Should I change 17 y/o brake fluid
Discussion in 'Gen 2 Prius Main Forum' started by nancytheprius, Apr 11, 2024.
  1. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    Just moved from Midwest to soCal. Brake fluid is original to 2006 Prius with 119k miles. Should I get the brake fluid changed at this point? Will new fluid worsen brake actuator like new trans fluid on a traditional ICE car if replaced too late?
    Need input
    iPhone ?
  2. Tombukt2
    13,290
    2,398
    Yes but you don't have to do anything too crazy undo one of the fittings on the reservoir output over there on the passenger side of the car and bring the level and the reservoir down to almost nothing You see it disappearing in the connection for the lowest tube for output now clamp off that last hose that the fluid is just beginning to run out of clamp it off clamp off the other two disconnect the reservoir take it out of the car and clean it Wash it with soap and water whatever it is you do doesn't really matter You don't want to damage the plastic with super heavy crazy cleaners treat it like a plastic cup or mug Dawn will do or install a new one whatever trips your trigger once that's all cleaned renewed nice dry return it to the car He can put the three tubes on the three fittings on the jug that feed the components over on the driver side of the car now what I usually do is maybe unconventional I go to one of the front wheels and crack the zerk bleed fitting so fluid is now dripping out of that zerk fitting while I'm doing this so fluid is leaving the tube in the reservoir that you left some fluid in going through the actuator and coming out that one fitting so now I wait about 10 or 12 minutes and that should start moving the fluid that was in that tube that we left fluid in You should start seeing it run down if you try and look down the tube you might see it there's a lot lower than it was we'd like it to get all the way to the actuator when we think this sort of thing is happening then we can fill the clean reservoir up with dot four brake fluid all the way up to where the cap goes You're going to bleed it down and let it run down to the full mark this is going to take a while. If you don't like that methodology because old fluid is going to be in a few of the tubes going to the wheels that you don't have open you can manually bleed the brakes like you used to do except on the Prius you start in the front first pumping pumping pumping holding assistant cracks squirts repeat boring I know but it'll move the fluid quickly You can't take on any air now because the reservoir is full The clamps are undone and every time you pump fluid out of one of the wheel fittings that much more fluid is starting to leave the reservoir so you go around to each wheel and do the open and closing about 10 times per wheel and you should be at new fluid at the zerk fitting which is what you're undoing and closing and then that will net you new fluid through the actuator to the wheels and you're good there could be some old fluid still in the master cylinder the part that actually is connected to the pedal but it won't be much to talk about and eventually it will somewhat be mixed with the other You're talking probably less than an ounce of fluid mixed with that whole reservoir of new fluids so there's always that certainly this will outlast the car and your time together for sure.
    nancytheprius likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,985
    5,281
    Pacific Northwest, USA
    I'd wait till 20 years, personally... Lol
    Or more to the point 50 years ago the short lifespan of your car could be dramatically extended by changing all the fluids often, but not so much these days.
    What's more, there's a theory on here that may be true, which is that your super expensive brake booster pump can experience just enough changes during a fluid change that it will fail soon after. This probably has more to do with the mechanic doing the job than the pump itself, but definitely something to consider.
    I'd like to know what @ChapmanF says about how a mechanic could possibly damage a really old brake booster pump doing a fluid change? How much of a risk is that?
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,264
    870
    Monument, Colorado USA
    I'm uncomfortable going more than 5-years.
    But you can do a test on the fuid that's in there with test strips. I'm guessing you'll want to get it changed out ASAP afterwards.
    So I guess we can't upload links or pictures...search on Amazon for:
    Phoenix Systems 8006-B Double-Ended Brake Fluid + Coolant Test Strips (15 foil wrapped test strips), 1 Pack
    VelvetFoot and sylvaing like this.
  5. nancytheprius
    365
    156
    iowa
    I got the test strip and the strip didn’t change colors. Not sure if my brake fluid is just too far gone or if the strip was defective
  6. ColoradoBoo
    1,264
    870
    Really? I test both my Tundra (which I just did a brake fluid flush and fill) and my wife's 2017 Prius and got good readings with both coolant and brake fluid. Did you use the correct ends that are marked?
  7. nancytheprius
    365
    156
    iowa
    Yes! The coolant showed up and tested okay but not the brake fluid!
  8. Mendel Leisk
    41,826
    Toyota Canada recommends 3 years or 48k kms, whichever comes first. Toyota USA doesn't say anything.
  9. nancytheprius
    365
    156
    iowa
    What does Toyota Canada recommend when it’s been 17 years and you haven’t touched it yet haha
  10. Tombukt2
    13,290
    2,398
    Actually if it's clear in the reservoir and everything looks good not turning black or brown it's probably fine I have 26-year-old pure silicone purple silicone brake fluid in a AE something one of the first A engine Corollas I can't remember what year 80 something and that fluid is still purple the brake still work The car somewhat runs We haven't done anything with it in a long time but I move it around the property when needed and the brakes are fine of course silicone won't eat up rubber and turn black or do any of that It's not also the proper brake fluid for the car. One of these days in a yard car I'm going to try the same fluid in a Prius probably with pretty uneventful results.
  11. qmanqman
    qmanqman Active Member
    439
    152
    CO
    You change brake fluid?
    PriusCamper likes this.
  12. nancytheprius
    365
    156
    iowa
    Not yet
  13. bisco
    52,286
    i wouldn't bother
  14. Tombukt2
    13,290
    2,398
    I think there are some strips that can measure moisture content pH things like that there's no moisture content and everything is good I would say leave it alone for the general consumer not mess with it probably not worth your time
    VelvetFoot likes this.
  15. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Mine was original at 120K and was brown. I sucked it out with a turkey baster from the dollar store and refilled with brand new clear. No issues. now at 141K still clear and no brake problems at all. I would do it for peace of mind.
  16. Mendel Leisk
    41,826
    That leaves the funky stuff down at the caliper though.
    sylvaing likes this.
  17. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
  18. Dduelin2
    Dduelin2 Junior Member
    N Florida
    What an eye opener.
    Yes you should positively change brake fluid at the manufacturer's recommended interval. BF absorbs moisture which raises the boiling point of BF (brakes become less efficient under heavy repeated use or don't work at all at some point) and corrodes components in the master cylinder and calipers or drums. Neglecting maintenance eventually costs more or screws some owner further down the line. Replacing BF requires a complete flush and bleed of each circuit, not just topping off the reservoir.
  19. Mendel Leisk
    41,826
    If you’re referring to Toyota USA, they’ve got nothing to say on the subject. Toyota Canada says 3 years or 48k kms. IIRC this was a turnaround; they were also silent on the subject in 2010 when we bought.
  20. Dduelin2
    N Florida
    Well, they have plenty to say now.
    2013 Toyota brake fluid replacement interval
