slip indicator, and ABS light wont turn off on my prius. And if the video attachment is working, there is a weird repeating humming noise from what sounds like my hybrid battery that stops once i get over around 40mph. ive had battery and diagnostics run and have all came back clean. the braking has felt slightly off but not sure if that is me overthinking. any advice on what the issue could be? for context, i was rear ended about a month ago and my bumper was replaced at a Toyota collisions center. thanks in advance!
    52,417
    is the e brake dragging?
    who ran the diags?
  3. Brian1954
    Brian1954 Senior Member
    2,422
    972
    South Central PA, USA
    If the warning lights are on, you have trouble codes that should be read with a Prius capable scanner. Get the trouble codes read and then come back and post what they are. You will then receive some help for the codes that you have.
  4. Mendel Leisk
    41,948
    Do you have anything constantly plugged into OBD port? That caused sim issues for me, till I ceased.
  5. John Raville
    Atlanta, GA
    Hey guys i appreciate the responses. I do not, unfortunately i took it to the dealer and it is the R& R brake booster assembly with master cylinder. originally quoted at $5K fix for a car i spent $13K for. Apparently that part has a warranty but is expired, going to do my best to see about getting a goodwill warranty but not holding my breathe. Unfortunately, I also bought this car used at a Nissan dealership, not the Toyota one. Any and all advice would be greatly appreciated.
  6. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Self suicide?
    Paladain55 and Mendel Leisk like this.
  7. Mendel Leisk
    41,948
    Is there any other kind?
  8. Paladain55
    Paladain55 Active Member
    410
    169
    The South
    Gonna have to revert to the good ole days of driving with non assisted brakes and no abs/tcs.
  9. rjparker
    10,580
    6,636
    Shop around for an independent with Prius experience. The parts might be $600-$1000. It is several hours of work to install and another hour to calibrate and bleed.
    Get part from online Toyota dealer, some may be in your area. Validate with their online vin check. Find the mechanic shop first.
  10. ChapmanF
    18,589
    And no rears. And no regen.
    The Prius brake actuator is really not much like some extra ABS thing bolted on to a working brake system.
  11. Mr.Vanvandenburg
    1,358
    596
    2020 Prius Prime
    Maybe try another dealer for a second opinion. Sometimes abs wheel sensors go out and what about a brake flush?
  12. Paladain55
    410
    169
    The South
    Whew yikes
